Chrishab
(Christian)
August 12, 2019, 8:45am
121
Got it working now.
I had to restart openHAB (2.5 snapshot) and delete the old printer to make it work.
Before the restart the system would still show the old printer definitions when adding new items manually.
Autodiscovery still does not work for my printer though.
All details are pulled from the printer correctly. Thank you!
Cossey
(Stewart Cossey)
August 12, 2019, 8:56am
122
Did auto-discovery work for you or did you manually add the Thing?
If you could share me your http://<PrinterIP>/DevMgmt/ProductUsageDyn.xml
file ill take a look and see if there might be something odd about the file - it could be possible that it maybe a bug.
If you are using Paper UI, did you try Shift+Refresh
ing the page?
Thanks for confirming that this appears to work in openHAB 2.4
higgers
(Steve Higton)
August 12, 2019, 11:12am
123
I dropped the jar into the addons directory of my 2.4 system and then logged into the console to check that the bundle was loaded and active, which it was.
Auto-discovery didnāt work so I manually added a thing via the Paper UI, left all settings as default and filled in the static IP of the printer. I then created items for the four ink levels and the status and added these to my sitemap. The ink level items are all blank (just shows ā- %ā on the sitemap) but the status seems to work, it was initially āIdleā but then changed to āPrintingā when I printed a test page.
I havenāt got around to enabling debug logging for the addon yet to see if that gives any hints as to why the ink level items arenāt working. Iāll do that later today.
Iāve been following the development of this binding for a while, it looks really good. Thanks for all your efforts!
Cossey
(Stewart Cossey)
August 12, 2019, 12:11pm
124
New Update
Download link: LINK NO LONGER AVAILABLE
Added in additional channels.
Improve usage data check stability.
@suntribe can you try this version and see how it works for you?
@higgers On Binding initialization it checks the Embedded Web Server and dynamically adds the channels supported by your printer. If it doesnāt work ill need to look at your ProductUsageDyn.xml
file. Iāve just figured out how to use the Dynamic Channels so its either something wrong on my end or your usage file may have some additional markup that I need to cater for.
@Chrishab and @higgers
Auto-discovery uses mDNS - is the openHAB Core :: Bundles :: mDNS Service
bundle running? It may need to be installed - I donāt think dropping the binding into the folder installs dependent bundles. I know that the IPP Binding uses mDNS so if you install that binding and try re-scanning for HP Printers it might workā¦?
higgers
(Steve Higton)
August 12, 2019, 1:44pm
125
Hereās the ProductUsageDyn.xml for the printer:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
THIS DATA SUBJECT TO DISCLAIMER(S) INCLUDED WITH THE PRODUCT OF ORIGIN.
<pudyn:ProductUsageDyn xmlns:dd="http://www.hp.com/schemas/imaging/con/dictionaries/1.0/" xmlns:dd2="http://www.hp.com/schemas/imaging/con/dictionaries/2008/10/10" xmlns:pudyn="http://www.hp.com/schemas/imaging/con/ledm/productusagedyn/2007/12/11"xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.hp.com/schemas/imaging/con/ledm/productusagedyn/2007/12/11 ../schemas/ProductUsageDyn.xsd">
<dd:Version>
<dd:Revision>SVN-IPG-LEDM.119</dd:Revision>
<dd:Date>2010-08-31</dd:Date>
</dd:Version>
<pudyn:PrinterSubunit>
<dd:TotalImpressions PEID="5082">13285</dd:TotalImpressions>
<dd:MonochromeImpressions>5217</dd:MonochromeImpressions>
<dd:ColorImpressions>8066</dd:ColorImpressions>
<dd:A4EquivalentImpressions>
<dd:TotalImpressions>13160.8</dd:TotalImpressions>
<dd:MonochromeImpressions>5173.0</dd:MonochromeImpressions>
<dd:ColorImpressions>7987.8</dd:ColorImpressions>
</dd:A4EquivalentImpressions>
<dd:SimplexSheets>12138</dd:SimplexSheets>
<dd:DuplexSheets PEID="5021">622</dd:DuplexSheets>
<dd:JamEvents PEID="16076">0</dd:JamEvents>
<dd:MispickEvents>145</dd:MispickEvents>
<dd:TotalFrontPanelCancelPresses PEID="30033">118</dd:TotalFrontPanelCancelPresses>
<dd:TotalQuickFormsButtonPresses>0</dd:TotalQuickFormsButtonPresses>
<pudyn:UsageByMarkingAgent>
<dd2:CumulativeMarkingAgentUsed PEID="64100">
<dd:ValueFloat>623</dd:ValueFloat>
<dd:Unit>milliliters</dd:Unit>
</dd2:CumulativeMarkingAgentUsed>
<dd2:CumulativeHPMarkingAgentUsed PEID="64101">
</dd2:CumulativeHPMarkingAgentUsed>
<dd:CumulativeHPMarkingAgentInserted PEID="64001">
<dd:ValueFloat>665</dd:ValueFloat>
</dd:CumulativeHPMarkingAgentInserted>
</pudyn:UsageByMarkingAgent>
<pudyn:UsageByMedia>
<dd:TotalImpressions>0</dd:TotalImpressions>
<dd:MonochromeImpressions>0</dd:MonochromeImpressions>
<dd:ColorImpressions>0</dd:ColorImpressions>
<dd:MediaSizeName>na_executive_7.25x10.5in</dd:MediaSizeName>
</pudyn:UsageByMedia>
<dd:TotalImpressions>211</dd:TotalImpressions>
<dd:MonochromeImpressions>80</dd:MonochromeImpressions>
<dd:ColorImpressions>131</dd:ColorImpressions>
<dd:MediaSizeName>na_letter_8.5x11in</dd:MediaSizeName>
<dd:MediaSizeName>na_legal_8.5x14in</dd:MediaSizeName>
<dd:TotalImpressions PEID="5086">0</dd:TotalImpressions>
<dd:MediaSizeName>na_govt-letter_8x10in</dd:MediaSizeName>
<dd:MediaSizeName>na_invoice_5.5x8.5in</dd:MediaSizeName>
<dd:TotalImpressions>89</dd:TotalImpressions>
<dd:MonochromeImpressions>56</dd:MonochromeImpressions>
<dd:ColorImpressions>33</dd:ColorImpressions>
<dd:MediaSizeName>iso_a5_148x210mm</dd:MediaSizeName>
<dd:TotalImpressions>12881</dd:TotalImpressions>
<dd:MonochromeImpressions>5061</dd:MonochromeImpressions>
<dd:ColorImpressions>7820</dd:ColorImpressions>
<dd:MediaSizeName>iso_a4_210x297mm</dd:MediaSizeName>
<dd:MediaSizeName>jis_b5_182x257mm</dd:MediaSizeName>
<dd:MediaSizeName>jpn_hagaki_100x148mm</dd:MediaSizeName>
<dd:TotalImpressions>12</dd:TotalImpressions>
<dd:MonochromeImpressions>1</dd:MonochromeImpressions>
<dd:ColorImpressions>11</dd:ColorImpressions>
<dd:MediaSizeName>iso_a6_105x148mm</dd:MediaSizeName>
<dd:TotalImpressions>36</dd:TotalImpressions>
<dd:ColorImpressions>36</dd:ColorImpressions>
<dd:MediaSizeName>na_index-4x6_4x6in</dd:MediaSizeName>
<dd:MediaSizeName>na_index-5x8_5x8in</dd:MediaSizeName>
<dd:TotalImpressions>48</dd:TotalImpressions>
<dd:MonochromeImpressions>19</dd:MonochromeImpressions>
<dd:ColorImpressions>29</dd:ColorImpressions>
<dd:MediaSizeName>na_index-3x5_3x5in</dd:MediaSizeName>
<dd:MediaSizeName>na_monarch_3.875x7.5in</dd:MediaSizeName>
<dd:MediaSizeName>na_number-10_4.125x9.5in</dd:MediaSizeName>
<dd:MediaSizeName>iso_dl_110x220mm</dd:MediaSizeName>
<dd:MediaSizeName>iso_c5_162x229mm</dd:MediaSizeName>
<dd:TotalImpressions>1</dd:TotalImpressions>
<dd:ColorImpressions>1</dd:ColorImpressions>
<dd:MediaSizeName>iso_c6_114x162mm</dd:MediaSizeName>
<dd:MediaSizeName>na_a2_4.375x5.75in</dd:MediaSizeName>
<dd:MediaSizeName>jpn_chou3_120x235mm</dd:MediaSizeName>
<dd:MediaSizeName>jpn_chou4_90x205mm</dd:MediaSizeName>
<dd:MediaSizeName>custom_hp-greeting-card-env_4.4x6in</dd:MediaSizeName>
<dd:TotalImpressions>4</dd:TotalImpressions>
<dd:ColorImpressions>4</dd:ColorImpressions>
<dd:MediaSizeName>om_photo_89x127mm</dd:MediaSizeName>
<dd:MediaSizeName>na_5x7_5x7in</dd:MediaSizeName>
<dd:MediaSizeName>custom_photo-2l-size-card_127x178mm</dd:MediaSizeName>
<dd:MediaSizeName>om_small-photo_100x150mm</dd:MediaSizeName>
<dd:MediaSizeName>na_number-6_4.33x9.06in</dd:MediaSizeName>
<dd:MediaSizeName>jpn_oufuku_148x200mm</dd:MediaSizeName>
<dd:MediaSizeName>10x15</dd:MediaSizeName>
<dd:MediaSizeName>na_foolscap_8.5x13in</dd:MediaSizeName>
<dd:MediaSizeName>prc_16k_197x273mm</dd:MediaSizeName>
<dd:MediaSizeName>prc_16k_195x270mm</dd:MediaSizeName>
<dd:MediaSizeName>prc_16k_184x260mm</dd:MediaSizeName>
<dd:MediaSizeName>custom</dd:MediaSizeName>
<dd:TotalImpressions PEID="5087">13094</dd:TotalImpressions>
<dd:MediaSizeName>a4_or_letter</dd:MediaSizeName>
<dd:TotalImpressions PEID="5084">36</dd:TotalImpressions>
<dd:MediaSizeName>4x6</dd:MediaSizeName>
<dd:TotalImpressions PEID="5083">1</dd:TotalImpressions>
<dd:MediaSizeName>unknownenvelope</dd:MediaSizeName>
<dd:TotalImpressions PEID="5085">1</dd:TotalImpressions>
<dd:MediaSizeName>5x7</dd:MediaSizeName>
<pudyn:UsageByMediaType>
<dd:TotalImpressions PEID="5003">13476</dd:TotalImpressions>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5048">3131</dd:TotalImpressions>
<dd:PagesPerJob>one</dd:PagesPerJob>
</dd:UsageByJobSize>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5049">1054</dd:TotalImpressions>
<dd:PagesPerJob>two</dd:PagesPerJob>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5050">651</dd:TotalImpressions>
<dd:PagesPerJob>threeToFive</dd:PagesPerJob>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5051">277</dd:TotalImpressions>
<dd:PagesPerJob>sixToTen</dd:PagesPerJob>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5052">165</dd:TotalImpressions>
<dd:PagesPerJob>greaterThanTen</dd:PagesPerJob>
<dd:UsageByQuality>
<dd:NormalImpressions PEID="5041">13394</dd:NormalImpressions>
<dd:DraftImpressions PEID="5042">2</dd:DraftImpressions>
<dd:BetterImpressions PEID="5043">80</dd:BetterImpressions>
</dd:UsageByQuality>
<dd:MediaType>plain</dd:MediaType>
</pudyn:UsageByMediaType>
<dd:TotalImpressions PEID="5004">270</dd:TotalImpressions>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5053">94</dd:TotalImpressions>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5054">4</dd:TotalImpressions>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5055">6</dd:TotalImpressions>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5056">1</dd:TotalImpressions>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="5057">2</dd:TotalImpressions>
<dd:UsageByQuality>
<dd:NormalImpressions PEID="5044">12</dd:NormalImpressions>
<dd:DraftImpressions>0</dd:DraftImpressions>
<dd:BetterImpressions PEID="5046">258</dd:BetterImpressions>
<dd:MediaType>glossy</dd:MediaType>
<dd:UsageByTimeInterval>
<dd:JobCount PEID="39000">3189</dd:JobCount>
<dd:JobDuration>lessthanTwoMinutes</dd:JobDuration>
</dd:UsageByTimeInterval>
<dd:JobCount PEID="39001">259</dd:JobCount>
<dd:JobDuration>twoToFiveMinutes</dd:JobDuration>
<dd:JobCount PEID="39002">516</dd:JobCount>
<dd:JobDuration>fiveToThirtyMinutes</dd:JobDuration>
<dd:JobCount PEID="39003">157</dd:JobCount>
<dd:JobDuration>thirtyToSixtyMinutes</dd:JobDuration>
<dd:JobCount PEID="39004">354</dd:JobCount>
<dd:JobDuration>oneToSixHours</dd:JobDuration>
<dd:JobCount PEID="39005">447</dd:JobCount>
<dd:JobDuration>sixHoursToOneDay</dd:JobDuration>
<dd:JobCount PEID="39006">343</dd:JobCount>
<dd:JobDuration>oneToThreeDays</dd:JobDuration>
<dd:JobCount PEID="39007">131</dd:JobCount>
<dd:JobDuration>threeToSevenDays</dd:JobDuration>
<dd:JobCount PEID="39008">30</dd:JobCount>
<dd:JobDuration>sevenDaysToOneMonth</dd:JobDuration>
<dd:JobCount PEID="39009">0</dd:JobCount>
<dd:JobDuration>oneToThreeMonths</dd:JobDuration>
<pudyn:UsageByCoverage>
<dd:IHM_PlainNormalBest PEID="5071">202</dd:IHM_PlainNormalBest>
<dd:IHM_1to9PagesPerJob_Brochure PEID="5076">0</dd:IHM_1to9PagesPerJob_Brochure>
<dd:IHM_10to49PagesPerJob_Brochure PEID="5077">0</dd:IHM_10to49PagesPerJob_Brochure>
<dd:IHM_GT49PagesPerJob_Brochure PEID="5078">0</dd:IHM_GT49PagesPerJob_Brochure>
<dd:CoverageType>greaterThanThirtyPercentCoverage</dd:CoverageType>
</pudyn:UsageByCoverage>
<dd:IHM_PlainNormalBest PEID="5072">611</dd:IHM_PlainNormalBest>
<dd:IHM_1to9PagesPerJob_Brochure PEID="5073">0</dd:IHM_1to9PagesPerJob_Brochure>
<dd:IHM_10to49PagesPerJob_Brochure PEID="5074">0</dd:IHM_10to49PagesPerJob_Brochure>
<dd:IHM_GT49PagesPerJob_Brochure PEID="5075">0</dd:IHM_GT49PagesPerJob_Brochure>
<dd:CoverageType>lessThanThirtyPercentCoverage</dd:CoverageType>
<dd:IHM_BrochureDuplexed PEID="5081">0</dd:IHM_BrochureDuplexed>
<dd:IHM_PlainDuplexed PEID="5080">41</dd:IHM_PlainDuplexed>
<pudyn:UIButtonPressCounters>
<dd:ButtonPressCount PEID="30051">0</dd:ButtonPressCount>
<dd:ButtonPressOptions>re-printButtonPress</dd:ButtonPressOptions>
</pudyn:UIButtonPressCounters>
<dd:ButtonPressCount PEID="30039">98</dd:ButtonPressCount>
<dd:ButtonPressOptions>startScanButtonPress</dd:ButtonPressOptions>
<dd:DetachableUIAppsLaunchCount>0</dd:DetachableUIAppsLaunchCount>
<dd:DetachableUIAppsImpressions>0</dd:DetachableUIAppsImpressions>
<dd:EWSAccessCount PEID="16081">147998</dd:EWSAccessCount>
<dd:NetworkImpressions PEID="25000">10534</dd:NetworkImpressions>
<dd:WirelessNetworkImpressions PEID="25002">2979</dd:WirelessNetworkImpressions>
<dd:VideoClipImpressions PEID="36001">0</dd:VideoClipImpressions>
</pudyn:PrinterSubunit>
<pudyn:ConsumableSubunit>
<pudyn:Consumable>
<dd:MarkerColor>Magenta</dd:MarkerColor>
<dd:ConsumableTypeEnum>ink</dd:ConsumableTypeEnum>
<dd2:CumulativeConsumableCount>5</dd2:CumulativeConsumableCount>
<dd:ConsumableRawPercentageLevelRemaining>47</dd:ConsumableRawPercentageLevelRemaining>
<dd:SupplyRegion PEID="64330">1</dd:SupplyRegion>
<dd:SupplyFillLevel PEID="64331">230</dd:SupplyFillLevel>
<dd:SupplyFamilyNumber PEID="64332">26</dd:SupplyFamilyNumber>
<dd:SupplyModelNumber PEID="64333">1</dd:SupplyModelNumber>
<dd:SupplySerialNumber PEID="64334">1705371260</dd:SupplySerialNumber>
<dd:SupplyStatusBits PEID="64335">65792</dd:SupplyStatusBits>
<dd:SupplyRefilledStateCounter PEID="28007">0</dd:SupplyRefilledStateCounter>
<dd:PVPCartridgeCounter PEID="28026">0</dd:PVPCartridgeCounter>
<dd:PostInkAlertCounter PEID="11073">0</dd:PostInkAlertCounter>
<dd:PrimeEventLevel0Counter PEID="40005">98</dd:PrimeEventLevel0Counter>
<dd:PrimeEventLevel1Counter PEID="40006">30</dd:PrimeEventLevel1Counter>
<dd:PrimeEventLevel2Counter PEID="40007">5470</dd:PrimeEventLevel2Counter>
<dd:UsageByMarkingAgentCount>
<dd:MarkingAgentCount PEID="11023">12903887</dd:MarkingAgentCount>
<dd:MarkingAgentCountType>HPDropsCount</dd:MarkingAgentCountType>
</dd:UsageByMarkingAgentCount>
<dd:MarkingAgentCount PEID="11058">0</dd:MarkingAgentCount>
<dd:MarkingAgentCountType>LDWDropsCount</dd:MarkingAgentCountType>
<dd:MarkingAgentCount PEID="11063">0</dd:MarkingAgentCount>
<dd:MarkingAgentCountType>LDWServiceDropsCount</dd:MarkingAgentCountType>
<dd:MarkingAgentCount PEID="11031">7396179</dd:MarkingAgentCount>
<dd:MarkingAgentCountType>serviceDropsCount</dd:MarkingAgentCountType>
<dd:RefilledCount>
<dd:CounterfeitRefilledCount PEID="16086">0</dd:CounterfeitRefilledCount>
<dd:GenuineRefilledCount>0</dd:GenuineRefilledCount>
</dd:RefilledCount>
<dd:PenInsertionTriggerSnapshotCounter PEID="28031">21</dd:PenInsertionTriggerSnapshotCounter>
</pudyn:Consumable>
<pudyn:Consumable>
<dd:MarkerColor>Cyan</dd:MarkerColor>
<dd:ConsumableRawPercentageLevelRemaining>20</dd:ConsumableRawPercentageLevelRemaining>
<dd:SupplyRegion PEID="64318">4</dd:SupplyRegion>
<dd:SupplyFillLevel PEID="64319">216</dd:SupplyFillLevel>
<dd:SupplyFamilyNumber PEID="64320">26</dd:SupplyFamilyNumber>
<dd:SupplyModelNumber PEID="64321">1</dd:SupplyModelNumber>
<dd:SupplySerialNumber PEID="64322">1935721580</dd:SupplySerialNumber>
<dd:SupplyStatusBits PEID="64323">65792</dd:SupplyStatusBits>
<dd:SupplyRefilledStateCounter PEID="28006">0</dd:SupplyRefilledStateCounter>
<dd:PVPCartridgeCounter PEID="28025">0</dd:PVPCartridgeCounter>
<dd:PostInkAlertCounter PEID="11072">0</dd:PostInkAlertCounter>
<dd:MarkingAgentCount PEID="11022">12935960</dd:MarkingAgentCount>
<dd:MarkingAgentCount PEID="11057">0</dd:MarkingAgentCount>
<dd:MarkingAgentCount PEID="11062">0</dd:MarkingAgentCount>
<dd:MarkingAgentCount PEID="11030">6772572</dd:MarkingAgentCount>
<dd:RefilledCount>
</dd:RefilledCount>
</pudyn:Consumable>
<pudyn:Consumable>
<dd:MarkerColor>Yellow</dd:MarkerColor>
<dd:ConsumableRawPercentageLevelRemaining>64</dd:ConsumableRawPercentageLevelRemaining>
<dd:SupplyRegion PEID="64306">4</dd:SupplyRegion>
<dd:SupplyFillLevel PEID="64307">230</dd:SupplyFillLevel>
<dd:SupplyFamilyNumber PEID="64308">26</dd:SupplyFamilyNumber>
<dd:SupplyModelNumber PEID="64309">1</dd:SupplyModelNumber>
<dd:SupplySerialNumber PEID="64310">-2115361644</dd:SupplySerialNumber>
<dd:SupplyStatusBits PEID="64311">65792</dd:SupplyStatusBits>
<dd:SupplyRefilledStateCounter PEID="28008">0</dd:SupplyRefilledStateCounter>
<dd:PVPCartridgeCounter PEID="28027">0</dd:PVPCartridgeCounter>
<dd:PostInkAlertCounter PEID="11074">0</dd:PostInkAlertCounter>
<dd:MarkingAgentCount PEID="11024">12535743</dd:MarkingAgentCount>
<dd:MarkingAgentCount PEID="11059">0</dd:MarkingAgentCount>
<dd:MarkingAgentCount PEID="11064">0</dd:MarkingAgentCount>
<dd:MarkingAgentCount PEID="11032">6993420</dd:MarkingAgentCount>
<dd:RefilledCount>
</dd:RefilledCount>
</pudyn:Consumable>
<pudyn:Consumable>
<dd:MarkerColor>Black</dd:MarkerColor>
<dd2:CumulativeConsumableCount>6</dd2:CumulativeConsumableCount>
<dd:SupplyRegion PEID="64300">4</dd:SupplyRegion>
<dd:SupplyFillLevel PEID="64301">651</dd:SupplyFillLevel>
<dd:SupplyFamilyNumber PEID="64302">26</dd:SupplyFamilyNumber>
<dd:SupplyModelNumber PEID="64303">1</dd:SupplyModelNumber>
<dd:SupplySerialNumber PEID="64304">1919616720</dd:SupplySerialNumber>
<dd:SupplyStatusBits PEID="64305">65792</dd:SupplyStatusBits>
<dd:SupplyRefilledStateCounter PEID="28005">0</dd:SupplyRefilledStateCounter>
<dd:PVPCartridgeCounter PEID="28024">0</dd:PVPCartridgeCounter>
<dd:PostInkAlertCounter PEID="11071">0</dd:PostInkAlertCounter>
<dd:PrimeEventLevel0Counter PEID="40002">15</dd:PrimeEventLevel0Counter>
<dd:PrimeEventLevel1Counter PEID="40003">0</dd:PrimeEventLevel1Counter>
<dd:PrimeEventLevel2Counter PEID="40004">13276</dd:PrimeEventLevel2Counter>
<dd:MarkingAgentCount PEID="11021">28304005</dd:MarkingAgentCount>
<dd:MarkingAgentCount>0</dd:MarkingAgentCount>
<dd:MarkingAgentCount PEID="11029">6250021</dd:MarkingAgentCount>
<dd:RefilledCount>
</dd:RefilledCount>
</pudyn:Consumable>
</pudyn:ConsumableSubunit>
<pudyn:ScannerEngineSubunit>
<dd:ScanImages PEID="6000">1591</dd:ScanImages>
<dd:TMAScanToHostImages>0</dd:TMAScanToHostImages>
<dd:AdfImages PEID="6011">1106</dd:AdfImages>
<dd:DuplexSheets PEID="6015">115</dd:DuplexSheets>
<dd:FlatbedImages>448</dd:FlatbedImages>
<dd:JamEvents PEID="6012">34</dd:JamEvents>
<dd:MispickEvents>29</dd:MispickEvents>
<dd:ScanToCardCount PEID="6010">641</dd:ScanToCardCount>
<pudyn:UsageByADF>
<dd:UsageByJobSize>
<dd:UsageByJobSize>
<dd:UsageByJobSize>
<dd:UsageByJobSize>
<dd:UsageByJobSize>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="6016">124</dd:TotalImpressions>
<dd:PagesPerJob>oneToTen</dd:PagesPerJob>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="6017">20</dd:TotalImpressions>
<dd:PagesPerJob>elevenToTwenty</dd:PagesPerJob>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="6018">14</dd:TotalImpressions>
<dd:PagesPerJob>twentyOneToThirty</dd:PagesPerJob>
<dd:UsageByJobSize>
<dd:TotalImpressions PEID="6019">3</dd:TotalImpressions>
<dd:PagesPerJob>greaterThanThirtyfive</dd:PagesPerJob>
</pudyn:UsageByADF>
</pudyn:ScannerEngineSubunit>
<pudyn:MassStorageSubunit>
<dd:TotalImpressions PEID="18018">33</dd:TotalImpressions>
<dd:MemoryDevicesInserted PEID="23017">42</dd:MemoryDevicesInserted>
<dd:PhotoCardInserts PEID="23005">42</dd:PhotoCardInserts>
<dd:PictbridgeImpressions PEID="31000">0</dd:PictbridgeImpressions>
<dd:PictbridgeConnections>0</dd:PictbridgeConnections>
<pudyn:UsageByPhotocard>
<dd:TotalImpressions PEID="18003">0</dd:TotalImpressions>
<dd:PhotoCardType>4x6Impressions </dd:PhotoCardType>
</pudyn:UsageByPhotocard>
<dd:PhotoCardType>4x6MetricEquivalentImpressions</dd:PhotoCardType>
<dd:TotalImpressions PEID="18004">0</dd:TotalImpressions>
<dd:PhotoCardType>5x7Impressions</dd:PhotoCardType>
<dd:PhotoCardType>5x7MetricEquivalentImpressions</dd:PhotoCardType>
<dd:TotalImpressions PEID="18006">0</dd:TotalImpressions>
<dd:PhotoCardType>8x10Or8.5x11orA4Impressions</dd:PhotoCardType>
<dd:PhotoCardType>8x10Or8.5x11orA4MetricEquivalentImpressions</dd:PhotoCardType>
<dd:TotalImpressions PEID="18064">0</dd:TotalImpressions>
<dd:PhotoCardType>albumImpressions</dd:PhotoCardType>
<dd:TotalImpressions PEID="18066">0</dd:TotalImpressions>
<dd:PhotoCardType>clipArtImpressions</dd:PhotoCardType>
<dd:PhotoCardType>3UpLayoutImpressions</dd:PhotoCardType>
<dd:TotalImpressions PEID="18065">0</dd:TotalImpressions>
<dd:PhotoCardType>designImpressions</dd:PhotoCardType>
<dd:TotalImpressions PEID="18063">0</dd:TotalImpressions>
<dd:PhotoCardType>frameImpressions</dd:PhotoCardType>
</pudyn:MassStorageSubunit>
<pudyn:CopyApplicationSubunit>
<dd:TotalImpressions PEID="3019">1374</dd:TotalImpressions>
<dd:ColorImpressions>152</dd:ColorImpressions>
<dd:MonochromeImpressions PEID="3001">1222</dd:MonochromeImpressions>
<dd:AdfImages>482</dd:AdfImages>
<dd:FlatbedImages>902</dd:FlatbedImages>
</pudyn:CopyApplicationSubunit>
<pudyn:ScanApplicationSubunit>
<dd:AdfImages>0</dd:AdfImages>
<dd:FlatbedImages>14</dd:FlatbedImages>
<dd:ImagesSentToEmail PEID="6014">1</dd:ImagesSentToEmail>
<dd:ImagesSentToFolder PEID="6013">196</dd:ImagesSentToFolder>
<dd:ScanToHostImages PEID="6001">14</dd:ScanToHostImages>
</pudyn:ScanApplicationSubunit>
<pudyn:FaxApplicationSubunit>
<dd:TotalImpressions PEID="4016">0</dd:TotalImpressions>
<dd:FlatbedImages>0</dd:FlatbedImages>
<dd:ImagesSentToPC PEID="4012">0</dd:ImagesSentToPC>
<dd:ImagesReceivedFromPC>0</dd:ImagesReceivedFromPC>
<dd:TotalReceivedImages PEID="4007">0</dd:TotalReceivedImages>
<dd:ImagesSentToEmail PEID="4015">0</dd:ImagesSentToEmail>
<dd:ImagesSentToFolder PEID="4014">0</dd:ImagesSentToFolder>
<dd:TotalImagesSent PEID="4011">0</dd:TotalImagesSent>
</pudyn:FaxApplicationSubunit>
<pudyn:PrintApplicationSubunit>
<dd:TotalImpressions PEID="7009">11527</dd:TotalImpressions>
<dd:PhotoImpressions PEID="7002">194</dd:PhotoImpressions>
<dd:MediaSize_4x6in_10x15cm_Impressions PEID="7006">2</dd:MediaSize_4x6in_10x15cm_Impressions>
<dd:IHMPrintViewImpressions PEID="5079">0</dd:IHMPrintViewImpressions>
<dd:CloudPrintImpressions PEID="36016">2</dd:CloudPrintImpressions>
</pudyn:PrintApplicationSubunit>
<pudyn:PonyExpressSubunit>
<pudyn:PECounter PEID="5000">13713</pudyn:PECounter>
<pudyn:PECounter PEID="5088">523</pudyn:PECounter>
<pudyn:PECounter PEID="5033">0</pudyn:PECounter>
<pudyn:PECounter PEID="4013">0</pudyn:PECounter>
<pudyn:PECounter PEID="5031">37</pudyn:PECounter>
<pudyn:PECounter PEID="5032">1</pudyn:PECounter>
<pudyn:PECounter PEID="5037">13626</pudyn:PECounter>
<pudyn:PECounter PEID="5011">1</pudyn:PECounter>
</pudyn:PonyExpressSubunit>
</pudyn:ProductUsageDyn>
higgers
(Steve Higton)
August 12, 2019, 1:59pm
126
I just installed the IPP binding and restart the HP printer binding and the behaviour was the same. No new HP printer thing appeared automatically in the inbox and scanning for things using the HP printer binding didnāt discover anything either. Installed bundles with DNS in the title are now as follows:
openhab> bundle:list | grep DNS
26 x Active x 80 x 3.5.5 x JmDNS
99 x Active x 80 x 0.10.0.oh240 x Eclipse SmartHome Configuration mDNS Discovery
121 x Active x 80 x 0.10.0.oh240 x Eclipse SmartHome REST mDNS Announcer
Are any of these the Core::Bundle::mDNS bundle you referred to above?
Cossey
(Stewart Cossey)
August 12, 2019, 9:52pm
127
Sorry @higgers I am not sure since I no longer use 2.4 but if it was missing the mDNS component it would have been installed with the IPP binding; maybe something else is going on here, Iāll likely need debug logs.
On another note - I saved your xml markup and ran it on a nodeJS server to test the binding and it all appears to work - if you havenāt yet, can you try the most recent update of the Binding I released about 10 hours ago and see if the ink levels work?
suntribe
(suntribe)
August 12, 2019, 11:24pm
128
I confirm that numbers now do appearā¦ tnx
Cossey
(Stewart Cossey)
August 13, 2019, 11:14am
129
New Update
Always the same link: LINK NO LONGER AVAILABLE
Add new channels (Cumulative marking used, displayed in millilitres) dynamic and displayed only if supported by the printer
Adjust how the Ink/Toner Levels are updated to use SmartHomeUnits.PERCENT
higgers
(Steve Higton)
August 13, 2019, 12:41pm
130
Success! With the new binding the ink levels now appear, excellent stuff!
I enabled debug logging and scanned for a printer in PaperUI but that still didnāt work so I manually added the thing. I couldnāt see anything interesting in the log around the time of the automatic scan.
Great stuff, Stewart, thanks!
jwiseman
(Mr. Wiseman (OH 4.2 Snapshot on Pi4))
August 14, 2019, 6:11pm
131
Hi Stewart,
My printer HP LaserJet 400 M401n (provided XML schema earlier on) was self discovered and everything works as expected.
Now my wife knows when the printer fails for whatever reason when sheās doing her eBay sales printing from across the house.
Thank you very much for your work!
Best, Jay
Cossey
(Stewart Cossey)
August 14, 2019, 11:23pm
132
Thanks for being patient @jwiseman , I learned pretty fast that implementing this binding on a per device basis wasnāt sustainable due to all the different printers made by HP and all the requests coming through here. After getting my new PC build and Windows 10 sorted I finally have the time now to spend on this.
Hopefully more people who used this binding in the past will come back here and try the new version of the binding so I can get more feedback. Nailing this issue with Auto-discovery will be ideal, glad it worked for you.
Cossey
(Stewart Cossey)
August 16, 2019, 10:59pm
133
The HP Printer Binding has been merged into the openhab2-addons
repository meaning that you should see the Binding in the next milestone and major versions.
Any bug reports or feature requests should be opened on the official openHAB repository here:
Make sure you tag the issue with the [hpprinter]
and include my tag in the message body @Cossey
I will look at adding more channels/data points (specifically pages remaining) in the near future.
goxaz
(Unknown)
December 23, 2019, 10:15pm
134
Hello!
How to add HP LaserJet 100 colorMFP M175nw printer?
<pudyn:ProductUsageDyn xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:dd="http://www.hp.com/schemas/imaging/con/dictionaries/1.0/" xmlns:pudyn="http://www.hp.com/schemas/imaging/con/ledm/productusagedyn/2007/12/11" xsi:schemaLocation="http://www.hp.com/schemas/imaging/con/dictionaries/1.0/ dd/DataDictionaryMasterLEDM.xsd http://www.hp.com/schemas/imaging/con/ledm/productusagedyn/2007/12/11 ProductUsageDyn.xsd">
<dd:Version>
<dd:Revision>SVN.3337</dd:Revision>
</dd:Version>
<dd:TotalImpressions>3682</dd:TotalImpressions>
<dd:MonochromeImpressions>1999</dd:MonochromeImpressions>
<dd:ColorImpressions>1683</dd:ColorImpressions>
<dd:JamEvents>1</dd:JamEvents>
<dd:MispickEvents>0</dd:MispickEvents>
<dd:PCL6Impressions>
<dd:TotalImpressions>3234</dd:TotalImpressions>
</dd:PCL6Impressions>
<dd:PCL5Impressions>
<dd:TotalImpressions>95</dd:TotalImpressions>
</dd:PCL5Impressions>
<dd:PostScriptImpressions>
<dd:TotalImpressions>148</dd:TotalImpressions>
</dd:PostScriptImpressions>
<pudyn:Consumable>
<dd:ConsumableTypeEnum>toner</dd:ConsumableTypeEnum>
<dd:TotalImpressions>374</dd:TotalImpressions>
<dd:TotalImpressions>376</dd:TotalImpressions>
<dd:MediaSizeName>b4_or_legal</dd:MediaSizeName>
<dd:TotalImpressions>372</dd:TotalImpressions>
<dd:MediaSizeName>custom_or_other</dd:MediaSizeName>
<dd:EstimatedPagesRemaining>800</dd:EstimatedPagesRemaining>
<dd:AverageLifetimeFivePercentCoverageImpressions>0</dd:AverageLifetimeFivePercentCoverageImpressions>
<dd:GreaterThanZeroToTwoPercentSaturatedImpressions>255</dd:GreaterThanZeroToTwoPercentSaturatedImpressions>
<dd:GreaterThanTwoToFourPercentSaturatedImpressions>0</dd:GreaterThanTwoToFourPercentSaturatedImpressions>
<dd:GreaterThanFourToEightPercentSaturatedImpressions>0</dd:GreaterThanFourToEightPercentSaturatedImpressions>
<dd:GreaterThanEightToTwelvePercentSaturatedImpressions>0</dd:GreaterThanEightToTwelvePercentSaturatedImpressions>
<dd:GreaterThanTwelveToOneHundredPercentSaturatedImpressions>0</dd:GreaterThanTwelveToOneHundredPercentSaturatedImpressions>
<dd:FormatterColorImpressionCount>374</dd:FormatterColorImpressionCount>
<dd:ConsumableRawPercentageLevelRemaining>69</dd:ConsumableRawPercentageLevelRemaining>
<pudyn:PreviousCartridgeData>
<dd:TotalImpressions>1802</dd:TotalImpressions>
<dd:MonochromeImpressions>1802</dd:MonochromeImpressions>
<dd:TotalImpressions>1837</dd:TotalImpressions>
<dd:MediaSizeName>b5_or_executive</dd:MediaSizeName>
<dd:FormatterImpressionsAtOut>1254</dd:FormatterImpressionsAtOut>
<dd:ConsumableRawPercentageLevelRemaining>0</dd:ConsumableRawPercentageLevelRemaining>
<dd:Installation>
<dd:Date>2015-05-26</dd:Date>
</dd:Installation>
<dd:ConsumableLastUsedDate>2019-01-30</dd:ConsumableLastUsedDate>
<dd:Capacity>
<dd:MaxCapacity>0</dd:MaxCapacity>
<dd:Unit>100ImpressionsAt5PercentCoverage</dd:Unit>
</dd:Capacity>
<dd:TotalImpressions>155</dd:TotalImpressions>
<dd:ColorImpressions>25</dd:ColorImpressions>
<dd:MonochromeImpressions>130</dd:MonochromeImpressions>
</pudyn:PreviousCartridgeData>
</pudyn:Consumable>
<pudyn:Consumable>
<dd:TotalImpressions>209</dd:TotalImpressions>
<dd:TotalImpressions>208</dd:TotalImpressions>
<dd:EstimatedPagesRemaining>1250</dd:EstimatedPagesRemaining>
<dd:GreaterThanZeroToTwoPercentSaturatedImpressions>211</dd:GreaterThanZeroToTwoPercentSaturatedImpressions>
<dd:FormatterColorImpressionCount>209</dd:FormatterColorImpressionCount>
<dd:ConsumableRawPercentageLevelRemaining>87</dd:ConsumableRawPercentageLevelRemaining>
<dd:TotalImpressions>1528</dd:TotalImpressions>
<dd:TotalImpressions>1539</dd:TotalImpressions>
<dd:FormatterImpressionsAtOut>617</dd:FormatterImpressionsAtOut>
<dd:Installation>
<dd:Date>2011-08-12</dd:Date>
</dd:Installation>
<dd:Capacity>
</dd:Capacity>
<dd:TotalImpressions>287</dd:TotalImpressions>
<dd:ColorImpressions>27</dd:ColorImpressions>
<dd:MonochromeImpressions>260</dd:MonochromeImpressions>
</pudyn:Consumable>
<pudyn:Consumable>
<dd:EstimatedPagesRemaining>1300</dd:EstimatedPagesRemaining>
<dd:TotalImpressions>1540</dd:TotalImpressions>
<dd:FormatterImpressionsAtOut>864</dd:FormatterImpressionsAtOut>
<dd:Installation>
</dd:Installation>
<dd:Capacity>
</dd:Capacity>
</pudyn:Consumable>
<pudyn:Consumable>
<dd:TotalImpressions>207</dd:TotalImpressions>
<dd:EstimatedPagesRemaining>1150</dd:EstimatedPagesRemaining>
<dd:GreaterThanZeroToTwoPercentSaturatedImpressions>214</dd:GreaterThanZeroToTwoPercentSaturatedImpressions>
<dd:FormatterColorImpressionCount>208</dd:FormatterColorImpressionCount>
<dd:ConsumableRawPercentageLevelRemaining>85</dd:ConsumableRawPercentageLevelRemaining>
<dd:FormatterImpressionsAtOut>701</dd:FormatterImpressionsAtOut>
<dd:Installation>
</dd:Installation>
<dd:Capacity>
</dd:Capacity>
</pudyn:Consumable>
<pudyn:Consumable>
<dd:ConsumableTypeEnum>imageDrum</dd:ConsumableTypeEnum>
<dd:EstimatedPagesRemaining>20000</dd:EstimatedPagesRemaining>
<dd:FormatterColorImpressionCount>1684</dd:FormatterColorImpressionCount>
<dd:ConsumableRawPercentageLevelRemaining>46</dd:ConsumableRawPercentageLevelRemaining>
<pudyn:PreviousCartridgeData/>
</pudyn:Consumable>
<dd:AdfImages>162</dd:AdfImages>
<dd:FlatbedImages>443</dd:FlatbedImages>
<dd:JamEvents>3</dd:JamEvents>
<dd:TotalImpressions>290</dd:TotalImpressions>
<dd:ColorImpressions>28</dd:ColorImpressions>
<dd:MonochromeImpressions>262</dd:MonochromeImpressions>
<dd:AdfImages>66</dd:AdfImages>
<dd:FlatbedImages>222</dd:FlatbedImages>
<dd:AdfImages>96</dd:AdfImages>
<dd:FlatbedImages>223</dd:FlatbedImages>
<psdyn:ProductStatusDyn xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:dd="http://www.hp.com/schemas/imaging/con/dictionaries/1.0/" xmlns:ad="http://www.hp.com/schemas/imaging/con/ledm/alertdetails/2007/10/31" xmlns:pscat="http://www.hp.com/schemas/imaging/con/ledm/productstatuscategories/2007/10/31" xmlns:locid="http://www.hp.com/schemas/imaging/con/ledm/localizationids/2007/10/31" xmlns:psdyn="http://www.hp.com/schemas/imaging/con/ledm/productstatusdyn/2007/10/31" xsi:schemaLocation="http://www.hp.com/schemas/imaging/con/dictionaries/1.0/ dd/DataDictionaryMasterLEDM.xsd http://www.hp.com/schemas/imaging/con/ledm/alertdetails/2007/10/31 AlertDetails.xsd http://www.hp.com/schemas/imaging/con/ledm/productstatuscategories/2007/10/31 ProductStatusCategories.xsd http://www.hp.com/schemas/imaging/con/ledm/localizationids/2007/10/31 LocalizationIds.xsd http://www.hp.com/schemas/imaging/con/ledm/productstatusdyn/2007/10/31 ProductStatusDyn.xsd">
<dd:Version>
<dd:Revision>SVN.2730</dd:Revision>
</dd:Version>
<psdyn:Status>
<pscat:StatusCategory>ready</pscat:StatusCategory>
<psdyn:LocString lang="ru">ŠŠ¾ŃŠ¾Š²</psdyn:LocString>
<psdyn:LocString lang="ru">192.168.0.4</psdyn:LocString>
</psdyn:Status>
<psdyn:AlertTable>
<dd:ModificationNumber>2</dd:ModificationNumber>
</psdyn:AlertTable>
</psdyn:ProductStatusDyn>
It is discovered, but shows nothing:
Please help!
Cossey
(Stewart Cossey)
December 27, 2019, 11:01am
135
Hi @goxaz ,
Hmm, I am going to have to investigate this further and get back to you. Iāll be busy over the next week or so, but I will see what I can do. If others can look into this and resolve it they are more than welcome to open a PR with a fix.
tom6
(cruise)
December 27, 2019, 11:34am
136
Hp printer has an embed web interface that gives this printer a special capability that is accepting all different types of printers. This technique is called binding. But the other printer dont have this special featurs. If a binding is done by other company printer accept Hp it will show error and the printer not printing .
I beg your help to follow the steps to add a HP Deskjet 3720 printer. Although I installed HPPrinter binding, auto-discover doesnāt work. A manual discover doesnāt work either and edition of a thing added the printer and channels are added automatically but as a noob I donāt know if something else is to be done. Widget in PaperUI shows no status neither ink level. Thanks in advance.
Carber
(Aitor)
March 27, 2020, 4:11pm
138
Iām trying to add my HP OfficeJet Pro 6830, but scan info and print info is not all supported. I add my own usage and status files.
Thanks for this great Binding.
ProductUsageDyn.xml (32.0 KB)
ProductStatusDyn.xml (2.5 KB)
Please, add model HP Deskjet 3720. Here you are xml files.
ProductUsageDyn.xml (26.5 KB)
ProductStatusDyn.xml (2.9 KB)
Thanks in advance
wlaw
(Wayne Law)
April 15, 2020, 1:54am
140
@Cossey Iāve started seeing a similar issue to that raised by @goxaz . That is, status runs ok but the usage fails.
Turning trace on in the console I can see the HTTP client polling for status every 4 seconds as expected but no polls for usage. Drilling down further I can see a warning in the log that an exception is raised related to a null pointer. See below.
Usage was working but stopped about a week or two back. Not sure what the trigger was but it is a common problem because I setup a second openhab instance on another platform and see the same behaviours from a clean install.
Looking into HPUsage.java at line 79 it seems to be trying to read the ādd:Unitā. Connecting to the printer via a browser using HTTP or HTTPS displays /DevMgmt/ProductUsageDyn.xml no problems at all and I can see the Unit is in millilitres.
Stewart, if you have any tips on how I can help you out by me drilling further into to this I would be most grateful.
Regards
Wayne
PS I have no idea whether a HP6950 is a supported printer. It didnāt auto discover but does so manually ok and finds all the supported channels. Like I said above, it used to work ok but recently stopped processing the usage data a couple of weeks back. No idea what caused that to happen. I can send across a copy of the /DevMgmt/ProductUsageDyn.xml output if needed.
2020-04-15 10:46:20.516 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.hpprinter.internal.api.HPUsage.(HPUsage.java:79) ~[?:?]
at org.openhab.binding.hpprinter.internal.api.HPWebServerClient.getUsage(HPWebServerClient.java:114) ~[?:?]
at org.openhab.binding.hpprinter.internal.binder.HPPrinterBinder.checkUsage(HPPrinterBinder.java:301) ~[?:?]
at org.openhab.binding.hpprinter.internal.binder.HPPrinterBinder.lambda$1(HPPrinterBinder.java:277) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) ~[?:?]
