The documentation says “When the discovery process is started, the binding will put the controller into inclusion mode for a defined period of time to allow new devices to be discovered and added to the network.”
I can’t see any obvious way / button for putting the stick into inclusion mode. Any assistance gratefully received.
Ah. So beautifully simple when you know how! The stick now generates an encouraging blue flashing light. I will marked solved once I have added a device. Thanks.
