i3creations
(Michael Crandall)
1
I’m new to openHAB. I would like to make the following http request using the httpbinding but it does not appear to work:
http://10.0.0.251:5984/dev_home_data_v2/_design/views/_view/get_latest_temp_humid_by_iot_id?startkey=[“ESP0007”]&endkey=[“ESP0007”,{}]
I suspect it is due to the square brackets and curly braces. Is there a way to escape these special characters?
Thanks for your help in advance!
rlkoshak
(Rich Koshak)
2
Yes. Here is a link to the full map. You will want:
- [ = %5B
- ] = %5D
- { = %7B
- } = %7D
ranielsen
(Rob Nielsen)
3
i3creations
(Michael Crandall)
4
Thanks for the help! Not only did I need to escape the braces, I also then had to escape the percentage symbol because the httpbinding is expecting a parameter. Here is the final working escaped url for anyone that runs into this:
http://10.0.0.251:5984/dev_home_data_v2/_design/views/_view/get_latest_temp_humid_by_iot_id?startkey=%[%"ESP0007%"%]&endkey=%[%"ESP0007%",%{%}%]
NCO
(E. Gerland)
5
Does this also apply to REGEX?
I would like to extract “plugged” from curl:
The result of curl looks like this:
Battery level |
47% (plugged) |
I tried:
val String plugged = transform(“REGEX”, “.% %%28(…).”, json) - ascii replacement for (
val String plugged = transform(“REGEX”, “.% ((…).”, json) - escaping (
val String plugged = transform(“REGEX”, “.%%25%%20%%28(…).”, json)
none of these work.
So how to look for “% (” and extract the next 7 characters?
EDIT:
Got it:
I needed to double escape the “(”
val String plugged = transform("REGEX", ".*% \\((.......).*", json)
