I’ve upgraded to OpenHab 2.4 which has HS220 support! However, I’m wondering if the support for it was actually tested Only a brightness channel is exposed and while setting the brightness to a non-zero value does indeed turn the light on, setting the brightness to “0” does not turn the light off.
I’m rather wondering if the ideal input would be to expose a switch plus a dimmer value. This would make sense as I may wish to turn the light off without changing the brightness level used if the light is turned on again; further, it’d be nice to be able to change the default brightness in response to the total solar radiation.
Well, now I have the opposite problem. The switch turns off but it won’t turn on! When I turn it on, I see this in the logs:
2018-12-30 07:59:58.848 [ome.event.ItemCommandEvent] - Item 'MasterBath_Light_Brightness' received command 32
2018-12-30 07:59:58.855 [nt.ItemStatePredictedEvent] - MasterBath_Light_Brightness predicted to become 32
2018-12-30 07:59:58.866 [vent.ItemStateChangedEvent] - MasterBath_Light_Brightness changed from 0 to 32
2018-12-30 07:59:59.301 [vent.ItemStateChangedEvent] - MasterBath_Light_Brightness changed from 32 to 0
Not sure if the switch has a feedback loop? I did uninstall the other plugin and restarted openhab2.
Looking at bundle:list, I only have one version installed:
START LEVEL 100 , List Threshold: 50
ID │ State │ Lvl │ Version │ Name
.... snip ....
258 │ Active │ 80 │ 2.5.0.201812291920 │ TPLinkSmartHome Binding
