I have a HTTP binding which grabs an image from the internet every 5 minutes and stores it in an Image item. This is working fine.
Now I also want to be able to grab this image on a manual way, eg by clicking on a button in a widget. Is this possible by calling this http Thing in a rule (DSL)?
Or what is the best approach?
Did you try sending a REFRESH command to the channel?
I always forget about the REFRESH command. We should probably mention that in the add-on readme. Not all binding support REFRESH (nor does it make sense in all cases).
Already tried this, but was struggling how-to store the image in a Image item.
Never heard of this possibility. How does this work? Although it’s the thing which needs a refresh, no?
You’ll have to Base64 encode the retrieved binary. There are tutorials on the forum.
Send the Item linked to the Channel the REFRESH command:
MyItem.sendCommand(REFRESH)
