Hi there,
I run oH2.5 on a Raspi3 with MQTT binding.
I’m just wondering how can one use the tasmota backlog command in order to switch the LED on and after some time off …
Like in tasmota console with:
Backlog power on; delay 200; power off
// things
Thing topic h801_XXXX "LED H801 #2 (sonoff-XXXX-h801)" @ "MQTT" {
Channels:
Type switch : h801_XXXX_switch "LED H801 #1: Power Switch" [ stateTopic="tasmota/sonoff-XXXX-h801/stat/POWER", commandTopic="tasmota/sonoff-XXXX-h801/cmnd/POWER", on="ON", off="OFF" ]
Type colorHSB : h801_XXXX_color "LED H801 #1: Farbe" [ stateTopic="tasmota/sonoff-XXXX-h801/stat/RESULT/HSBColor", commandTopic="tasmota/sonoff-XXXX-h801/cmnd/HSBColor" ]
Type number : h801_XXXX_tasmocolor "LED H801 #1: Switch RGB" [ commandTopic="tasmota/sonoff-XXXX-h801/cmnd/color", formatBeforePublish="%d" ]
Type dimmer : h801_XXXX_dimmer "LED H801 #1: Dimmer" [ commandTopic="tasmota/sonoff-XXXX-h801/cmnd/dimmer" ]
Type number : h801_XXXX_scheme "LED H801 #1: Scheme" [ commandTopic="tasmota/sonoff-XXXX-h801/cmnd/scheme", formatBeforePublish="%d" ]
Type switch : h801_XXXX_wakeup "LED H801 #1: Wakeup" [ commandTopic="tasmota/sonoff-XXXX-h801/cmnd/wakeup" ]
Type number : h801_XXXX_wakeupd "LED H801 #1: Wakeup duration" [ commandTopic="tasmota/sonoff-XXXX-h801/cmnd/wakeupduration", formatBeforePublish="%d" ]
Type string : h801_XXXX_reachable "LED H801 #1: Reachable" [ stateTopic="tasmota/sonoff-XXXX-h801/tele/LWT" ]
Type number : h801_XXXX_rssi "LED H801 #1: Empfang RSSI" [ stateTopic="tasmota/sonoff-XXXX-h801/stat/STATE", transformationPattern="JSONPATH:$.Wifi.RSSI" ]
Type string : h801_XXXX_command "LED H801 #2: Command" [ commandTopic="cmnd/sonoff-XXXX-h801/Backlog" ]
// items
String OG_sz_l_led1_command "BLINK" <light> (gM,gR,Glicht) { channel="mqtt:topic:mosquitto:h801_XXXX:h801_XXXX_command" }
rule "SZ Schrank-LED Licht 20sec schalten"
Channel "mihome:sensor_switch:XXX:YYY:button" triggered DOUBLE_PRESSED
OG_sz_l_led1_command.sendCommand("Backlog power on; delay 200; power off")
The outcome is as follows:
[vent.ChannelTriggeredEvent] - mihome:sensor_switch:XXX:YYY:button triggered DOUBLE_PRESSED
[ome.event.ItemCommandEvent] - Item 'OG_sz_l_led1_command' received command Backlog power on; delay 200; power off
[nt.ItemStatePredictedEvent] - OG_sz_l_led1_command predicted to become Backlog power on; delay 200; power off
… so nothing happens with the LED
