Hi Everyone i have already setup my system its being running fine for over 3 month i have obviously made changes to the system before and recently but now i’m getting this response when trying to access localhost:8080 any ideas how too fix this or find whats going wrong im running OH v2.2 on windows
i read a post saying people received this error when there was a error in there items file
i have removed my .items file and restarted OH still getting this error i have also deleted folders Cache & Temp none of these solved my problem so i restored them after testing
Problem accessing /start/index. Reason:
Server Error
Caused by:
java.lang.NullPointerException
at org.openhab.ui.dashboard.internal.DashboardService.getLocalizedText(DashboardService.java:240)
at org.openhab.ui.dashboard.internal.DashboardServlet.lambda$0(DashboardServlet.java:203)
at org.openhab.ui.dashboard.internal.DashboardServlet.replaceKeysWithFunction(DashboardServlet.java:217)
at org.openhab.ui.dashboard.internal.DashboardServlet.replaceKeysWithLocaleFunction(DashboardServlet.java:203)
at org.openhab.ui.dashboard.internal.DashboardServlet.serveDashboard(DashboardServlet.java:114)
at org.openhab.ui.dashboard.internal.DashboardServlet.doGet(DashboardServlet.java:80)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
at org.eclipse.jetty.server.Server.handle(Server.java:534)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108)
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589)
at java.lang.Thread.run(Unknown Source)
Powered by Jetty:// 9.3.22.v20171030
hi dim thanks for reply the error is displayed straight in my browser when trying to access localhost:8080 i cannot access any ui error also displayed in karaf
at org.openhab.ui.dashboard.internal.DashboardService.getLocalizedText(DashboardService.java:240) ~[189:org.openhab.ui.dashboard:2.2.0]
at org.openhab.ui.dashboard.internal.DashboardServlet.lambda$0(DashboardServlet.java:203) ~[189:org.openhab.ui.dashboard:2.2.0]
at org.openhab.ui.dashboard.internal.DashboardServlet.replaceKeysWithFunction(DashboardServlet.java:217) [189:org.openhab.ui.dashboard:2.2.0]
at org.openhab.ui.dashboard.internal.DashboardServlet.replaceKeysWithLocaleFunction(DashboardServlet.java:203) [189:org.openhab.ui.dashboard:2.2.0]
at org.openhab.ui.dashboard.internal.DashboardServlet.serveDashboard(DashboardServlet.java:114) [189:org.openhab.ui.dashboard:2.2.0]
at org.openhab.ui.dashboard.internal.DashboardServlet.doGet(DashboardServlet.java:80) [189:org.openhab.ui.dashboard:2.2.0]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) [31:javax.servlet-api:3.1.0]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) [31:javax.servlet-api:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [85:org.eclipse.jetty.security:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at java.lang.Thread.run(Unknown Source) [?:?]
you should be careful and make sure that no username/password combos (or other critical info) is included.
you can remove it now from dropbox. i downloaded a copy
(so many errors are logged )
IllegalArgumentException: Network prefix length is not within bounds
did you change anything related to the IP Address of the windows host running OH2.2 recently?
any org.eclipse.smarthome.network options configured in %OPENHAB_CONF%/services/runtime.cfg?
I would do the following if I was you: Instead of trying to debug every error and clean your OH2 deployment:
Install a new, clean OH2.3 Stable release and copy over your configuration files (items, rules, etc)
Also: Try to use a static IP Address on the host running OH2.3. DHCP based could cause issues when the IP changes. I see older IP: 192.168.0.54 and newer IP: 192.168.0.76 ?
I have noticed this error myself when i was looking at a kodi machine that was offline it gave this error saying uninitialized:Network prefix length is not within bounds what does it mean?
No i have not changed any IP settings
Yes i have moved it around in the past and then realised the folder should be called openHAB
Thats strange that is not the IP assosiated with my machine it should be 192.168.0.58 and like i say i have not changed any network settings IP .76 is a Google Home Mini .54 is a amazon fire stick so none of these are hosting OH
My Setup was created by PaperUI so i dont have all the text files atm im in the process of moving them over
The machine hosting OH has never had its IP address changed its always been 192.168.0.58 and it runs 24/7 so there is no chance something else stealing the IP
A fresh start seems too have solved the problem of not being able too access the main page and brought a couple of my things back online that were stuck off because of a network error
A few more things too do yet top get my setup back too where it was
