I use TCP binding to get a trigger message from a T25 Mobotix towards Openhab.
The meaning of what I’m trying to do is really a trigger and there is no “state” associated to the message.
The only way I have found so far is to do it as below (I got the T25 to send a text message with ON inside (to explain the REGEX((ON)) part, but i really use it only a a trigger).
Switch RFIDorPINAccessOnT25 {tcp="<[ON:192.168.101.11:8888:'REGEX((ON))']" }
rule "Test"
Item RFIDorPINAccessOnT25 changed to ON
RFIDorPINAccessOnT25 .postUpdate(OFF)
// Here what I want to do...
I’m wondering if there is a cleaner way than going via an Item and resetting it inside a rule systematically after the trigger?
Thanks,
