Cossey
(Stewart Cossey)
January 17, 2019, 1:36pm
81
@MDAR , I’ve just looked at those files but unfortunately they aren’t any good for testing as they have not been saved correctly (I see the This XML file does not appear to have any style information associated with it. The document tree is shown below. message appears at the top of the text, which is what you see in web browsers like Chrome when viewing the file).
Using Chrome, when viewing the xml pages use the “3 Dots Menu Button” > More Tools > Save Page As to correctly save these files to disk with the proper markup intact without the above message. I will still work on getting these two printers supported, but I need these files to test it and make sure it works all good. Could you please give this another try?
Thanks heaps Stuart.
MDAR
January 17, 2019, 1:47pm
82
I’ll get on to that this afternoon.
MDAR
January 17, 2019, 2:00pm
83
All Done
I’ve replaced the Zip file on my website.
I’ll change the files on GitHub next… DONE
MDAR
January 18, 2019, 10:07am
84
Hi Stewart
I noticed that your GitHub site suggests that you’ve already added the two printers
Where can I download the jar file?
(The Dropbox link above seems to refer to an older version)
Cossey
(Stewart Cossey)
January 18, 2019, 10:31am
85
Implementation has been done but not tested just yet with your newly uploaded XML files so I haven’t yet built a new version of the plugin (I’m being more strict now with my releases, making sure new Things are tested on my end before releasing). I have one more episode of You’re all surrounded that I’m watching now, then after I’ll test with the files you’ve provided me to make sure it’s working 100%, then I’ll close the issue and then update the Binding here.
Check back again in a couple of hours, thanks for your patience.
MDAR
January 18, 2019, 10:40am
86
Hi
Sorry if I sounded needy.
I completely misunderstood the situation.
Please take as much time as you like, (enjoy a few more episodes) and only work on this when you have the time & interest.
Many thanks,
Stuart
Cossey
(Stewart Cossey)
January 18, 2019, 12:08pm
87
New Updates!
Fixes manually adding Things from the Binding - it would incorrectly mark Printer as offline.
LaserJet 200 color should be correctly auto-discovered.
Support for Deskjet 3520
Known issues:
Officejet 7500 e910 is a Thing, but presently doesn’t work due to a completely different xml file layout.
The Color LaserJet MFP M277dw may not auto-discover correctly.
It’s all good man. The DeskJet support has been added, however that Wide Format printer seems to have a completely different layout in the XML file so I will have to spend some time tomorrow working on it. This is very interesting as its the first case so far out of 12 printer models that I’ve come across that has a completely different layout.
MDAR
January 18, 2019, 12:11pm
88
That’s all excellent news. Thanks.
If you need any more information, or even remote access to the Web Interface, please let me know.
Chrishab
(Christian)
January 18, 2019, 8:50pm
89
Nice, just updated to test the LaserJet 200 and it worked perfectly! Thank you!
baeron25
(Christian)
January 19, 2019, 9:13am
90
Hi Cossey,
thank you for this useful new binding!
I have an Officejet Pro X476dw MFP, would it be able to support that?
The connection to the EWS is https: (but http: seems to work, too)
ProductUsageDyn.xml:
THIS DATA SUBJECT TO DISCLAIMER(S) INCLUDED WITH THE PRODUCT OF ORIGIN.
<pudyn:ProductUsageDyn xmlns:dd="http://www.hp.com/schemas/imaging/con/dictionaries/1.0/" xmlns:dd2="http://www.hp.com/schemas/imaging/con/dictionaries/2008/10/10" xmlns:pudyn="http://www.hp.com/schemas/imaging/con/ledm/productusagedyn/2007/12/11" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.hp.com/schemas/imaging/con/ledm/productusagedyn/2007/12/11 ../schemas/ProductUsageDyn.xsd">
<dd:Version>
<dd:Revision>SVN-IPG-LEDM.119</dd:Revision>
<dd:Date>2010-08-31</dd:Date>
</dd:Version>
<pudyn:PrinterSubunit>
<dd:TotalImpressions PEID="5082">2887</dd:TotalImpressions>
<dd:MonochromeImpressions>1010</dd:MonochromeImpressions>
<dd:ColorImpressions>1860</dd:ColorImpressions>
<dd:A4EquivalentImpressions>
<dd:TotalImpressions>2870.0</dd:TotalImpressions>
<dd:MonochromeImpressions>1010.0</dd:MonochromeImpressions>
<dd:ColorImpressions>1860.0</dd:ColorImpressions>
</dd:A4EquivalentImpressions>
<dd:SimplexSheets>2754</dd:SimplexSheets>
<dd:DuplexSheets PEID="5021">62</dd:DuplexSheets>
<dd:JamEvents PEID="16076">2</dd:JamEvents>
<dd:MispickEvents>63</dd:MispickEvents>
<dd:PCL6Impressions>
<dd:TotalImpressions>2708</dd:TotalImpressions>
<dd:MonochromeImpressions>607</dd:MonochromeImpressions>
<dd:ColorImpressions>2101</dd:ColorImpressions>
</dd:PCL6Impressions>
<dd:PCL5Impressions>
<dd:TotalImpressions>0</dd:TotalImpressions>
<dd:MonochromeImpressions>0</dd:MonochromeImpressions>
<dd:ColorImpressions>0</dd:ColorImpressions>
</dd:PCL5Impressions>
<dd:PostScriptImpressions>
<dd:TotalImpressions>15</dd:TotalImpressions>
<dd:MonochromeImpressions>1</dd:MonochromeImpressions>
<dd:ColorImpressions>14</dd:ColorImpressions>
</dd:PostScriptImpressions>
<dd:TotalFrontPanelCancelPresses PEID="30033">26</dd:TotalFrontPanelCancelPresses>
<pudyn:UsageByMarkingAgent>
<dd2:CumulativeMarkingAgentUsed PEID="64100">
<dd:ValueFloat>432</dd:ValueFloat>
<dd:Unit>milliliters</dd:Unit>
</dd2:CumulativeMarkingAgentUsed>
<dd2:CumulativeHPMarkingAgentUsed PEID="64101">
</dd2:CumulativeHPMarkingAgentUsed>
<dd:CumulativeHPMarkingAgentInserted PEID="64001">
<dd:ValueFloat>775</dd:ValueFloat>
</dd:CumulativeHPMarkingAgentInserted>
</pudyn:UsageByMarkingAgent>
<pudyn:UsageByMedia>
<dd:TotalImpressions>1</dd:TotalImpressions>
<dd:ColorImpressions>1</dd:ColorImpressions>
<dd:DuplexSheets>0</dd:DuplexSheets>
<dd:MediaSizeName>na_letter_8.5x11in</dd:MediaSizeName>
</pudyn:UsageByMedia>
<dd:MediaSizeName>na_legal_8.5x14in</dd:MediaSizeName>
<dd:MediaSizeName>na_executive_7.25x10.5in</dd:MediaSizeName>
<dd:MediaSizeName>na_invoice_5.5x8.5in</dd:MediaSizeName>
<dd:MediaSizeName>na_index-3x5_3x5in</dd:MediaSizeName>
<dd:MediaSizeName>na_index-4x6_4x6in</dd:MediaSizeName>
<dd:TotalImpressions PEID="5083">0</dd:TotalImpressions>
<dd:MediaSizeName>unknownenvelope</dd:MediaSizeName>
<dd:MediaSizeName>na_5x7_5x7in</dd:MediaSizeName>
<dd:MediaSizeName>na_index-5x8_5x8in</dd:MediaSizeName>
<dd:TotalImpressions>2869</dd:TotalImpressions>
<dd:ColorImpressions>1859</dd:ColorImpressions>
<dd:DuplexSheets>62</dd:DuplexSheets>
<dd:MediaSizeName>iso_a4_210x297mm</dd:MediaSizeName>
<dd:MediaSizeName>iso_a5_148x210mm</dd:MediaSizeName>
<dd:MediaSizeName>iso_a6_105x148mm</dd:MediaSizeName>
<dd:TotalImpressions PEID="5085">0</dd:TotalImpressions>
<dd:MediaSizeName>5x7</dd:MediaSizeName>
<dd:MediaSizeName>om_small-photo_100x150mm</dd:MediaSizeName>
<dd:MediaSizeName>prc_16k_195x270mm</dd:MediaSizeName>
<dd:MediaSizeName>prc_16k_184x260mm</dd:MediaSizeName>
<dd:MediaSizeName>prc_16k_197x273mm</dd:MediaSizeName>
<dd:MediaSizeName>jpn_hagaki_100x148mm</dd:MediaSizeName>
<dd:MediaSizeName>jpn_oufuku-rot_148x200mm</dd:MediaSizeName>
<dd:MediaSizeName>om_photo_89x127mm</dd:MediaSizeName>
<dd:MediaSizeName>na_number-10_4.125x9.5in</dd:MediaSizeName>
<dd:MediaSizeName>na_monarch_3.875x7.5in</dd:MediaSizeName>
<dd:MediaSizeName>iso_b5_envelope_176x250mm</dd:MediaSizeName>
<dd:MediaSizeName>iso_c5_162x229mm</dd:MediaSizeName>
<dd:MediaSizeName>iso_c6_114x162mm</dd:MediaSizeName>
<dd:MediaSizeName>iso_dl_110x220mm</dd:MediaSizeName>
<dd:MediaSizeName>jpn_chou3_120x235mm</dd:MediaSizeName>
<dd:MediaSizeName>jpn_chou4_90x205mm</dd:MediaSizeName>
<dd:MediaSizeName>jis_b5_182x257mm</dd:MediaSizeName>
<dd:MediaSizeName>jis_b6_128x182mm</dd:MediaSizeName>
<dd:MediaSizeName>na_foolscap_8.5x13in</dd:MediaSizeName>
<dd:MediaSizeName>na_legal_216x340mm</dd:MediaSizeName>
<dd:MediaSizeName>custom</dd:MediaSizeName>
<dd:TotalImpressions PEID="5087">2887</dd:TotalImpressions>
<dd:MediaSizeName>a4_or_letter</dd:MediaSizeName>
<dd:TotalImpressions PEID="5084">0</dd:TotalImpressions>
<dd:MediaSizeName>4x6</dd:MediaSizeName>
<pudyn:UsageByMediaType>
<dd:TotalImpressions PEID="5003">2885</dd:TotalImpressions>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5048">702</dd:TotalImpressions>
<dd:PagesPerJob>one</dd:PagesPerJob>
</dd:UsageByJobSize>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5049">212</dd:TotalImpressions>
<dd:PagesPerJob>two</dd:PagesPerJob>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5050">162</dd:TotalImpressions>
<dd:PagesPerJob>threeToFive</dd:PagesPerJob>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5051">48</dd:TotalImpressions>
<dd:PagesPerJob>sixToTen</dd:PagesPerJob>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5052">47</dd:TotalImpressions>
<dd:PagesPerJob>greaterThanTen</dd:PagesPerJob>
<dd:UsageByQuality>
<dd:NormalImpressions PEID="5041">2882</dd:NormalImpressions>
<dd:DraftImpressions PEID="5042">0</dd:DraftImpressions>
<dd:BetterImpressions PEID="5043">3</dd:BetterImpressions>
</dd:UsageByQuality>
<dd:MediaType>plain</dd:MediaType>
</pudyn:UsageByMediaType>
<dd:TotalImpressions PEID="5004">0</dd:TotalImpressions>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5053">0</dd:TotalImpressions>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5054">0</dd:TotalImpressions>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5055">0</dd:TotalImpressions>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5056">0</dd:TotalImpressions>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5057">0</dd:TotalImpressions>
<dd:UsageByQuality>
<dd:NormalImpressions PEID="5044">0</dd:NormalImpressions>
<dd:BetterImpressions PEID="5046">0</dd:BetterImpressions>
<dd:BestImpressions PEID="5092">0</dd:BestImpressions>
<dd:MediaType>HPAdvancedPhoto</dd:MediaType>
<dd:UsageByTimeInterval>
<dd:JobCount PEID="39000">553</dd:JobCount>
<dd:JobDuration>lessthanTwoMinutes</dd:JobDuration>
</dd:UsageByTimeInterval>
<dd:JobCount PEID="39001">43</dd:JobCount>
<dd:JobDuration>twoToFiveMinutes</dd:JobDuration>
<dd:JobCount PEID="39002">115</dd:JobCount>
<dd:JobDuration>fiveToThirtyMinutes</dd:JobDuration>
<dd:JobCount PEID="39003">33</dd:JobCount>
<dd:JobDuration>thirtyToSixtyMinutes</dd:JobDuration>
<dd:JobCount PEID="39004">1234</dd:JobCount>
<dd:JobDuration>oneToSixHours</dd:JobDuration>
<dd:JobCount PEID="39005">1830</dd:JobCount>
<dd:JobDuration>sixHoursToOneDay</dd:JobDuration>
<dd:JobCount PEID="39006">2808</dd:JobCount>
<dd:JobDuration>oneToThreeDays</dd:JobDuration>
<dd:JobCount PEID="39007">2531</dd:JobCount>
<dd:JobDuration>threeToSevenDays</dd:JobDuration>
<dd:JobCount PEID="39008">465</dd:JobCount>
<dd:JobDuration>sevenDaysToOneMonth</dd:JobDuration>
<dd:JobCount PEID="39009">2</dd:JobCount>
<dd:JobDuration>oneToThreeMonths</dd:JobDuration>
<pudyn:UsageByCoverage>
<dd:IHM_PlainNormalBest PEID="5071">131</dd:IHM_PlainNormalBest>
<dd:IHM_1to9PagesPerJob_Brochure PEID="5076">0</dd:IHM_1to9PagesPerJob_Brochure>
<dd:IHM_10to49PagesPerJob_Brochure PEID="5077">0</dd:IHM_10to49PagesPerJob_Brochure>
<dd:IHM_GT49PagesPerJob_Brochure PEID="5078">0</dd:IHM_GT49PagesPerJob_Brochure>
<dd:CoverageType>greaterThanThirtyPercentCoverage</dd:CoverageType>
</pudyn:UsageByCoverage>
<dd:IHM_PlainNormalBest PEID="5072">327</dd:IHM_PlainNormalBest>
<dd:IHM_1to9PagesPerJob_Brochure PEID="5073">0</dd:IHM_1to9PagesPerJob_Brochure>
<dd:IHM_10to49PagesPerJob_Brochure PEID="5074">0</dd:IHM_10to49PagesPerJob_Brochure>
<dd:IHM_GT49PagesPerJob_Brochure PEID="5075">0</dd:IHM_GT49PagesPerJob_Brochure>
<dd:CoverageType>lessThanThirtyPercentCoverage</dd:CoverageType>
<dd:IHM_BrochureDuplexed PEID="5081">0</dd:IHM_BrochureDuplexed>
<dd:IHM_PlainDuplexed PEID="5080">10</dd:IHM_PlainDuplexed>
<pudyn:UIButtonPressCounters>
<dd:ButtonPressCount PEID="30039">136</dd:ButtonPressCount>
<dd:ButtonPressOptions>startScanButtonPress</dd:ButtonPressOptions>
</pudyn:UIButtonPressCounters>
<pudyn:UsageByTrayAndMedia>
<dd:TotalImpressions PEID="5089">0</dd:TotalImpressions>
<dd:InputBin>Tray1</dd:InputBin>
</pudyn:UsageByTrayAndMedia>
<dd:TotalImpressions PEID="5090">0</dd:TotalImpressions>
<dd:TotalImpressions PEID="5091">0</dd:TotalImpressions>
<dd:TotalImpressions PEID="5029">0</dd:TotalImpressions>
<dd:MediaSizeName>any</dd:MediaSizeName>
<dd:InputBin>Tray2</dd:InputBin>
<dd:EWSAccessCount PEID="16081">26</dd:EWSAccessCount>
<dd:NetworkImpressions PEID="25000">2609</dd:NetworkImpressions>
<dd:WirelessNetworkImpressions PEID="25002">0</dd:WirelessNetworkImpressions>
<pudyn:UserRequestedPrime PEID="40008">0</pudyn:UserRequestedPrime>
<pudyn:SubscriptionImpressions>0</pudyn:SubscriptionImpressions>
</pudyn:PrinterSubunit>
<pudyn:ConsumableSubunit>
<pudyn:Consumable>
<dd:MarkerColor>Yellow</dd:MarkerColor>
<dd:ConsumableTypeEnum>ink</dd:ConsumableTypeEnum>
<dd2:CumulativeConsumableCount>2</dd2:CumulativeConsumableCount>
<dd:ConsumableState>ok</dd:ConsumableState>
<dd:ConsumableRawPercentageLevelRemaining>93</dd:ConsumableRawPercentageLevelRemaining>
<dd:SupplyRegion PEID="64306">1</dd:SupplyRegion>
<dd:SupplyFillLevel PEID="64307">1074</dd:SupplyFillLevel>
<dd:SupplyFamilyNumber PEID="64308">29</dd:SupplyFamilyNumber>
<dd:SupplyModelNumber PEID="64309">1</dd:SupplyModelNumber>
<dd:SupplySerialNumber PEID="64310">538199646</dd:SupplySerialNumber>
<dd:SupplyStatusBits PEID="64311">805372160</dd:SupplyStatusBits>
<dd:SupplyRefilledStateCounter PEID="28008">0</dd:SupplyRefilledStateCounter>
<dd:PVPCartridgeCounter PEID="28027">0</dd:PVPCartridgeCounter>
<dd:PrimeEventCounter PEID="40014">0</dd:PrimeEventCounter>
<dd:PrimeEventLevel0Counter PEID="40005">26</dd:PrimeEventLevel0Counter>
<dd:PrimeEventLevel1Counter PEID="40006">0</dd:PrimeEventLevel1Counter>
<dd:PrimeEventLevel2Counter PEID="40007">0</dd:PrimeEventLevel2Counter>
<dd:UsageByMarkingAgentCount>
<dd:MarkingAgentCount PEID="11024">11695946</dd:MarkingAgentCount>
<dd:MarkingAgentCountType>HPDropsCount</dd:MarkingAgentCountType>
</dd:UsageByMarkingAgentCount>
<dd:MarkingAgentCount PEID="11032">9316769</dd:MarkingAgentCount>
<dd:MarkingAgentCountType>serviceDropsCount</dd:MarkingAgentCountType>
<dd:RefilledCount>
<dd:CounterfeitRefilledCount PEID="16086">0</dd:CounterfeitRefilledCount>
<dd:GenuineRefilledCount>0</dd:GenuineRefilledCount>
</dd:RefilledCount>
<dd:PenInsertionTriggerSnapshotCounter PEID="28031">7</dd:PenInsertionTriggerSnapshotCounter>
</pudyn:Consumable>
<pudyn:Consumable>
<dd:MarkerColor>Cyan</dd:MarkerColor>
<dd2:CumulativeConsumableCount>1</dd2:CumulativeConsumableCount>
<dd:ConsumableState>low</dd:ConsumableState>
<dd:ConsumableRawPercentageLevelRemaining>2</dd:ConsumableRawPercentageLevelRemaining>
<dd:SupplyRegion PEID="64318">1</dd:SupplyRegion>
<dd:SupplyFillLevel PEID="64319">1074</dd:SupplyFillLevel>
<dd:SupplyFamilyNumber PEID="64320">29</dd:SupplyFamilyNumber>
<dd:SupplyModelNumber PEID="64321">1</dd:SupplyModelNumber>
<dd:SupplySerialNumber PEID="64322">272133477</dd:SupplySerialNumber>
<dd:SupplyStatusBits PEID="64323">65792</dd:SupplyStatusBits>
<dd:SupplyRefilledStateCounter PEID="28006">0</dd:SupplyRefilledStateCounter>
<dd:PVPCartridgeCounter PEID="28025">0</dd:PVPCartridgeCounter>
<dd:PrimeEventCounter PEID="40013">0</dd:PrimeEventCounter>
<dd:MarkingAgentCount PEID="11022">12469792</dd:MarkingAgentCount>
<dd:MarkingAgentCount PEID="11030">10691756</dd:MarkingAgentCount>
<dd:RefilledCount>
</dd:RefilledCount>
</pudyn:Consumable>
<pudyn:Consumable>
<dd:MarkerColor>Magenta</dd:MarkerColor>
<dd:SupplyRegion PEID="64330">1</dd:SupplyRegion>
<dd:SupplyFillLevel PEID="64331">990</dd:SupplyFillLevel>
<dd:SupplyFamilyNumber PEID="64332">29</dd:SupplyFamilyNumber>
<dd:SupplyModelNumber PEID="64333">1</dd:SupplyModelNumber>
<dd:SupplySerialNumber PEID="64334">271982683</dd:SupplySerialNumber>
<dd:SupplyStatusBits PEID="64335">65792</dd:SupplyStatusBits>
<dd:SupplyRefilledStateCounter PEID="28007">0</dd:SupplyRefilledStateCounter>
<dd:PVPCartridgeCounter PEID="28026">0</dd:PVPCartridgeCounter>
<dd:PrimeEventCounter PEID="40012">0</dd:PrimeEventCounter>
<dd:MarkingAgentCount PEID="11023">11640027</dd:MarkingAgentCount>
<dd:MarkingAgentCount PEID="11031">10169114</dd:MarkingAgentCount>
<dd:RefilledCount>
</dd:RefilledCount>
</pudyn:Consumable>
<pudyn:Consumable>
<dd:MarkerColor>Black</dd:MarkerColor>
<dd:ConsumableRawPercentageLevelRemaining>84</dd:ConsumableRawPercentageLevelRemaining>
<dd:SupplyRegion PEID="64300">1</dd:SupplyRegion>
<dd:SupplyFillLevel PEID="64301">2284</dd:SupplyFillLevel>
<dd:SupplyFamilyNumber PEID="64302">29</dd:SupplyFamilyNumber>
<dd:SupplyModelNumber PEID="64303">1</dd:SupplyModelNumber>
<dd:SupplySerialNumber PEID="64304">314062133</dd:SupplySerialNumber>
<dd:SupplyStatusBits PEID="64305">805372160</dd:SupplyStatusBits>
<dd:SupplyRefilledStateCounter PEID="28005">0</dd:SupplyRefilledStateCounter>
<dd:PVPCartridgeCounter PEID="28024">0</dd:PVPCartridgeCounter>
<dd:PrimeEventCounter PEID="40011">0</dd:PrimeEventCounter>
<dd:PrimeEventLevel0Counter PEID="40002">3</dd:PrimeEventLevel0Counter>
<dd:PrimeEventLevel1Counter PEID="40003">2</dd:PrimeEventLevel1Counter>
<dd:PrimeEventLevel2Counter PEID="40004">7</dd:PrimeEventLevel2Counter>
<dd:MarkingAgentCount PEID="11021">13005730</dd:MarkingAgentCount>
<dd:MarkingAgentCount PEID="11029">8100467</dd:MarkingAgentCount>
<dd:RefilledCount>
</dd:RefilledCount>
</pudyn:Consumable>
</pudyn:ConsumableSubunit>
<pudyn:ScannerEngineSubunit>
<dd:ScanImages PEID="6000">568</dd:ScanImages>
<pudyn:UsageByScanMediaSize>
<dd:ScanMediaSize>any</dd:ScanMediaSize>
</pudyn:UsageByScanMediaSize>
<dd:AdfImages PEID="6011">296</dd:AdfImages>
<dd:DuplexSheets PEID="6015">18</dd:DuplexSheets>
<dd:FlatbedImages>180</dd:FlatbedImages>
<dd:JamEvents>5</dd:JamEvents>
<dd:MispickEvents>2</dd:MispickEvents>
<dd:ScanToCardCount PEID="6010">8</dd:ScanToCardCount>
<pudyn:UsageByADF>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="6016">65</dd:TotalImpressions>
<dd:PagesPerJob>oneToTen</dd:PagesPerJob>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="6017">7</dd:TotalImpressions>
<dd:PagesPerJob>elevenToTwenty</dd:PagesPerJob>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="6018">1</dd:TotalImpressions>
<dd:PagesPerJob>twentyOneToThirty</dd:PagesPerJob>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="6019">0</dd:TotalImpressions>
<dd:PagesPerJob>greaterThanThirtyfive</dd:PagesPerJob>
</pudyn:UsageByADF>
</pudyn:ScannerEngineSubunit>
<pudyn:MassStorageSubunit>
<dd:TotalImpressions PEID="18018">1</dd:TotalImpressions>
<dd:MemoryDevicesInserted PEID="23017">2</dd:MemoryDevicesInserted>
<pudyn:UsageByPhotocard>
<dd:TotalImpressions PEID="18003">0</dd:TotalImpressions>
<dd:PhotoCardType>4x6Impressions </dd:PhotoCardType>
</pudyn:UsageByPhotocard>
<dd:PhotoCardType>4x6MetricEquivalentImpressions</dd:PhotoCardType>
<dd:TotalImpressions PEID="18004">0</dd:TotalImpressions>
<dd:PhotoCardType>5x7Impressions</dd:PhotoCardType>
<dd:PhotoCardType>5x7MetricEquivalentImpressions</dd:PhotoCardType>
<dd:TotalImpressions PEID="18006">0</dd:TotalImpressions>
<dd:PhotoCardType>8x10Or8.5x11orA4Impressions</dd:PhotoCardType>
<dd:PhotoCardType>8x10Or8.5x11orA4MetricEquivalentImpressions</dd:PhotoCardType>
<dd:PhotoCardType>albumImpressions</dd:PhotoCardType>
<dd:PhotoCardType>clipArtImpressions</dd:PhotoCardType>
<dd:PhotoCardType>3UpLayoutImpressions</dd:PhotoCardType>
<dd:PhotoCardType>designImpressions</dd:PhotoCardType>
<dd:PhotoCardType>frameImpressions</dd:PhotoCardType>
</pudyn:MassStorageSubunit>
<pudyn:CopyApplicationSubunit>
<dd:TotalImpressions PEID="3019">82</dd:TotalImpressions>
<dd:ColorImpressions>15</dd:ColorImpressions>
<dd:MonochromeImpressions>67</dd:MonochromeImpressions>
<dd:AdfImages>43</dd:AdfImages>
<dd:FlatbedImages>26</dd:FlatbedImages>
</pudyn:CopyApplicationSubunit>
<pudyn:ScanApplicationSubunit>
<dd:AdfImages>29</dd:AdfImages>
<dd:FlatbedImages>62</dd:FlatbedImages>
<dd:ImagesSentToEmail PEID="6014">5</dd:ImagesSentToEmail>
<dd:ImagesSentToFolder PEID="6013">279</dd:ImagesSentToFolder>
<dd:ScanToHostImages PEID="6001">91</dd:ScanToHostImages>
</pudyn:ScanApplicationSubunit>
<pudyn:FaxApplicationSubunit>
<dd:TotalImpressions PEID="4016">0</dd:TotalImpressions>
<dd:AdfImages>0</dd:AdfImages>
<dd:FlatbedImages>0</dd:FlatbedImages>
<dd:ImagesSentToPC PEID="4012">0</dd:ImagesSentToPC>
<dd:ImagesReceivedFromPC>0</dd:ImagesReceivedFromPC>
<dd:TotalReceivedImages PEID="4007">0</dd:TotalReceivedImages>
<dd:ImagesSentToEmail PEID="4015">0</dd:ImagesSentToEmail>
<dd:ImagesSentToFolder PEID="4014">0</dd:ImagesSentToFolder>
<dd:TotalImagesSent PEID="4011">0</dd:TotalImagesSent>
</pudyn:FaxApplicationSubunit>
<pudyn:PrintApplicationSubunit>
<dd:TotalImpressions PEID="7009">2802</dd:TotalImpressions>
<dd:PhotoImpressions PEID="7002">0</dd:PhotoImpressions>
<dd:MediaSize_4x6in_10x15cm_Impressions PEID="7006">0</dd:MediaSize_4x6in_10x15cm_Impressions>
<dd:IHMPrintViewImpressions PEID="5079">0</dd:IHMPrintViewImpressions>
<dd:CloudPrintImpressions PEID="36016">2</dd:CloudPrintImpressions>
</pudyn:PrintApplicationSubunit>
<pudyn:PonyExpressSubunit>
<pudyn:PECounter PEID="5000">2901</pudyn:PECounter>
<pudyn:PECounter PEID="5088">53</pudyn:PECounter>
<pudyn:PECounter PEID="5033">0</pudyn:PECounter>
<pudyn:PECounter PEID="4013">0</pudyn:PECounter>
<pudyn:PECounter PEID="5031">0</pudyn:PECounter>
<pudyn:PECounter PEID="5032">0</pudyn:PECounter>
<pudyn:PECounter PEID="5037">2887</pudyn:PECounter>
<pudyn:PECounter PEID="5011">0</pudyn:PECounter>
<pudyn:PECounter PEID="3001">67</pudyn:PECounter>
</pudyn:PonyExpressSubunit>
<pudyn:MobileApplicationSubunit>
<pudyn:TotalUsage>
<pudyn:Counter>
<pudyn:TotalImpressions>0</pudyn:TotalImpressions>
</pudyn:Counter>
<pudyn:RemoteDeviceType>Windows</pudyn:RemoteDeviceType>
<pudyn:DriverType>ePrint</pudyn:DriverType>
</pudyn:TotalUsage>
<pudyn:TotalUsage>
<pudyn:Counter>
</pudyn:Counter>
<pudyn:DriverType>inOS</pudyn:DriverType>
</pudyn:TotalUsage>
<pudyn:TotalUsage>
<pudyn:Counter>
</pudyn:Counter>
<pudyn:DriverType>discrete</pudyn:DriverType>
</pudyn:TotalUsage>
<pudyn:TotalUsage>
<pudyn:Counter>
<pudyn:TotalImpressions>7</pudyn:TotalImpressions>
</pudyn:Counter>
<pudyn:DriverType>UniversalPrintDriver</pudyn:DriverType>
</pudyn:TotalUsage>
<pudyn:TotalUsage>
<pudyn:Counter>
</pudyn:Counter>
<pudyn:RemoteDeviceType>OSX</pudyn:RemoteDeviceType>
</pudyn:TotalUsage>
<pudyn:TotalUsage>
<pudyn:Counter>
</pudyn:Counter>
<pudyn:RemoteDeviceType>samsung</pudyn:RemoteDeviceType>
</pudyn:TotalUsage>
<pudyn:DocumentUsage>
<pudyn:Counter>
</pudyn:Counter>
</pudyn:DocumentUsage>
<pudyn:Counter>
<pudyn:TotalImpressions>68</pudyn:TotalImpressions>
</pudyn:Counter>
<pudyn:RemoteDeviceType>iOS</pudyn:RemoteDeviceType>
<pudyn:Counter>
</pudyn:Counter>
<pudyn:RemoteDeviceType>Android</pudyn:RemoteDeviceType>
<pudyn:PhotoUsage>
<pudyn:Counter>
</pudyn:Counter>
</pudyn:PhotoUsage>
<pudyn:PhotoUsage>
<pudyn:Counter>
<pudyn:TotalImpressions>1</pudyn:TotalImpressions>
</pudyn:Counter>
</pudyn:PhotoUsage>
<pudyn:PhotoUsage>
<pudyn:Counter>
</pudyn:Counter>
</pudyn:PhotoUsage>
</pudyn:MobileApplicationSubunit>
</pudyn:ProductUsageDyn>
ProductStatusDyn.xml:
<psdyn:ProductStatusDyn xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:dd="http://www.hp.com/schemas/imaging/con/dictionaries/1.0/" xmlns:ad="http://www.hp.com/schemas/imaging/con/ledm/alertdetails/2007/10/31" xmlns:pscat="http://www.hp.com/schemas/imaging/con/ledm/productstatuscategories/2007/10/31" xmlns:locid="http://www.hp.com/schemas/imaging/con/ledm/localizationids/2007/10/31" xmlns:psdyn="http://www.hp.com/schemas/imaging/con/ledm/productstatusdyn/2007/10/31" xsi:schemaLocation="http://www.hp.com/schemas/imaging/con/dictionaries/1.0/ ../schemas/dd/DataDictionaryMasterLEDM.xsd http://www.hp.com/schemas/imaging/con/ledm/alertdetails/2007/10/31 ../schemas/AlertDetails.xsd http://www.hp.com/schemas/imaging/con/ledm/productstatuscategories/2007/10/31 ../schemas/ProductStatusCategories.xsd http://www.hp.com/schemas/imaging/con/ledm/localizationids/2007/10/31 ../schemas/LocalizationIds.xsd http://www.hp.com/schemas/imaging/con/ledm/productstatusdyn/2007/10/31 ../schemas/ProductStatusDyn.xsd">
<dd:Version>
<dd:Revision>SVN-IPG-LEDM.216</dd:Revision>
<dd:Date>2011-02-08</dd:Date>
</dd:Version>
<psdyn:Status>
<pscat:StatusCategory>genuineHP</pscat:StatusCategory>
<locid:StringId>65561</locid:StringId>
</psdyn:Status>
<psdyn:Status>
<pscat:StatusCategory>inPowerSave</pscat:StatusCategory>
<locid:StringId>65640</locid:StringId>
</psdyn:Status>
<psdyn:AlertTable>
<dd:ModificationNumber>18</dd:ModificationNumber>
<psdyn:Alert>
<ad:ProductStatusAlertID>genuineHP</ad:ProductStatusAlertID>
<dd:SequenceNumber>1</dd:SequenceNumber>
<ad:Severity>Info</ad:Severity>
<ad:AlertPriority>399</ad:AlertPriority>
<ad:AlertDetails>
<ad:AlertDetailsMarkerColor>Yellow</ad:AlertDetailsMarkerColor>
<ad:AlertDetailsConsumableTypeEnum>ink</ad:AlertDetailsConsumableTypeEnum>
<ad:AlertDetailsMarkerLocation>1</ad:AlertDetailsMarkerLocation>
<ad:AlertDetailsUserAction>acknowledgeConsumableState</ad:AlertDetailsUserAction>
</ad:AlertDetails>
<dd:ResourceURI>/DevMgmt/ConsumableConfigDyn.xml</dd:ResourceURI>
<dd:ResourceType>ledm:hpLedmConsumableConfigDyn</dd:ResourceType>
</psdyn:Alert>
<psdyn:Alert>
<dd:SequenceNumber>2</dd:SequenceNumber>
<ad:AlertDetails>
<ad:AlertDetailsMarkerColor>Black</ad:AlertDetailsMarkerColor>
<ad:AlertDetailsMarkerLocation>4</ad:AlertDetailsMarkerLocation>
</ad:AlertDetails>
</psdyn:Alert>
</psdyn:AlertTable>
</psdyn:ProductStatusDyn>
vzorglub
(Vincent Regaud)
January 19, 2019, 9:17am
91
Your productstatust.xml has not copied in properly, can you try again.
I also think that @Cossey would prefer it posted on the github too:
MDAR
January 19, 2019, 9:23am
92
@baeron25
Does this information help you ?
baeron25
(Christian)
January 19, 2019, 11:41am
93
Yes, thank you, didn’t realise that!
I saved the 2 files for the HP Officejet Pro X476dw MFP again.
ProductUsageDyn.xml (35.4 KB)
ProductStatusDyn.xml (3.1 KB)
Cossey
(Stewart Cossey)
January 19, 2019, 12:39pm
94
New Update!
Support for OfficeJet 7500 E910
Support for OfficeJet X476DW MFP
I’ve now added support for your printer.
@MDAR That wide format printer is now supported. I noticed that the xml was different, however for the data points currently supported it was mostly the same, but did notice the printheads also appear to be listed under the consumables section in the xml. You may need to assist with one more thing, when testing it may not auto-discover the device correctly (this depends on how the device is named but the log should output when it detects an unsupported device and log the name). Also, thanks for assisting Christian.
Thanks for being helpful and assisting others in this thread, helps speed things up and makes it easier for me!
MDAR
January 20, 2019, 8:49pm
95
Hi
Nether of the printers here auto detected, but that’s nothing new for me, sometimes things don’t respond to pings.
I’m not entirely sure it’s not something to do with the FritzBox.
However, manually adding the OfficeJet 7500 A3 printer works perfectly
The Deskjet 3520 was added manually too and seems very happy.
Thanks for all your hard work
Cossey
(Stewart Cossey)
January 21, 2019, 7:00am
96
Hey Stuart,
Just for your information regarding how auto-discovery works, I detect the HP devices using Apple Bonjour/Multicast DNS. It only works within a single broadcast domain. This detection capability is built into openHAB and I looked at the source code of the auto-detection section in the IPP Binding for how to implement this functionality in my Binding.
It may be that the printers themselves have Bonjour/AirPrint service disabled which means that it may not be detected over network - if you have a Windows based machine, you could try and install the Bonjour service (provided by Apple and installs alongside iTunes) and then try an application like Bonjour Browser for Windows to see if your computer can detect the printers over network. It may be that your FritzBox has issues with Multicast DNS or messes with it in some way. I would expect AirPrint would not work either (if supported).
MDAR
January 21, 2019, 7:38am
97
Oh I see…
That explains it perfectly
We’re an apple free house, so I’ve got no way to know if they reveal themselves anyway.
baeron25
(Christian)
January 21, 2019, 7:58am
98
Thanks for your work! All values for my printer are pulled. Auto-Discovery did not work (Bonjour / Airprint is activated, but I changed the printer name for Bonjour from the default to a custom name). After adding the printer manually everything was fine.
Cossey
(Stewart Cossey)
January 22, 2019, 2:32am
99
Hello all,
I just wanted to give everyone here an update regarding this Binding. I feel that the Binding is almost at the state that it should soon be ready to open a Pull Request in the Official openhab addons repository and get it merged as an Official addon (if the maintainer team accepts it).
I do have a question to ask you all however, @heilbron came across a situation when his Ink carts were low which took the Ink level indicator into the negatives (for example, -2%). I want a draw up a consensus from everyone on how to propose the situation should be handled. There are two approaches we could follow:
Keep the negative values as they are when this occurs.
Whenever the carts fall into negative values keep the result as 0% instead of negative.
I’m open to debate as to the best way to handle this situation. This will also help me close the open issue regarding this matter.
Furthermore, I really only have the following left until this is ready for prime time:
Update the Readme file with all the new Things in the recent updates
Get the reboot channel working
Merge the master branch into the binding branch and update the header files and licensing changes made recently. Then try and get the Binding to compile.
Unfortunately with point 3, I’m having issues with the checkstyle in maven searching the HP Printer Binding tools/
folder (which doesn’t exist) for checkstyle_suppressions.xml
file instead of openhab2-addons/tools
folder.
Even with the change of name your printer should auto-detect since you have Bonjour enabled on your printer. Could I ask a favour? Could I please get you to enable DEBUG level logging for the Binding in Karaf and look for the line:
Found HP Printer…
This should then contain maybe 9 or so lines of information, if you could find within this chunk the line of text that starts with ty:
and copy that entire line here then I can update the Binding with this information. The ty:
field is what the Binding checks against to match up the model with the correct Thing in openHAB. In some cases like your printer, it’s not simply the model name but either a subset of the name and some additional letters and numbers in brackets, this is a bit of a problem with the LaserJets that I’ve added support for. That would be much appreciated!
baeron25
(Christian)
January 22, 2019, 6:19pm
100
I tried auto-detection again (deleted the existing thing before that). Unfortunately my printer is not found and I can’t see anything in the log regarding the X 476dw. I have about 20 printers in my network and 2 of them where detected (as unknown HP printer), for example a HP Pagewide 586dw. But I can use Airprint on all of them.
Found HP Printer [ServiceInfoImpl@1683660 name: 'bjr-hp586pw-01._universal._sub._printer._tcp.local.' address: '/192.168.68.55:515 /fe80:xxx ' status: 'NO DNS state: probing 1 task: null' is persistent, has data
UUID: a9be9b68-f7b7-11e5-a970-476162108cc2
Transparent: T
product: (HP PageWide Color MFP 586)
note:
usb_MFG: Hewlett-Packard
Duplex: T
Fax: F
adminurl: http://prt-hp586pw-01.local/airprint_mob_status.htm
usb_MDL: HP PageWide Color MFP 586
rp: BINPS
URF: V1.4,CP99,RS600,MT1-2-3-5-12,W8,PQ4,SRGB24,IS20-21-22,IFU21-22,DM1,OB10
Binary: T
txtvers: 1
pdl: application/postscript,application/PCLm
Scan: T
qtotal: 4
priority: 40
ty: HP PageWide Color MFP 586
Color: T]
2019-01-22 19:05:24.917 [DEBUG] [covery.HPPrinterDiscoveryParticipant] - findThingType
2019-01-22 19:05:24.919 [DEBUG] [covery.HPPrinterDiscoveryParticipant] - types _printer._tcp.local. vs PageWideColorMFP586
2019-01-22 19:05:24.921 [DEBUG] [covery.HPPrinterDiscoveryParticipant] - Created a DiscoveryResult discoveryResult [thingUID=hpprinter:generictype1:bjr_hp586pw_01, properties={ipAddress=192.168.68.55}, representationProperty=null, flag=NEW, label=bjr-hp586pw-01, bridgeUID=null, ttl=-1, timestamp=1548180324921] for printer on host '192.168.68.55' name 'bjr-hp586pw-01'
