This tutorial should explain how to move the persistence running on the OH runtime system (in my case a raspberry pi) to your NAS (e.g. Synology).
The goal is to reduce the write access to the SD-card of the RPi to reduce the probability of SD-card corruption.
My assumption is, that your jdbc persistence is already running on your OH (here 2.1 stable).
- Install MariaDB on your NAS (please note: The standard port on synologies NAS’ mariaDB is 3307, not the MySQL default of 3306)
This will also install all required sub components (e.g. phpmyadmin) - Connect to your NAS via ssh
ssh admin@youripadress (for synology admin is the standard admin and root might not be allowed to log in remotely via console) - Verify the location of your MySQL executable instance – in my case it was mariaDB10: sudo find . -name mysql (from root folder)
- Connect locally to the MariaDB:
/usr/local/mariadb10/bin/mysql -u root –p - Proceed with this tutorial by @Christian_V point 2 at “Create a database for OpenHAB”
- Additionally for remote access:
CREATE USER ‘openhab’@’%’ IDENTIFIED BY ‘yourpassword’;
And
GRANT ALL PRIVILEGES ON openhab.* TO ‘openhab’@’%’;
(% means remote access from all IPs in your network)
And
flush privileges; - Set your jdbc.cfg according to your setup:
url=jdbc:mariadb://192.168.178.39:3307/openhab
user=openhab
password=xxxxxx - After a restart of OH or reload of jdbc.cfg you should be able to see the items being generated in your mariaDB
- In case you would like to migrate your old DB data to your new DB, this could be easily done by phpMyAdmin (export / import) – I actually tried it with HeidiSQL which worked like a charm as well.
Please note, that you should drop all tables generated during the test on your NAS first. Otherwise the item_IDs will be messed up when you import the DB structure from your OH persistence.
