opus
(JĂĽrgen Baginski)
November 19, 2020, 10:35am
1
The thread about the script solution for VitoConnect was started 2 years ago.
Instead of creating new threads when a problem is observed the users tend to ask in this (now rather long) thread. I would close it if I could.
When using the boostrap.php from the github I get the error “couldn’t find index.php”.
Changed it to DIR./Viessmann/index.php
Changed the user and password and defined it hardcoded (like you told)
Still no authentication…
[image]
I think i couldn’t reach the authentication servers from Viessmann but how to check that?
@opus and @thetrueavatar
Solution: I had 2 network interfaces (NIC) one internal and one connected to the internet. Because there is no possibility to tell the API which …
I think only @moderators can lock a thread. They set up new threads to auto-lock after inactivity but did not want to go back and clean up the old open ones.
The discussion thread is here.
We have many users jumping on to an existing thread saying they have the same problem but the thread discussion has not helped them.
Most times the new user has the same symptoms but a different problem. It is very confusing trying to handle many users & problems in the same thread. If the forum detected “same problem” or “same issue” could it pop up a message suggesting or offering to start a new thread?
I do not know the capabilities of the forum software.
system
(system)
Closed
December 31, 2020, 4:51am
4
