i am using the snmp-binding to get the actual bandwith from my modem. I get the value as bit/s but would like to transform it to mbit/s and am not sure how to convert it the right way.
Would be great if anyone could help me.
Thanks, Alex
Thanks, Alex
I’m using Javascript Transformation to do something similar. I have IKEA Tradfri rollershutter which reports battery in the 0-50 range, so I created transformation for that channel that doubles the value. The code for the .js file looks like this:
(function(i) {
return 2*i
})(input)```
Thanks for your reply! I am not really familiar with JS but i tried to adopt your script for a first test…
(function(i) {
return i/1000
})(input)```
After that i changed the profile at the channel link but i get this warning:
12:39:55.181 [WARN ] [files.JavascriptTransformationProfile] - Could not transform state '86154000' with function 'calc_bandwidth.js' and format '%s'
Actually the Value of the item is 86154000 and i want to get 86,2 mbit/s
There seems to be problem with formatting the code, those three apostrophes shouldn’t be there at the end. Try this:
(function(i) {
return i/1000
})(input)
Thank you, great! Now i get 86 as value for the item.
When i add
%.1f MBit/s
to the state formatter at the advanced options i get an error again. When i add it to the state description the value is shown as expected:
I’m not sure what “advanced options” you are looking at,but maybe the /
needs escaping there //
EDIT - ah wait, are talking about the profile? JS profile returns strings (even if it looks like a number) so can’t be formatted with numeric %.1f
until after it has been used to update a Number Item.
As an aside, shouldn’t you be dividing by 1024?
yes, in principle you are right. I actually have to divide once by 1024 and once by 1000. The last three zeros are apparently only appended by the modem.
(function(i) {
return i/1000/1024
})(input)
Does someone know how to reset the persisted values by OH3? I havent setup a persistance service, yet, but i would like to reset the data that is safed by default:
