I can’t figure out my my thermostat temp channel/item is not showing the right temp. Is it a formatting issue?
Any ideas?
Colin
Any ideas?
Colin
That looks like a default value (80 00) in hex. Was it working before or is this a new device? If new, as a battery device is it fully initialized (5 lines at the bottom of the UI page)?
Lastly, if new, what is value of parameter 1 (enable or disable temperature sensor)?
it’s not a new device, but I have recently rebuilt my z-wave network and this device not been working correctly. Only a problem now that i need to use the heating
It looks like you have pointed me in the right direction however, thankyou!
from another site i found:
Configuration Parameter Number 1:
0–127 disables temperature sensor, 128-255 enables temperature sensor. Default = 0.
again, thanks.
Colin
Confirming issue is resolved!
thanks again
Colin
