Hi guys,
I’m developing a binding that retrieves data via http from two different sources - cloud API and local IP address… as said in the dev guidelines I should retrieve the http client centrally.
I wanted to ask you do I have to call the start() before use and should I call always stop() after finishing use?
From what I see in AbstractLifeCycle class in Jetty it is used to do call some “after” methods in the registered listeners but not sure if there are any other means for this.
What is the best practice here and how do you use it if you’re not using listeners in your code? I guess it’s not necessary in such a case…
Cheers,
K.
