Hi.
I need string array with 10 elments, and cycle to access each element.
I didnt found examples in wiki.
Thanx for help.
Hi.
Thanx for help.
At least according to Designer’s syntax highlighting it doesn’t appear that openHAB’s rules support arrays so you will need to use a List.
val myList = newArrayList('One', 'Two', 'Three', 'Four', 'Five', 'Six', 'Seven', 'Eight', 'Nine', 'Ten')
Looping will depend on what you want to do. You can do a forEach:
myList.forEach[ str |
// do stuff
or an Iterator:
val iterator = myList.iterator
while(iterator.hasNext) {
val str = i.next
// do stuff
Needing to create an array like this and iterate over them is a rare need which is why you didn’t find an example in the wiki.
Rich
How to create fixed size array?
I use this code, but it ugly:
var OledLines = newArrayList()
(0..31).forEach[
OledLines.add("")
OledLines.set(20, "Test")
I use it to post messages to OLED display in particular line.
The Rule’s DSL doesn’t have good support for arrays. ArrayList isn’t really an array, its a collection and it is not fixed sized.
You can try to see if one the following with work:
var OledLines = newArrayList(32)
var List<String> OledLines = new ArrayList(32)
Note that you will have to import both java.util.List and java.util.ArrayList for that second example to work.
Another cheezy hack could be:
var OledLines = " , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , ,".split(',')
