Hi everyone,
I’m trying to ‘sendHttpGetRequest’ that include the variable “dimmerlevel” in the URL. I have done this with ON/OFF and that works, but I simply can not figure out how to do the same using “dimmerlevel” value. I have tried searching this forum an google but can not find any information.
My simple on/off rule that works:
rule “Turn Garage_Loftlampe on”
Item Light_Garage_Loftlampe changed to ON
sendHttpGetRequest(“http://192.168.10.11:8080/json.htm?type=command¶m=switchlight&idx=20&switchcmd=On”)
rule “Turn Garage_Loftlampe off”
Item Light_Garage_Loftlampe changed to OFF
sendHttpGetRequest(“http://192.168.10.11:8080/json.htm?type=command¶m=switchlight&idx=20&switchcmd=Off”)
My dimmer rule
rule “Turn Light_Outdoor_Spots2 on - to dimmer level”
Item Light_Outdoor_Spots2 received command
sendHttpGetRequest(“http://192.168.10.11:8080/json.htm?type=command¶m=switchlight&idx=26&switchcmd=Set%20Level&level=**Dimmer_Value**”)
But how do I get the ‘Dimmer_Value’ replaced by the actual value?
I have no experience with coding/scripting so please forgive my likely basic question.
Kind regards,
Søren
