Getting the following eror when starting openhab 2.2.0-SNAPSHOT:
2017-12-20 21:29:04.901 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler, id=308, bundle=215/mvn:org.openhab.binding/org.openhab.binding.http/1.12.0-SNAPSHOT]: Unexpected problem updating configuration org.openhab.http
java.lang.NumberFormatException: For input string: "5000.0"
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65) ~[?:?]
at java.lang.Integer.parseInt(Integer.java:580) [?:?]
at java.lang.Integer.valueOf(Integer.java:766) [?:?]
at org.openhab.binding.http.internal.HttpBinding.updated(HttpBinding.java:507) [215:org.openhab.binding.http:1.12.0.201712180210]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1479) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1435) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109) [7:org.apache.felix.configadmin:1.8.16]
beckhoff http binding works.
but froniusrtd not… where is the 5000 comming from in the exception ?
is it possible to configure on raspberrypi at another path as /etc/openhab2/services/http.cfg ?
thanks,
many item configs, but for the fronius inverter only this one:
Number PV_DaySumCalculated "Tagessumme [%.1f kWh]" <inverter>
Number PV_YearSumCalculated "Jahressumme [%.1f MWh]" <inverter>
Number PV_TotalCalculated "Gesamtsumme [%.1f MWh]" <inverter>
Number PV_Prozent "Auslastung [%.2f %%]" <inverter>
Number PV_Current "Aktuelle Leistung [%0f W]" <inverter> (PV) { http="<[froniusrtd:4000:JSONPATH($.Body.Data.PAC.Values.1)]" }
Number PV_DaySum "Tagessumme [%0f Wh]" <inverter> (PV) { http="<[froniusrtd:30000:JSONPATH($.Body.Data.DAY_ENERGY.Values.1)]" }
Number PV_YearSum "Jahressumme [%0f Wh]" <inverter> (PV) { http="<[froniusrtd:30000:JSONPATH($.Body.Data.YEAR_ENERGY.Values.1)]" }
Number PV_Total "Gesamtsumme [%0f Wh]" <inverter> (PV) { http="<[froniusrtd:30000:JSONPATH($.Body.Data.TOTAL_ENERGY.Values.1)]" }
rule:
rule "pv-berechnung in kWh"
Item PV_DaySum received update
PV_DaySumCalculated.postUpdate((PV_DaySum.state as Number)/1000);
rule "pv-berechnung in MWh"
Item PV_YearSum received update
PV_YearSumCalculated.postUpdate((PV_YearSum.state as Number)/1000000);
rule "pv-berechnung total in MWh"
Item PV_Total received update
PV_TotalCalculated.postUpdate((PV_Total.state as Number)/1000000);
rule "auslastung"
Item PV_Current received update
PV_Prozent.postUpdate((PV_Current.state as Number)/8100*100);
thank you. already updated to 2.2.0-SNAPSHOT made an update a few minutes ago.
Inverter does not change data at the moment because of night modus maybe something is cached?
Before stopping working to show the data, I enabled format at paper UI http configuration.
I noticed that in my version (openhab 2.2.0-SNAPSHOT) there is no configuration for http available.
I changed under bindings HTTP BINDING the format. now tried to set it back to false and using http.cfg with format=true.
I do get some errors when changing http.cfg in the log.
So where exactly is the 5000.0 value configured in which file ?
I read in this forum that another person hat exactly the same problem caused by double configuration of http.cfg under /userdata/…
he deleted the userdata file and problem was solved…
I do only have /etc/openhab2/ directory on my raspberrypi, or is there anywhere else another http.cfg ?
thanks,
SOLVED !!!
Each time I saved http.cfg I got this error:
dler, id=320, bundle=215/mvn:org.openhab.binding/org.openhab.binding.http/1.12.0-SNAPSHOT]: Unexpected problem updating configuration org.openhab.http
at org.openhab.binding.http.internal.HttpBinding.updated(HttpBinding.java:507) [215:org.openhab.binding.http:1.12.0.201712210210]
at org.apache.felix.cm.impl.ConfigurationManager$UpdateConfiguration.run(ConfigurationManager.java:1792) [7:org.apache.felix.configadmin:1.8.16]
Solved by rewriting the URLs and updateInverval again. (not copy paste!).
Maybe there was an unicode symbol or anything else…
now everything works again !
Hopefully I can help someone with the same problem.
