So I finally broke down and installed the Eclipse IDE. However, it appears that the UI omits the Hue binding.
The files are there in the filesystem, and I can open them via File > Open, but if I then right-click the opened file and select Show In > Package Explorer, I get a windows error ding and nothing changes…
@namraccr This binding is for OH1 from what I understand? If you need source code access it is available via Github. I’ve just been looking through many hue issues trying to understand the state of the binding, the newer one now lives with eclipse in their ESH repo. You may find this issue comment I made helpful(at least for the links). I’m interested in seeing some more support added to the binding(specifically bridge groups), been told to create a new issue for it which you can find here.
