I’m not sure you can do that with the HTTP binding. I also think you have to sent a POST and not a GET. You can try to solve you issue through a rule using the “sendHttpPostRequest” function:
rule "testcase"
Item test received update ON
sendHttpPostRequest("http://172.21.10.182//devices/1010013", "application/json", '{“name”: “GOTO_POS_CMD”, “value”: 50}')
Read through the web page you posted earlier, apparently it’s supposed to be a PUT-request, not a POST. Change to sentHttpPutRequest() and see if that works.
Because your payload contains quote marks, you have to try a bit harder to get that passed to the http action. The rules interpreter is looking at those quotemarks, and treating them like it does any other quotemark. “Ooh, a string that starts here and stops there.”
rule "testcase"
var url = "http://172.21.10.182/devices/1010013"
var contenttype = "application/json"
var POSTrequest = '{“name”: “GOTO_POS_CMD”, “value”: 20}'
var output = sendHttpPostRequest(url, contenttype, POSTrequest)
rule "testcase"
var PUTrequest = '{"name": "GOTO_POS_CMD", "value": 20}'
var output = sendHttpPutRequest(url, contenttype, PUTrequest)
2020-01-24 11:02:26.741 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'home2.sitemap' has errors, therefore ignoring it: [2,2]: required (...)+ loop did not match anything at input 'switch'
2020-01-24 11:02:44.822 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home2.items'
2020-01-24 11:02:53.767 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'home2.sitemap' has errors, therefore ignoring it: [2,2]: required (...)+ loop did not match anything at input 'switch'
2020-01-24 11:02:58.508 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'home2.sitemap' has errors, therefore ignoring it: [2,2]: required (...)+ loop did not match anything at input 'switch'
2020-01-24 11:04:19.930 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'home.sitemap' has errors, therefore ignoring it: [44,1]: no viable alternative at input 'switch'
2020-01-24 11:04:50.326 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.sitemap'
2020-01-24 11:05:26.350 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.sitemap'
2020-01-24 11:05:33.630 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home2.sitemap'
2020-01-24 13:45:15.957 [WARN ] [.core.internal.folder.FolderObserver] - Error while opening file during update: C:\openHAB\conf\rules\testcase.rules
2020-01-24 13:45:16.342 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'testcase.rules'
2020-01-24 13:45:16.342 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'testcase.rules' is either empty or cannot be parsed correctly!
2020-01-24 13:45:17.584 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'testcase.rules' has errors, therefore ignoring it: [1,6]: no viable alternative at input 'â'
It means it doesn’t like the content of your rules file.
Given the funny character, you probably need to look into the character encoding your editor uses when it saves a file.
rule “testcase”
