I’m curious to test some new Bindings which are in development (like Bose or Yeelight). I found the source but have no idea what to do next. I copied the jar file in the add-ons folder but nothing happens…is there any additional step needed?
Look in the log and see if it says anything about starting the binding.
You might need a cfg file.
If it is a 1.x version binding you will need to enable the 1.x compatibility layer.
