{http="<[http://192.168.178.60/plc?aussen:60000:REGEX(.*?Aussenbereich: (.*?))]" should get you a String item if that line REALLY is the whole web page contents
As the response is EIN or AUS, but openHAB uses ON and OFF, there is no direct way. Of course you can use a JavaScript Transformation. Something like
item:
2018-09-10 12:21:33.904 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type JS:
2018-09-10 12:21:33.906 [WARN ] [ab.binding.http.internal.HttpBinding] - Couldn’t transform response because transformationService of type ‘JS:’ is unavailable
i do something wrong. In the Paper UI i already have installed by Transformations the Javascript Transformation
transformation-javascript - 2.2.0.
I uninstall this and afterwards I install it again. I’ve got the same warning “[WARN ] [ab.binding.http.internal.HttpBinding] - Couldn’t transform response because transformationService of type ‘JS:’ is unavailable”
I stopped Openhab and update and upgrade the raspi.
All transformations in the paper UI are installed.
I now i have a new Version 2.3. I lost the KNX Connection. I do the same like in the KNX.cfg (IP;TUNNEL;Port)
in the Things.
More information is still required??
I use a ABB IPR/S 3.1.1 (With the old binding (binding-knx1 - 1.11.0) it was working)
for the Java ive got the same result
2018-09-16 09:53:13.369 [WARN ] [ab.binding.http.internal.HttpBinding] - Couldn’t transform response because transformationService of type ‘JS:’ is unavailable
Please be aware that the knx Binding was upgraded to knx2, you have to configure a Bridge, Things and Channels (and bind these channels to the Items).
Another option is, to change a setting in Paper UI:
Configuration->System->Add-on Management->Include Legacy 1.x Bindings (switch ON)
Uninstall knx2 Add-ons->Bindings->knx->UNINSTALL
Install knx1 Add-ons->Bindings->knx1->INSTALL
Im use the old Version 1.x binding and ist working, only where i enter the Name of Default sitemap. I have no demo.sitemap and by the clasic UI I have not the correct site.
