Using openhab3.RC1 and tried to play around with my HTTP-items a bit, but am lost…
Still trying to find my way in UI-based configuration!
I’d like to simply get the answer of an http-request into an item.
thanks for the hint, I don’t know it’s the default? or did I change it? thought it was secs, not msecs.
the only thing I can see, is you have an stateTransformation, but I’d like to have the http-response (JSON) as a whole in the string and then do the magic in a rule (because the response could be empty sometime after Covid and I only need the warnings for my region…)
Hi there!
I also started with OH3 with some of my http items.
For me it is not possible to define a channel via textual configuration. Could someone give me a working example config?
Thing definition is ok and working, but the defined channel does not appear in the UI and nothing happens to the linked items…
It looks like i was able to solve my problem.
Channel definition has to be done with predefined channel type definitions, so Type string : xxx
has to be used!
