urban4
(Ulrich Urban)
October 22, 2016, 7:09pm
#1
Dear users,
has anybody the same problem?
Set-Up:
raspberry 2
java version “1.8.0” Java™ SE Runtime Environment (build 1.8.0-b132)
openhab 2 , HTTP Binding, binding-http - 1.9.0.b4
I thing that has something to do with java.
Can anybody help?
Greetings
urban4
(Ulrich Urban)
November 15, 2016, 2:24pm
#2
Dear users,
unfortunately it seems nobody has this error. Mabey the reason is a wrong java version??
My question is: Can somebody can give the correct setup to run openhab 2 on raspberry pi 2 with wheezy?
Which java is necessary on rpi2 and wheezy. Please send me a link or better an installation manual.
Greetings!
urban4
(Ulrich Urban)
November 15, 2016, 3:15pm
#3
Dear users,
i’ ve updated java 8 - now it works. I’m not sure if this was the reason.
Greetings!
esdeboer
(Eric de Boer)
February 1, 2017, 10:05pm
#4
For other people stumbling across this, if you want to use OpenJDK you need to add either the JCE from Oracle or from http://www.bouncycastle.org/java.html . see
http://justrocketscience.com/post/install-bouncy-castle
(And if you get this on freebsd, you also need to set your JAVA_HOME variable, as otherwise it is not set correctly by openhab, at least on 2.0)
