My .items file has the following record:
Number Ugenerated_0 "Генерация [%.0f В]" <inverter> (MAPGEN1)
{ http="<[http://192.168.4.200/value.html?value=u_generated&mapno=1:5000:JS(n.js)] >[*:GET:http://192.168.4.200/rest.html?cmd=u_generated&mapno=1&volt=%2$.0f]"}
which I want to use both to read and update the value via HTTP Binding
The “in” part works OK, but the "out@ generates error
java.util.IllegalFormatConversionException: f != org.openhab.core.library.types.DecimalType
If I understand it right - there is a mismatch between %.0f formatter specification and Openhab Decimaltype.
The actial value of Ugenarated_0 = 220
I found a workaround via .rules, but looking for direct solution of this problem
