So I am stuck trying to display a simple number on my sitemap.
What I have done so far:
Installed the HTTP Binding
Created an item as follows (Basically identical to the example provided):
Number temp_name “temp” { http="<[http://ip-address:port/data.json:60000:JSONPATH($.temp)]" }
Added a field into my sitemap
Text item=temp
Now, my item is displaying on the sitemap but my temp values are not, I have checked and the JSON endpoint is fine so I have no idea what the problem could be.
Had to install the JSONPATH transform in the paper UI. Would be handy if that was mentioned in the HTTP Binding documentation with the JSONPATH example.
Hmm. Most probably you’re right.
After fist look into the documentation I thought this is port, not interval. so I’ve skipped this
I will check this out in the evening.
