Hi all,
after update to 2.5.6.2 my heater items refreshs only after restart the openhab-service. I thought the problem was solved with 2.5.6.2. Does anyone else have the problem or does anyone have a solution?
Here the item which worked without problems before:
Number Volumenstrom “Volumenstrom [%.1f ]” (heizung) { http="<[http://192.168.10.144/heizung.php?id=01da:20000:REGEX(.?(.?).*)]" }
The timeout in http.cfg is 50000ms.
Thanks in advance
