I am struggeling to trigger say() through the REST-API.
e.g. the equivalent to say(“Test”) in a .rules file.
Could anyone point me in the right direction?
I’m probably wrong, but I’m not aware of a way to access it directly via Rest.
I have an SMS sending system which uses a dummy item and a rule that watches for updates / changes.
Then push the reformatted .state of that item into a SMS send URL
I also have a String item that I use to push different content into my Chromecasts or webaudio.
Again, a rule watches a virtual / orphaned Item and pushes the .state into the Say commands.
rule "say anything"
Item SayItem received update
say(SayItem.state, "voicerss:enGB", "webaudio")
It’s that of any help?
I thought of that but I still hope that there is a different solution …
I went down the same road…
But this works well enough for my application.
Just update the SayItem via Rest
Good luck.
If you find another way, please do post it
