val maxHumidity = 50
val int fanTime = 10
rule "Turn on fan"
Item Bathroom_Humidity changed
if(Bathroom_Fan.state != ON) {
if(Bathroom_Humidity.state as Number > maxHumidity) {
Bathroom_Fan.sendCommand(ON)
createTimer(now.plusMinutes(fanTime), [| Bathroom_Fan.sendCommand(OFF) ])
You need Persistence installed and configured to store Bathroom_Humidity.
val deltaPercent = 0.05 // 5%
rule "Turn on fan"
val pastHum = Bathroom_Humidity.historicState(now.minusMinutes(5)).state as Number
val currHum = Bathroom_Humidity.state as Number
if(pastHum < currHum) {
val delta = currHum - pastHum
if(delta / pastHum > deltaPercent) {
If it were me, I’d want the fan to stay on until a desired humidity has been reached or a maximum amount of time has past with it on.
Switch Bathroom_Fan { expire="10m,command=OFF" } // add your Channel links and other options
val hysteresis = 2
rule "Turn on fan"
if(Bathroom_Fan.state != ON) Bathroom_Fan.sendCommand(ON)
else if(Bathroom_Humidity.state as Number < maxHumidity - hysteresis) {
hysteresis keeps the fan from rapidly turning on and off if the humidity is right around maxHumidity.
Again, this is just me, but if the room humidity were less than a threshold, I wouldn’t want to turn on the fan even if someone is taking a shower. But I live in a very dry area where it is a struggle to keep the humidity above 30% in the first place.
The last example already has a max runtime. That is what the expire does. If the humidity gets above maxHumidity the fan turns ON. The fan will stay on until the humidity drops below maxHumidity-hysteresis or 10 minutes pass ,which ever comes first.
ok, now i understand. maybe what you are doing in the last example is not that bad .
but i have some errors when loading the rule
val hysteresis = 2
rule "Turn on fan"
Item esp_douche_hum changed
if(esp_douche_hum.state as Number > maxHumidity) {
if(Douche.state != ON) Douche.sendCommand(ON)
else if(esp_douche_hum.state as Number < maxHumidity - hysteresis) {
Douche.sendCommand(OFF)
and the error, what is wrong ?
2018-01-10 21:17:41.496 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'fan.rules'
2018-01-10 21:17:41.569 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'fan.rules' is either empty or cannot be parsed correctly!
2018-01-10 21:17:41.942 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'fan.rules' has errors, therefore ignoring it: [11,58]: missing '>' at '-'
2018-01-10 21:48:47.023 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'fan.rules'
2018-01-10 21:48:47.109 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'fan.rules' is either empty or cannot be parsed correctly!
2018-01-10 21:48:47.615 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'fan.rules' has errors, therefore ignoring it: [11,59]: mismatched input '-' expecting ')'
[11,72]: no viable alternative at input ')'
Stil the same error, do i need to install somthing else.
in the previous post you mentioned that i have to install Persistence, is this nessecary and how to do this.
This makes no sense but I don’t have time to figure out why it doesn’t work.
Use:
val minHumidity= 48
rule "Turn on fan"
else if(esp_douche_hum.state as Number < minHumidity) {
Because humidity is already a number, i don’t have to use as number. thats the way i solved it.
val maxHumidity = 65
val minHumidity= 3
rule "Turn on fan"
if(esp_douche_hum.state > maxHumidity) {
else if(esp_douche_hum.state < (maxHumidity-minHumidity)) {
if(Douche.state != OFF) Douche.sendCommand(OFF)
For the MQTT part, my standard MQTT line worked, but i don’t know where to put the expired part.
that’s my problem, i can’t get that information from one of the wiki pages.
That doesn’t make much sense either. If the state is already a Number then the as Number would do nothing. It shouldn’t break the code. Very strange.
[/quote]
i think i figurd it out by myself, by try and error.
and it looks like it is working, also instsalled the expired binding.
@rlkoshak - Hi Rich,
Im trying to use your rule example as above…but it seems the " if(pastHum < currHum)" isnt working due to the currHum var containing the %
I thought the ’ as Number" would strip this?
My test rule:
rule "Turn on fan"
Item HumidSensor_OfficeFridge changed
if(AeonModule_MainBathFan.state != ON) {
val pastHum = HumidSensor_OfficeFridge.historicState(now.minusMinutes(5), "influxdb").state as Number
val currHum = HumidSensor_OfficeFridge.state as Number
logWarn("MainBathFanRule", "VarInfo PastHum : " + pastHum )
logWarn("MainBathFanRule", "VarInfo Current : " + currHum )
logWarn("MainBathFanRule", "Checkpoint1 : " + delta)
logWarn("MainBathFanRule", "Starting Fan")
AeonModule_MainBathFan.sendCommand(ON)
createTimer(now.plusMinutes(fanTime), [| AeonModule_MainBathFan.sendCommand(OFF) ])
An extract of the log - as you can see the currHum value contains the % :
