Had pi-hole setup earlier, but ended up removing it. Since then i get theese errors in my logs:
2020-03-18 10:31:53.101 [ERROR] [org.apache.felix.configadmin ] -
[org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler, id=453,
bundle=245/mvn:org.openhab.binding/org.openhab.binding.http/[1.14.0,1.15)]: Unexpected
problem updating configuration org.openhab.http
java.lang.NumberFormatException: For input string: "600000*/"
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65) ~[?:1.8.0_242]
at java.lang.Integer.parseInt(Integer.java:580) ~[?:1.8.0_242]
at java.lang.Integer.valueOf(Integer.java:766) ~[?:1.8.0_242]
at org.openhab.binding.http.internal.HttpBinding.updated(HttpBinding.java:535) ~[?:?]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189) ~[bundleFile:?]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152) [bundleFile:?]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85) [bundleFile:?]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1118) [bundleFile:?]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1074) [bundleFile:?]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:138) [bundleFile:?]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105) [bundleFile:?]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_242]
I have removed anything related to pihole, in all my rules, things, items, services. But still they remain when i inspect the http binding in paperui. Have also deleted cache. No go. Any ideas where there might be something holding onto the information? It doesnt help if i delete in the http binding on paperui.
@Kimzer Look in /var/lib/openhab2/jsondb/org.eclipse.smarthome.core.thing.link.ItemChannelLink.json and make sure there isn’t a Link hanging around. Also, for items check: /var/lib/openhab2/jsondb/org.eclipse.smarthome.core.items.Item.json
If you find the item or link in either location you can remove it but stop OH first. You may also what to clean the cache as well.
Well, the binding is installed and complaing, understood or not.
Look in the working copy of addons.cfg, addons.config
Look for a http .jar in your /addons folder
Found the solution. I tried to grep, but could not find the culprit file. But i stumbled upon this, and that was the solution. If anyone else experience similar issues with http binding, check out the post below.
