hey michaeljoos - i copy pasted and it works now something with the IR part of my own didnt work. from a logic perspective you use == vs <= which is my implementation. basically you run so that you get an alert when it become 15 right? but what happens if for some reason a battery drops more than than one unit? wont you miss the alert?
Did you try the code I posted?
I run it once a day.
It will send an email if the battery is less than or equal to 15% and on Sunday it sends a list of all the batteries in the battery group.
It is for OH4 which is what you said you are using.
thanks for sending it through. I went through it. however your code is email based and i prefer the notification element offered by my code (it sends an alert to the openhab app) - so i just adjusted my own with the part offered by michaeljoos
For future readers of this thread, there is a rule template on the marketplace that handles this use case.
Install the rule templated from the Automation menu.
Create a Rule of Script that sends the alert. This is where you send the alert. I use the following:
configuration: {}
triggers: []
conditions: []
actions:
- inputs: {}
configuration:
type: application/javascript;version=ECMAScript-2021
script: >
var {alerting} = require('rlk_personal');
var logger = log('Low Battery');
alerting.sendAlert('The following batteries are below 10%: ' + this.threshItemLabels, logger);
type: script.ScriptAction
Instantiate a new rule using Threshold Alert as the template. I use the following configuration.
Parameter
Purpose
Value
Triggering Group
Group with all the battery level Items
AllBatteries
Threshold State
The threshold value to compare against, if the value is < this the alert rule is called. The rule handles UoM
15 %
Comparison Operator
If Item State <operator> Threshold is true, the alert rule is called.
Alert Rule
UID of the rule created in step 2.
battery_alert
Do Not Disturb
Do not call the alert rule between these two times, wait until the end of the time period. This prevents alerts from being sent over night.
Start: 22:00, End: 08:00
Rate Limit
Do not call the alert rule more often than this. For example, don’t alert more than once every eight hours.
PT8H
All the other properties are left at the defaults.
This rule template is pretty handy. I use it to send an alert when a door is left open too long, when a battery goes low and needs to be replaced soon, a sensor stops reporting, a service goes offline, and as a motion sensor timer.
I am a little bit confused. What is valid now for OH4.04 release?
What would be state of art implementation for Battery notification? The rule from Greg posted above for OH4 or your rule template @rlkoshak ?
I assume the rule from market will be maintained but I see some restrictions. Are they resolved now? Can I use the proposed template or shall I rather go with proven rule form @ubeaut ?
For some reasons I have a notification for this part of code. Raw 35 starts with for (var i_index in i_list) {
var datetoday = new Date();
var numberofweek = datetoday.getDay();
This will check the percentage of battery left and if it is low then email
Add the items to check into gBatteries group
//DAILY REPORT
var percenttocheck = 65;
var heading="Openhab daily low sensor battery report";
//WEEKLY REPORT
//Only do on Sundays (numberofweek is 0)
if (numberofweek == 0){
var percenttocheck = 100;
var heading="Openhab weekly sensor battery report";
var email_message = "";
var i;
var sendmail="";
var i_list = items.getItem("gBatteries").members;
i = i_list[i_index];
if(i.state <= percenttocheck){
sendmail="YES";
console.info('Test',i.label,i.state);
email_message = email_message + i.label + " " + i.state + "%" + "\r\n";
if(sendmail=="YES"){
message = "<H2>Sensor battery report <br>" +email_message +"</H2>" + "Percentage check was set at " +percenttocheck;
actions.get("mail", "mail:smtp:213647137d").sendHtmlMail("jacekdebski76@gmail.com", heading, message );
console.info(email_message);
2023-11-24 14:40:42.549 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'batterystatus.rules' has errors, therefore ignoring it: [35,25]: missing ';' at 'i_list'
Well, obviously I’m going to say the rule template. But you should use what ever you are comfortable using.
That rule template though, while being rather complex, is my most tested template and probably my second most used template so it’s pretty solid.
The rule template has more features including a “do not disturb” period where, for example, if a batter goes low in the middle of the night it will wait until morning to tell you. It also supports a different threshold level per battery as it seems that each device has it’s own unique meaning for remaining battery. I’ve one device that when it gets to 20% I still have 3-6 months left before I need to replace the battery while another one should be replaced at 30% because it has a mere day or two left.
I run OH 4.0.4. Updated from OH3. I know in OH4 some items values were updated in case of units.
What OH version you have? If it is not the same I am wondering if your script will run with the latest build.
We do not have “;” in your code i do not understand the way you check the index matrix. But I am not a coding expert.
When I comment the whole for () loop, warning disappear. So definitively there is sth wrong with the for ()
