And the plot thickens…
I just tried my panel in Silk browser on an Amazon Fire and the correct dashboard is displayed after timeout.
The IDs are not the panel name. It is taken from the list of Habpanel itself. Also, the “current” panel is not shown because I exclude habpanelex from it. We dont want the settings be part of the rotation.
Try this, paste the value you see from this url:
http:// < your openHAB > /rest/items/habpanelExConfig
{"link":"http://192.168.0.12:8080/rest/items/habpanelExConfig","state":"{\"initComplete\":true,\"isShowInDrawer\":true,\"screensaver\":{\"isEnabled\":true,\"timeoutSeconds\":60,\"durationSeconds\":60,\"dashboardList\":\"Testing,Prayers\"}}","editable":true,"type":"String","name":"habpanelExConfig","label":"HPEx Config for habpanelExConfig","tags":[],"groupNames":[]}
Ok, so I stopped, cache flushed, started OH for another reason…and now it’s working on Firefox as well…
I pasted http://192.168.53.220:8080/habpanel/index.html#/rest/items/habpanelExConfig
But it just showed the dashboards I have defined:
Hmmm. Looks good to me. Do you get any errors from console logs? The settings are retrieved from that item. I already added some cachebusting on the last version so hopefully settings are not cached.
I’m thinking it’s more of an iOS issue than Safari in particular since none of the browsers i’ve tried seem to work, even though i’m using the same saved dashboard that works on my Android and Windows devices so I know the server side is good. From what I recall, all browsers on iOS all have to use the same underlying engine because of an Apple requirement or something like that. I’m going to try jailbreaking and seeing if there’s an alternate browser that will work.
AS I said all seems to work now…not sure if it was the restart or the cache clear…
Fixed missing () on catch {} block. Modern browsers do not require parentheses on the catch block. I loaded it code onto an older IE and I was able to recreate the issue. Please take latest. Should fix other browsers…
Added on steps:
If you have a previous installation of HabPanelEx, I have noticed that the browser may sometimes cache the javascript file. Always clear your browser’s cache when upgrading so you know you have the latest js file loaded.
you should try now
Changes:
Added FullScreen mode on the screen saver - if this is turned on, it will make the panel fullscreen (no header, no drawer)
Added the Theater Mode
Please take latest from
It seems to have fixed my iPad issue, but i’m using the Matrix theme from Matrix Theme for HABPanel and theater mode doesn’t seem to work on any dashboards but the hpex setup screen. It’s a css conflict somewhere for sure, because if I take the external css file out of my habpanel config theater mode works as expected - just need to figure out where.
Looks like I spoke too soon. I changed the screen change time to get more time to troubleshoot and now everything seems to be working fine, including theater mode.
Hey Lucky,
Thanks for adding the Theater Mode; I’ve just installed your panel for the first time and I’m trying the “basic” screen save mode first and have discovered another “feature needed” at least for me ;-(
I have 3 tablets on the wall; one is vertically placed and the other two are horizontally placed.
The way I have the panels in HabPanel setup is; I have one for Horizontal and one for Vertical since the layout and widget sizes are so much different based on the orientation of the tablet.
For example, I have a panel called Weather and another called Weather-V which means a vertical layout. I have many panels setup like this . . .
The issue I’m having is; if I enable the screen saver and choose the panels I want to rotate through, it applies to both my horizontal and vertical tablets which means its going to show panels that will not fit or look proper on one of the tablet orientations.
I’m not sure if I’m SOL or is there something we can do to address this scenario?
Vertical:
Horizontal:
Yes, those temps are accurate!
Best, Jay
That’s pretty much the issue with HabPanel in general. All settings are shared across ALL devices. Let me see if I can come up with a way to have different hpex configs per device, stored on different String items.
Chicago temperature…1… yikes!!!
me is in florida… and I’m bummed because 60 F
Done. Get latest from the git
You can have as many device as you want, and all of them can be configured to have their own settings/configuration.
Thanks Lucky for allowing this change. It will be a HUGE help for everybody. My issue is getting the updated JSON into the panel. I have cleared the browser cache and tried another browser (Windows Chrome and Firefox) but it continues to bring in the same looking JSON for configuration.
I did download the latest ZIP off of GIT per your recommendation and the date of the JSON file is 1/29/19 @ 5:39 pm so I’m pretty sure I got the last update of it.
Every time I try from scratch it seems to keep my OLD configuration (panel rotation ids) which means to me it’s NOT really getting deleted when I delete the panel and the JSON widget.
Any advise?
Best, Jay
Json config will look the same lol. You need to go to Advanced tab under the settings page and use a different Item string. You need to type “I understood” in the box to make it editable.
For some reason the image upload isn’t working…
