Hi all,
just trying to move from my old and well working OH 1.8 to OH2 and check what’s running and what is not.
I do have a number of Arduino’s running here, which promote the info about their connected sensors via HTTP. So in OH1.8 i’m using often the HTTP-binding with RegEx to import this info into OH.
It looks like reading from HTTP and RegEx is ether not working or at least different in OH2. I also use the HTTP-Binding to post info to the Arduino’s, this is working well without changes.
BTW: I’m using the cache-functionality, setup in openhab.cfg for reading with this binding. Maybe this is the not or different working part?? (But i don’t think so, it looks like the whole content of the HTTP is filled into the OH2-item. I saw the same behaviour in 1.x, when the RegEx fit’s everything.)
See my example in item-definition:
Reading is working well in OH 1.x and NOT working in OH2:
String A51_HK1C “Heizkreis WoZi West [%s]” (A5x,HKreis,EG_Wohnzimmer) {http=<[A51chache:60000:REGEX(.?HK1: (.?)
This one to send data via the binding; it is working in in OH1.8 as well as OH2
Switch A51_HK1S “Heizkreis EG1” (A5x,HKreis,EG_Wohnzimmer) {http=">[ON:POST:http://192.168.0.51/HK1ON] >[OFF:POST:http://192.168.0.51/HK1OFF]" }
Any hint would be very kind.
Thanks,
andreas
