HowTo: Use Philips Hue sensors (Motion Sensor / Dimmer Switch)
Yes, I do. You can send a command in a rule or use a Switch item for it.
demo.items
Switch hueMotionSensorStatus
demo.rules
rule "Switch Hue Motion Sensor ON / OFF"
    Item hueMotionSensorStatus changed
    val url = "http://<bridge ip address>/api/<username>/sensors/<id>/config"
    var String body = ""
    if( hueMotionSensorStatus.state != ON ) {
        body = '{"on":false}'
    } else {
        body = '{"on":true}'
    logInfo("demo", "Send command '{}' to {}", body, url)
    sendHttpPutRequest(url, "application/json", body)
