Now it happened to me: The SD card stopped working.
I once moved the root to a SSD, but how can I use the SSD, where my “old” system resides, on a new openHABian installation? Is there any tutorial?
I took a look into the openhabian-config, but there is only a “move to SSD” (including formatting the SS) menu entry - but there’s no not “use existing SSD root” as an option…and in the forum I didn’t find this question.
I have very basic knowledge in Linux, so if I need to change some system files I should be able to manage it
Never mind, I connected the SSD on my PC, copied the files - and copied all back over to the new installation. When everything runs, I make a new “move” to the SSD to get away from the SD card (which was a good idea in the past otherwise my installation would have been lost)
Just for the records: This way will screw the access rights, because the system runs under the user and group “openhab” but files uploaded via samba uses “openhabian”.
to use an existing SSD or USB-stick that contains a move root with a new installation, you only have to edit /boot/cmdline.txt and point root to /dev/sda1
To do that, enter
sudo nano /boot/cmdline.txt
... change the line root=... to root=/dev/sda1
leave nano with crtl-x
YES to save
