just added a Hue Dimmer Switch to my installation, using OpenHAB v4.0.3.
I’m getting the channel trigger events for button-last-event in my rule, but the button_id is missing.
Means receivedEvent.toString() reports 0, 1, 3 etc.
According to doc it should be:
value = (button_id * 1000) + event_id;
rule is looking like this:
rule "Hue Dimmer 1 - button last event"
Channel "hue:device:.....:button-last-event" triggered
logInfo("Info", "Hue Dimmer 1: button last event: " + receivedEvent.toString())
Debug shows the same.
Interesting: With an additional Hue button switch everything works as expected (e.g. getting 1002 etc.)
This is what my Hue dimmer switch shows on 4.1M3 with Hue binding api version 2:
rule "Hue dimmer switch 1 event handling"
Channel "hue:device:huewz:18514abc-....:button-last-event" triggered
logInfo("EXTRA", "Dimmer switch event {}", receivedEvent)
switch(receivedEvent) {
case "1000": {
logInfo("EXTRA", "BTN ON INITIAL_PRESSED")
case "1001": {
logInfo("EXTRA", "BTN ON HOLD")
case "1002": {
logInfo("EXTRA", "BTN ON SHORT RELEASED")
case "1003": {
logInfo("EXTRA", "BTN ON LONG RELEASED")
case "2000": {
logInfo("EXTRA", "BTN Up LONG RELEASED")
case "2001": {
case "2002": {
case "2003": {
case "3000": {
logInfo("EXTRA", "BTN Down LONG RELEASED")
case "3001": {
case "3002": {
case "3003": {
case "4000": {
logInfo("EXTRA", "BTN OFF LONG RELEASED")
case "4001": {
case "4002": {
case "4003": {
2023-11-06 19:58:01.792 [INFO ] [org.openhab.core.model.script.EXTRA ] - BTN ON INITIAL_PRESSED
2023-11-06 19:58:02.819 [INFO ] [org.openhab.core.model.script.EXTRA ] - Dimmer switch event 1002
2023-11-06 19:58:02.819 [INFO ] [org.openhab.core.model.script.EXTRA ] - BTN ON SHORT RELEASED
2023-11-06 19:58:02.820 [INFO ] [org.openhab.core.model.script.EXTRA ] - Dimmer switch event 2000
2023-11-06 19:58:02.820 [INFO ] [org.openhab.core.model.script.EXTRA ] - BTN Up LONG RELEASED
2023-11-06 19:58:03.827 [INFO ] [org.openhab.core.model.script.EXTRA ] - Dimmer switch event 2002
2023-11-06 19:58:03.827 [INFO ] [org.openhab.core.model.script.EXTRA ] - BTN Up LONG RELEASED
2023-11-06 19:58:03.828 [INFO ] [org.openhab.core.model.script.EXTRA ] - Dimmer switch event 3000
2023-11-06 19:58:03.828 [INFO ] [org.openhab.core.model.script.EXTRA ] - BTN Down LONG RELEASED
2023-11-06 19:58:03.828 [INFO ] [org.openhab.core.model.script.EXTRA ] - Dimmer switch event 3002
2023-11-06 19:58:04.835 [INFO ] [org.openhab.core.model.script.EXTRA ] - Dimmer switch event 4000
2023-11-06 19:58:04.835 [INFO ] [org.openhab.core.model.script.EXTRA ] - BTN OFF LONG RELEASED
2023-11-06 19:58:04.835 [INFO ] [org.openhab.core.model.script.EXTRA ] - Dimmer switch event 4002
2023-11-06 19:58:04.836 [INFO ] [org.openhab.core.model.script.EXTRA ] - BTN OFF LONG RELEASED
2023-11-06 19:58:05.845 [INFO ] [org.openhab.core.model.script.EXTRA ] - Dimmer switch event 1000
2023-11-06 19:58:05.845 [INFO ] [org.openhab.core.model.script.EXTRA ] - BTN ON INITIAL_PRESSED
2023-11-06 19:58:05.846 [INFO ] [org.openhab.core.model.script.EXTRA ] - Dimmer switch event 1002
2023-11-06 19:58:05.846 [INFO ] [org.openhab.core.model.script.EXTRA ] - BTN ON SHORT RELEASED
2023-11-06 19:58:05.846 [INFO ] [org.openhab.core.model.script.EXTRA ] - Dimmer switch event 1000
2023-11-06 19:58:05.846 [INFO ] [org.openhab.core.model.script.EXTRA ] - BTN ON INITIAL_PRESSED
2023-11-06 19:58:06.848 [INFO ] [org.openhab.core.model.script.EXTRA ] - Dimmer switch event 1001
2023-11-06 19:58:06.848 [INFO ] [org.openhab.core.model.script.EXTRA ] - BTN ON HOLD
2023-11-06 19:58:07.853 [INFO ] [org.openhab.core.model.script.EXTRA ] - Dimmer switch event 1001
2023-11-06 19:58:07.853 [INFO ] [org.openhab.core.model.script.EXTRA ] - BTN ON HOLD
2023-11-06 19:58:08.858 [INFO ] [org.openhab.core.model.script.EXTRA ] - Dimmer switch event 1003
2023-11-06 19:58:08.859 [INFO ] [org.openhab.core.model.script.EXTRA ] - BTN ON LONG RELEASED
2023-11-06 19:58:09.867 [INFO ] [org.openhab.core.model.script.EXTRA ] - Dimmer switch event 4000
2023-11-06 19:58:09.867 [INFO ] [org.openhab.core.model.script.EXTRA ] - BTN OFF LONG RELEASED
2023-11-06 19:58:10.871 [INFO ] [org.openhab.core.model.script.EXTRA ] - Dimmer switch event 4001
2023-11-06 19:58:10.871 [INFO ] [org.openhab.core.model.script.EXTRA ] - BTN OFF LONG RELEASED
2023-11-06 19:58:11.877 [INFO ] [org.openhab.core.model.script.EXTRA ] - Dimmer switch event 4001
2023-11-06 19:58:11.877 [INFO ] [org.openhab.core.model.script.EXTRA ] - BTN OFF LONG RELEASED
