So i have a bit of a problem i need my relay 1 to turn on and after than i can turn the relay 2 on or off but when i want to turn relay 1 off i need relay 2 to turn off first if this relay is on.
rule "Switch1 ON"
Item Switch1 changed to ON
Relay1.postUpdate(ON)
Relay2.postUpdate(ON)
rule "Switch1 OFF"
Item Switch1 changed to OFF
Relay2.postUpdate(OFF)
Relay1.postUpdate(OFF)
You could wrap the second command in each of Harry’s example rules in a timer() function, if you wanted them to fire after a delay.
