I’m going to set up a separate DEBUG log file for this binding. Just have to figure out how exactly again…as it has been a long while ago since I’ve done this particular line of work…keep you posted.
But spitting through the various openhab.log(.n) files shows (the recurring WARN):
2018-11-25 02:45:11.743 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/openhab/addons/org.eclipse.smarthome.binding.hue-0.10.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.binding.hue [253]
Unresolved requirement: Import-Package: org.eclipse.jdt.annotation; resolution:=“optional”
Unresolved requirement: Import-Package: org.eclipse.smarthome.config.discovery.upnp
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [10:org.apache.felix.fileinstall:3.6.4]
Either missing dependencies?
Sidenote: I do use the official openhab:2.4.0.M6-amd64-debian docker container with persistent storage on a Ubuntu 18.04 LTS server
Question to the group. I run a hue motion sensor configured as describe ahead which triggers a shelly 1 via MQTT.
Unfortunately it takes up to 3 sec. till the shelly switch on the lights.
Does someone else have similar setup and encounter the same results?
Would be interesting to understand, as I then could focus on the key area of the problem.
Thanks Christoph. I went a head and tried you test version.
Seems to be working very well on my self-up (22 lamps/ 5 motion sensor). I’ve only configured this manually through item/things files so I haven’t played with the auto side through paperui.
In terms of documentation I was more looking at changing poling settings etc. For example I believe the presence sensor update at 500ms intervals and I can see that. But what frequency do other other sensors update at e.g. temp/light? For instance if I switch on a light in front of the the sensor it does take some time to update (many seconds).
Sounds good. I am happy to hear, that it is working.
Nice catch. Indeed it is not mentioned in the docs. Do you have time to add it? The polling interval for all sensors is by default 500ms (expected value in milliseconds, min. = 50ms). The polling interval for lights is by default 10s (expected value in seconds, min. = 1s). You are able to adjust both values for your needs like this:
I bought myself a Hue motion sensor, for the measurement of the ambiant light.
Unfortunatly Openhab is unable to find the sensor.
When I look on the Openhab Docs it states it is supported and this tutorial confirms this.
I am running OH2.3 Stable and updated the system through the openhabian-config tool.
Unfortunatly it didn’t help.
I’ve got the feeling the binding should be version 2.4 but is still 2.4, did the update fail or aren’t bindings updated until there is a new 2.4.0 stable version?
I found and testen a 0.10.0.jar version downloaded via a link somewhere in this thread.
But this is a test version, if I.m correct and doesn’t work with my version.
If I need version 2.4.0 binding, where can I find the update file and is it correct that it is just a drop of a .jar file into the addons folder?
