Need some help with setting up communication between OH2 items and Loxone “items”. Anyone got this working?
not sure but do you mean that you have a loxone binding when you talk about loxone items?
No, theres no loxone binding yet. I was able to get it working using the loxone restful service
Hi, would you mind writing a small guide how you got it working exactly? I have a Loxone installation at my home but would like to add some functionality through an OpenHab installation. But a small guide would help to get me started
We’re working on a small test case for loxone. So far, we’re able to put a lamp on/off. And dim another one. But I still need to figure out how the slider in openhab should read the current state of the lights. See below
So far the items
Switch LAMP01_ONOFF "Dinertable" <light> (HouseAll) { http=">[ON:POST:http://USER:PWD@IPLOXONE/dev/sps/io/MODULEID/RELAYID/on] >[OFF:POST:http://USER:PWD@IPLOXONE/dev/sps/io/MODULEID/RELAYID/off]" }
Dimmer LAMP02_DIM "Sfeer" <light> (HouseAll) { http=">[*:POST:http://USER:PWD@IPLOXONE/dev/sps/io/MODULEID/RELAYID/%2$s]" }
The sitemap:
Switch item=LAMP01_ONOFF
Slider item=LAMP02_DIM
Of course, in this example, change following:
- USER = Your user (fe admin)
- PWD= Your password (fe admin123)
- IPLOXONE= IP-adress (or hostname) of your loxone server (fe 192.168.0.2)
- MODULEID= address for module (fe 33c7ce60-db3e-11e2-91abde49cd04c455)
- RELAYID= address of your light/relay (fe AI2)
Next, I need to figure out how I can make the slider represent the same value as the current state. I can already read the value with following http string. If somebody can help me out how this can be ‘translated’ into the slider…
http://USER:PWD@IPLOXONE/dev/sps/io/MODULEID/RELAYID/astate
