- Platform information:
- Raspberry pie 4B 8gb
- OS: Openhabian
- openHAB version: 03.11.2020
- Issue of the topic: I’ve got a new Everspring HSP02 motion sensor, i’m very new to OH2 so I try to find the thing with the UI. That work, it create a node 7 but the system think to find a SM103 (contact sensor). I found in others post some similar problems but after some tries they work good.
I try some times with no different result, I try to modify the .xml file but OH2 continues to ovverride.
Some one has an Idea how to solve it?
When I try to activate the sensor from real… no result.
log:> 2020-11-10 22:00:24.857 [home.event.InboxAddedEvent] - Discovery Result with UID ‘zwave:device:0b045602:node6’ has been added.
2020-11-10 22:00:24.869 [home.event.InboxAddedEvent] - Discovery Result with UID ‘zwave:device:0b045602:node7’ has been added.
2020-11-10 22:00:41.905 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘zwave:device:0b045602:node6’ has been removed.
2020-11-10 22:00:48.651 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘zwave:device:0b045602:node7’ has been removed.
2020-11-10 22:00:48.671 [hingStatusInfoChangedEvent] - ‘zwave:device:0b045602:node7’ changed from UNINITIALIZED to INITIALIZING
2020-11-10 22:00:48.694 [hingStatusInfoChangedEvent] - ‘zwave:device:0b045602:node7’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-11-10 22:00:48.711 [hingStatusInfoChangedEvent] - ‘zwave:device:0b045602:node7’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-11-10 22:00:48.732 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:0b045602:node7’ has been updated.
2020-11-10 22:00:48.738 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:0b045602:node7’ has been updated.
2020-11-10 22:00:48.745 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:0b045602:node7’ has been updated.
2020-11-10 22:00:48.753 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:0b045602:node7’ has been updated.
2020-11-10 22:00:48.755 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=]
2020-11-10 22:01:36.244 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:0b045602:node7’ has been updated.
2020-11-10 22:17:31.319 [hingStatusInfoChangedEvent] - ‘zwave:device:0b045602:node7’ changed from ONLINE to REMOVING
2020-11-10 22:17:31.325 [hingStatusInfoChangedEvent] - ‘zwave:device:0b045602:node7’ changed from REMOVING to REMOVED
2020-11-10 22:17:31.337 [hingStatusInfoChangedEvent] - ‘zwave:device:0b045602:node7’ changed from REMOVED to UNINITIALIZED
2020-11-10 22:17:31.512 [hingStatusInfoChangedEvent] - ‘zwave:device:0b045602:node7’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-11-10 22:17:38.467 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 6: Device discovery could not resolve to a thingType! Manufacturer data not known.
2020-11-10 22:17:38.472 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘zwave:device:0b045602:node6’ to inbox.
2020-11-10 22:17:38.483 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘zwave:device:0b045602:node7’ to inbox.
2020-11-10 22:17:38.473 [home.event.InboxAddedEvent] - Discovery Result with UID ‘zwave:device:0b045602:node6’ has been added.
2020-11-10 22:17:38.484 [home.event.InboxAddedEvent] - Discovery Result with UID ‘zwave:device:0b045602:node7’ has been added.
2020-11-10 22:17:51.471 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘zwave:device:0b045602:node7’ has been removed.
2020-11-10 22:17:51.487 [hingStatusInfoChangedEvent] - ‘zwave:device:0b045602:node7’ changed from UNINITIALIZED to INITIALIZING
2020-11-10 22:17:51.520 [hingStatusInfoChangedEvent] - ‘zwave:device:0b045602:node7’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-11-10 22:17:51.527 [hingStatusInfoChangedEvent] - ‘zwave:device:0b045602:node7’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-11-10 22:17:51.537 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:0b045602:node7’ has been updated.
2020-11-10 22:17:51.551 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:0b045602:node7’ has been updated.
2020-11-10 22:17:51.557 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:0b045602:node7’ has been updated.
2020-11-10 22:17:51.564 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:0b045602:node7’ has been updated.
2020-11-10 22:17:51.567 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=]
2020-11-10 22:27:41.124 [ome.event.ItemUpdatedEvent] - Item ‘Batteria_sensore_movimento_PT’ has been updated.
2020-11-10 22:27:54.470 [.ItemChannelLinkAddedEvent] - Link ‘Batteria_sensore_movimento_PT-zwave:device:0b045602:node7:battery-level’ has been added.
2020-11-10 22:29:06.010 [.ItemChannelLinkAddedEvent] - Link ‘Atrio_sensore_movimento_PT-zwave:device:0b045602:node7:sensor_binary’ has been added.
2020-11-10 22:29:09.748 [.ItemChannelLinkAddedEvent] - Link ‘Atrio_sensore_movimento_PT-zwave:device:0b045602:node7:alarm_general’ has been added.
Blockquote
