Hello!
Is there a way to use more than 1 MAXCul Gateway Device? The naming in openhab.cfg is only “maxcul” like the BINDING_NAME.
I think this is a very common Issue for all Bindings. Any ideas? eg. copy the Binding with a new name?
Thanks for any hints.
Greets Olli
If the docs do not explicitly state that it supports more than one gateway than it most likely is not supported. You can run another instance of OH and use the MQTT EventBus configuration to synch the two together.
Thanks for the quick reply. I never used EventBus bevor. Let’s try to get this done.
