I have two Monoprice Z-Wave Curtain Module, Vision Security ID d03 Type 200d. I can command open/close, but I am unable to set the durations via HABMin, so trying to set via the configuration command-class. I’ve tried getting this to work on a light switch in the past, but had no luck, so I just manually set everything in HABmin.
How does the configuration class work?
I’ve tried Items:
Dimmer Curtain_1_Conf { zwave=“50:command=CONFIGURATION, parameter=UP” }
Dimmer Curtain_2_Conf { zwave=“50:command=CONFIGURATION, parameter=DOWN” }
Dimmer Curtain_3_Conf { zwave=“50:command=CONFIGURATION, parameter=STOP” }
And items (not sure what the actual parameters IDs would be):
Dimmer Curtain_1_Conf { zwave=“50:command=CONFIGURATION, parameter=0” }
Dimmer Curtain_2_Conf { zwave=“50:command=CONFIGURATION, parameter=1” }
Dimmer Curtain_3_Conf { zwave=“50:command=CONFIGURATION, parameter=2” }
These don’t work via rule, or sitemap with:
Switch item=Curtain_1_Conf mappings=[10=“10”]
Switch item=Curtain_2_Conf mappings=[10=“10”]
Switch item=Curtain_3_Conf mappings=[10=“10”]
I’ve also tried a few different item types. What am I doing wrong?Months ago, I also tried to set configuration data on my Cooper light switches with no success:
Switch item=Dimmer_Hall_Panic label=“Set param0” mappings=[0=“0”, 1=“1”, 2=“2”, 3=“3”]
Switch item=Dimmer_Hall_Panic2 label=“Set param1” mappings=[0=“0”, 1=“1”, 2=“2”, 3=“3”]
Switch Dimmer_Hall_Panic { zwave=“6:command=CONFIGURATION, parameter=0” }
Switch Dimmer_Hall_Panic2 { zwave=“6:command=CONFIGURATION, parameter=1” }
