Http get?
This item used to work:
Switch x300_rele_1_1 “Varmer kontroll” { http=“>[ON:GET:http://10.0.10.15/state.xml?relay1State=1&noReply=1] >[ON:GET:http://10.0.10.15/state.xml?relay1State=0&noReply=1]” }
Is the formatting changed?
I can switch the relays using http://10.0.10.15/state.xml?relay1State=1&noReply=1
Do you mean?
Because both binding definition are for ON
And I believe there should be a coma between each
Switch x300_rele_1_1 “Varmer kontroll” { http=">[ON:GET:http://10.0.10.15/state.xml?relay1State=1&noReply=1], >[OFF:GET:http://10.0.10.15/state.xml?relay1State=0&noReply=1]" }
Sorry, copy error.
The item that used to work:
Switch x300_rele_1_2 “Overstyr lokal termostat” { http=“>[ON:GET:http://10.0.10.15/state.xml?relay2State=1&noReply=1] >[OFF:GET:http://10.0.10.15/state.xml?relay2State=0&noReply=1]” }
And I have tried to change GET with POST…
According to binding doc, its no coma..:
Switch MyItem1 { http=“>[ON:POST:http://sample.com/myitem1:on] >[OFF:POST:http://sample.com/myitem1:off]” }
Does your item accept POST requests?
It says GET and therefor I have used that, but now I got no respons…
Please try to use code fences it makes reading easier and avoids smart quotation.
Is there a blank between > and [ I remember that the binding was a bit picky with the blanks and so on. Also, there has to be a single blank between the two commands only.
Thanks, I did not know..
Here’s the item:
Switch x300_rele_1_2 "Overstyr lokal termostat" { http=">[ON:GET:http://10.0.10.15/state.xml?relay2State=1&noReply=1] >[OFF:GET:http://10.0.10.15/state.xml?relay2State=0&noReply=1]" }
So when I put: http://10.0.10.15/state.xml?relay2State=1&noReply=1 in a browser the relay switch…
Used to work, did you change any other items in the file? Sometimes it happens when there is a error that the file is not processed anymore, but I have had this only with rule files until now.
Question is what did you change?
Yes, I didnt use this these items since last summer because its for my poolcontrol. In the mean time I’ve installed OH 2.2 and can’t remember which version OH I had…
These items has just been in the items file..All the read items (temperatures) from this device are working…
