Hi all,
I am currently in the process of adding Hue light bulbs to my setup.
I have the A60 Hue LED bulbs and these are being discovered with only two channels, Brightness (Dimmer) and Alert (String).
With my other lights I am able to offer a slider and a switch for each bulb so that users can turn on and off as well as set the percentage.
How do you do this with the Hue A60’s?
I also have no idea what the Alert Channel so so off to see if I can work that out…
Paul
