- Platform information:
- Hardware: Raspberry Pi 4
- OS: Raspbian Bullseye
- Java Runtime Environment: openjdk 11.0.14 2022-01-18
- openHAB version: 3.2.0
- Issue of the topic:
Every morning and evening I switch all my thermostates from “day” to “night” and back which basically means: Night temp: 18 °C and day temperature the last user set temperature.
Sometimes openHAB forgets to set the temperature of one thermostate. I.e. it still is set to 18 °C although we have reached the “day” program. - Please post configurations (if applicable):
I tried to shorten the rules as much as possible but in order to give you the full picture I had to post nearly all rules.
The init:
import java.util.Map
val Map<String, String> shellies = newHashMap
rule "IP Adressen festlegen"
System started
shellies.put("Keller", "192.168.188.66")
shellies.put("WC", "192.168.188.70")
shellies.put("Wohnzimmer", "192.168.188.68")
shellies.put("Kinderzimmer", "192.168.188.74")
shellies.put("Treppenhaus", "192.168.188.67")
shellies.put("Buero", "192.168.188.72")
shellies.put("BadDG", "192.168.188.69")
shellies.put("BadOG", "192.168.188.71")
shellies.put("Spielzimmer", "192.168.188.73")
shellies.put("Schlafzimmer", "192.168.188.75")
Day/Night switch:
rule "Fussbodenheizung: Nachtabsenkung"
Time cron "0 30 22 1/1 * ? *"
if(vIt_HZ_AusserHaus.state==OFF) {
vIt_HZ_Tag.sendCommand('OFF')
logInfo("Fussbodenheizung: Nachtabsenkung", "Nachtabsenkung aktiviert")
rule "Fussbodenheizung: Tagesprogramm"
Time cron "0 30 5 1/1 * ? *"
vIt_HZ_Tag.sendCommand('ON')
logInfo("Fussbodenheizung: Tagesprogramm", "Tagesprogramm gestartet")
Now let us iterate through all thermostates:
rule "Fussbodenheizung: Tagesprogramm Temperaturen ändern"
Item vIt_HZ_Tag changed
gSollTemperaturen.members.forEach[ v_Heizung_Soll |
var String raumName = v_Heizung_Soll.name.split("_").get(3)
var v_Heizung_SollAnwender = gAnwenderSollTemperaturen.members.findFirst[ i | i.name.toString.contains(raumName) ] as NumberItem
if(vIt_HZ_Tag.state == ON) {
v_Heizung_Soll.sendCommand(v_Heizung_SollAnwender.state as Number)
} else {
v_Heizung_Soll.sendCommand(vIt_HZ_SollTempNacht.state as Number)
logInfo("Fussbodenheizung: Tagesprogramm Temperaturen ändern", "Alle Thermostate haben die Temperatur für das " + vIt_HZ_Tag.state + "-Programm erhalten")
And now the temperature settings “cascade” until they get sent to the shellies:
rule "Fussbodenheizung: Abschalt-/Einschaltwert neu berechnen"
Member of gSollTemperaturen received update
var v_Heizung_Soll = triggeringItem
var Double Hysterese = (vIt_HZ_Hysterese.state as Number).doubleValue()
var Double Abschaltwert = (v_Heizung_Soll.state as Number).doubleValue() + Hysterese
var Double Einschaltwert = Abschaltwert - 2 * Hysterese
var String roomName = v_Heizung_Soll.name.split("_").get(3)
val v_Heizung_Abschalt = gAbschaltTemperaturen.members.findFirst[ i | i.name.toString.contains(roomName) ] as NumberItem
val v_Heizung_Einschalt = gEinschaltTemperaturen.members.findFirst[ i | i.name.toString.contains(roomName) ] as NumberItem
logInfo("Fussbodenheizung: Abschalt-/Einschaltwert neu berechnen", "Solltemperatur geändert für " + roomName + ": " + v_Heizung_Soll.state + " °C")
// Heizungstimer abbrechen, falls Temperatur manuell geandert wird, bevor der Timer abgelaufen war
val GroupItem a_Heizung_Timer = gHeizungsTimer.members.findFirst[ timer | timer.name.toString.contains(roomName)] as SwitchItem
if(a_Heizung_Timer !== null) {
// Dieser Raum hat einen Ruecksetztimer (wahrscheinlich alle ausser das Treppenhaus)
if(a_Heizung_Timer.state == ON) {
a_Heizung_Timer.postUpdate(OFF)
logInfo("Fussbodenheizung: Abschalt-/Einschaltwert neu berechnen", "Timer " + a_Heizung_Timer.name + " wurde abgebrochen aufgrund manueller Temperaturaenderung.")
v_Heizung_Abschalt.sendCommand(Abschaltwert)
v_Heizung_Einschalt.sendCommand(Einschaltwert)
rule "Fussbodenheizung: Abschalt-/Einschaltwert an ein Shelly versenden"
Member of gEinschaltTemperaturen changed
var v_Heizung_Einschalt = triggeringItem
var String roomName = v_Heizung_Einschalt.name.split("_").get(3)
if(v_Heizung_Einschalt.state == NULL || v_Heizung_Abschalt.state == NULL) {
return;
var String ipAddress = shellies.get(roomName)
// http Befehl an Shelly senden
var String httpString = ""
httpString = "http://"+ipAddress+"/settings/ext_temperature/0?undertemp_threshold_tC=" + String::format("%.2f",(v_Heizung_Einschalt.state as Number).doubleValue())
sendHttpGetRequest(httpString)
httpString = "http://"+ipAddress+"/settings/ext_temperature/0?overtemp_threshold_tC=" + String::format("%.2f",(v_Heizung_Abschalt.state as Number).doubleValue())
logInfo("Fussbodenheizung: Abschalt-/Einschaltwert an ein Shelly versenden", "Neue Einschalttemperatur im Raum " + roomName + ": " + v_Heizung_Einschalt.state)
logInfo("Fussbodenheizung: Abschalt-/Einschaltwert an ein Shelly versenden", "Neue Abschalttemperatur im Raum " + roomName + ": " + v_Heizung_Abschalt.state)
Thread::sleep(1000)
- If logs where generated please post these here using code fences:
The log is very important here now. The temperature was not set for “Keller”.
2022-05-27 05:30:00.999 [INFO ] [ript.Fussbodenheizung: Tagesprogramm] - Tagesprogramm gestartet
2022-05-27 05:30:01.045 [INFO ] [bschalt-/Einschaltwert neu berechnen] - Solltemperatur geändert für Keller: 20.5 °C
2022-05-27 05:30:01.071 [INFO ] [g: Tagesprogramm Temperaturen ändern] - Alle Thermostate haben die Temperatur für das ON-Programm erhalten
2022-05-27 05:30:01.072 [INFO ] [bschalt-/Einschaltwert neu berechnen] - Solltemperatur geändert für Treppenhaus: 19.5 °C
2022-05-27 05:30:01.101 [INFO ] [bschalt-/Einschaltwert neu berechnen] - Solltemperatur geändert für Wohnzimmer: 21.0 °C
2022-05-27 05:30:01.126 [INFO ] [bschalt-/Einschaltwert neu berechnen] - Solltemperatur geändert für BadDG: 21.0 °C
2022-05-27 05:30:01.155 [INFO ] [bschalt-/Einschaltwert neu berechnen] - Solltemperatur geändert für BadOG: 21.0 °C
2022-05-27 05:30:01.180 [INFO ] [bschalt-/Einschaltwert neu berechnen] - Solltemperatur geändert für WC: 21.0 °C
2022-05-27 05:30:01.208 [INFO ] [bschalt-/Einschaltwert neu berechnen] - Solltemperatur geändert für Buero: 21.0 °C
2022-05-27 05:30:01.233 [INFO ] [bschalt-/Einschaltwert neu berechnen] - Solltemperatur geändert für Spielzimmer: 21.0 °C
2022-05-27 05:30:01.251 [INFO ] [bschalt-/Einschaltwert neu berechnen] - Solltemperatur geändert für Kinderzimmer: 21.0 °C
2022-05-27 05:30:01.269 [INFO ] [bschalt-/Einschaltwert neu berechnen] - Solltemperatur geändert für Schlafzimmer: 21.0 °C
2022-05-27 05:30:01.918 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Einschalttemperatur im Raum Treppenhaus: 19.2
2022-05-27 05:30:01.921 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Abschalttemperatur im Raum Treppenhaus: 19.8
2022-05-27 05:30:04.730 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Einschalttemperatur im Raum Wohnzimmer: 20.7
2022-05-27 05:30:04.732 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Abschalttemperatur im Raum Wohnzimmer: 21.3
2022-05-27 05:30:06.532 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Einschalttemperatur im Raum BadDG: 20.7
2022-05-27 05:30:06.551 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Abschalttemperatur im Raum BadDG: 21.3
2022-05-27 05:30:08.291 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Einschalttemperatur im Raum BadOG: 20.7
2022-05-27 05:30:08.295 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Abschalttemperatur im Raum BadOG: 21.3
2022-05-27 05:30:10.133 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Einschalttemperatur im Raum WC: 20.7
2022-05-27 05:30:10.136 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Abschalttemperatur im Raum WC: 21.3
2022-05-27 05:30:12.918 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Einschalttemperatur im Raum Buero: 20.7
2022-05-27 05:30:12.921 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Abschalttemperatur im Raum Buero: 21.3
2022-05-27 05:30:14.633 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Einschalttemperatur im Raum Spielzimmer: 20.7
2022-05-27 05:30:14.636 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Abschalttemperatur im Raum Spielzimmer: 21.3
2022-05-27 05:30:16.456 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Einschalttemperatur im Raum Kinderzimmer: 20.7
2022-05-27 05:30:16.465 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Abschalttemperatur im Raum Kinderzimmer: 21.3
2022-05-27 05:30:18.296 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Einschalttemperatur im Raum Schlafzimmer: 20.7
2022-05-27 05:30:18.298 [INFO ] [inschaltwert an ein Shelly versenden] - Neue Abschalttemperatur im Raum Schlafzimmer: 21.3
We see that the lower/upper temperatures were calculated for the room “Keller” as we can see in the message at 2022-05-27 05:30:01.045
but this information is not further propagated. The rule Einschaltwert an ein Shelly versenden
is not calculated for this room.
Is this probably a threading issue? I hoped to workaround this issue with the Thread:sleep(1000)
command in the rule Fussbodenheizung: Abschalt-/Einschaltwert neu berechnen
but it did not help.
Any ideas?
Best,
Oliver
PS. Parts of the code are inspired from this project Thermostatsteuerung by kriwanek
