This might be helpful for anyone looking to automate their Rinnai Hot Water on demand heater that has the Control-R WiFi module installed. Rinnai’s wifi integration has been a complete hack from the company for over a year and im happy to finally have some form of a solution to turn recirculation on though OpenHAB.
I do not take credit for this, as i came across some code that gains access to their portal for the necessary commands:
Step 1: Install this on your OH Server: GitHub - explosivo22/rinnaicontrolr: Python interface for the Rinnai Control-R API
Step 2: Edit the following script: /usr/local/lib/python3.6/dist-packages/rinnaicontrolr/base.py
Under the following Line (Line:130):
def is_heating(self, dev):
return dev['info']['domestic_combustion'] == 'true'
Add:
def get_inlet_temperature(self, dev):
return dev['info']['m08_inlet_temperature']
def get_outlet_temperature(self, dev):
return dev['info']['m02_outlet_temperature']
def start_maintenance_retrieval(self, dev):
self._set_shadow(dev, 'do_maintenance_retrieval', 'true')
This will allow you to get some statistics from your unit if you wish, Inlet water temperature, Outlet water temperature, and query ‘maintenance’ which is required to refresh/pull these values listed.
Once that is done, create the following script in your Openhab/scripts directory:
rinnai.py
import sys
from rinnaicontrolr import RinnaiWaterHeater
rinnai = RinnaiWaterHeater('XXemail@email.comXX', 'XXpasswordXX')
for device in rinnai.get_devices():
if str(sys.argv[1]) == "settemp": #Set the temperature of hot water heater
rinnai.set_temperature_setpoint(device, sys.argv[2]) # set the temp for the second arguement value
if str(sys.argv[1]) == "maint": #Start Maintenance retrieval
rinnai.start_maintenance_retrieval(device)
if str(sys.argv[1]) == "recirc": #Enable Recirc followed by duration
rinnai.start_recirculation(device, sys.argv[2]) # Start Recirc with duration variable in minutes
if str(sys.argv[1]) == "status": #JSON output of status query
s = ""
s = s + "{\n"
s = s + '"TEMP": "%s",\n' % \
rinnai.get_temperature_setpoint(device)
s = s + '"isHeating": "%s",\n' % \
rinnai.is_heating(device)
s = s + '"isRecirculating": "%s",\n' % \
rinnai.is_recirculating(device)
s = s + '"inletTemp": "%s",\n' % \
rinnai.get_inlet_temperature(device)
s = s + '"outletTemp": "%s",\n' % \
rinnai.get_outlet_temperature(device)
s = s + "}\n"
print(s)
Create the following files in openhab:
.things
Thing exec:command:rinnai [command="/usr/bin/python3 /etc/openhab/scripts/rinnai.py status", interval=10, timeout=10]
.items
Group Rinnai
Group gRinnai_Parse_json (Rinnai)
String H_BM_LDRY_Rinnai_JSON "Rinnai JSON: [%s]" {channel="exec:command:rinnai:output"}
Number H_BM_LDRY_Rinnai_TEMP "Current Temperature [%s °F]" (Rinnai,gRinnai_Parse_json)
Number H_BM_LDRY_Rinnai_SETTEMP "Target Temperature [%s °F]" (Rinnai)
Number H_BM_LDRY_Rinnai_inletTemp "Rinnai Inlet Temperature [%s °F]]" (Rinnai,gRinnai_Parse_json)
Number H_BM_LDRY_Rinnai_outletTemp "Rinnai Outet Temperature [%s °F]]" (Rinnai,gRinnai_Parse_json)
String H_BM_LDRY_Rinnai_isHeating "Rinnai Is Heating [%s]" (Rinnai,gRinnai_Parse_json)
String H_BM_LDRY_Rinnai_isRecirculating "Rinnai is Recirculating [%s]" (Rinnai,gRinnai_Parse_json)
Switch H_BM_LDRY_Rinnai_RECIRCULATION "Recirculation" (Rinnai) {ga="WaterHeater",expire="1m, command=OFF"}
Number H_BM_LDRY_Rinnai_RECIRC_DURATION "How long to run Recirc for [%s min]" (Rinnai,gRinnai_Parse_json)
.Rules
var Timer tRinnai_Reschedule_Maint = null
rule "Rinnai: Parse JSON output to individual Items"
Item H_BM_LDRY_Rinnai_JSON changed
logInfo(filename+".R1", "### Rinnai: Parse JSON output to individual Items ###")
val String json = (H_BM_LDRY_Rinnai_JSON.state as StringType).toString
gRinnai_Parse_json.members.forEach [ value |
var String name = value.name.replace('H_BM_LDRY_Rinnai_','$.')
value.postUpdate(transform("JSONPATH", name, json).replaceAll('"',''))
rule "Rinnai: Turn Recirculation ON"
Item H_BM_LDRY_Rinnai_RECIRCULATION changed from OFF to ON
logInfo(filename+".R2", "### Rinnai: Turn Recirculation ON ###")
executeCommandLine("/usr/bin/python3.6", "/etc/openhab/scripts/rinnai.py", "recirc", H_BM_LDRY_Rinnai_RECIRC_DURATION.state.toString())
rule "Rinnai: When Heater is Running, Gather Maintenance Stats (Inlet/Outlet Temps)"
Item H_BM_LDRY_Rinnai_isHeating changed from False to True
logInfo(filename+".R3", "### Rinnai: When Heater is Running, Gather Maintenance Stats (Inlet/Outlet Temps) ###")
if(tRinnai_Reschedule_Maint === null) {
tRinnai_Reschedule_Maint = createTimer(now.plusSeconds(30), [ |
if(H_BM_LDRY_Rinnai_isHeating.state == "True") {
executeCommandLine("/usr/bin/python3.6", "/etc/openhab/scripts/rinnai.py", "maint")
logInfo(filename+".R", "--> Gathering Maintenace Information and Rescheduling retrieval")
tRinnai_Reschedule_Maint.reschedule(now.plusSeconds(30))
} else {
logInfo(filename+".R", "<--Canceling Maintenace Retrieval Timer")
tRinnai_Reschedule_Maint.cancel()
Hope this helps someone that is looking to acheive the same, If you have any questions just ask!
