I would like to test the state of a MQTT device from a rule.
Currently I use a sendCommand to set the state of a device, for instance:
MOTE_40_ACT.sendCommand(“ON”)
What could be the correspondent action to get or read the state, and then test it? For instance to verify if the previous command was a effective.
The item definition is:
Switch MOTE_40_ACT “40. Mote_40 - Prise” { mqtt=">[mymosquitto:Home/RF/sb/040/0/047:command:ON:default],>[mymosquitto:Home/RF/sb/040/0/047:command:OFF:default],<[mymosquitto:Home/RF/nb/040/0/047:state:default]" }
Thanks in advance,
Robert
