Hue bulb changing color wrongly when brightness is 0
I downloaded the 4.2 milestone build, started OH, run through the setup wizard and then placed your jar file into the addons folder.
I still receive an error message:
18:01:19.752 [WARN ] [org.apache.felix.fileinstall         ] - Error while starting bundle: file:/C:/openhab-4.2.0.M1/addons/org.openhab.binding.hue-4.2.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.hue [266]
  Unresolved requirement: Import-Package: org.openhab.core.config.discovery.upnp
        at org.eclipse.osgi.container.Module.start(Module.java:463) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:445) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.7.4]
        at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.7.4]
        at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [bundleFile:3.7.4]
        at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.7.4]
        at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.7.4]
Only after manually adding the upnp binding discovery is working:
18:04:14.571 [INFO ] [openhab.event.InboxAddedEvent        ] - Discovery Result with UID 'hue:bridge-api2:ecb5fafffe8c6257' has been added.
18:04:14.571 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'hue:bridge-api2:ecb5fafffe8c6257' to inbox.
Once adding the thing, it stayed in OFFLINE (Configuration Error) as I need to authenticate.
After pressing the button on the hue bridge the application key was added to the thing, but the thing remained in OFFLINE (Configuration Error) state. Only manually disabling and enabling the thing helped to get the thing online.
Regarding the color issue, sending e.g. “36,54,0” as command to an item linked to the color channel still not working as expected and the light is again changing color (but now to a different color than with the previous version).
Please find the log below.
Let me know if I should test something else.
18:15:40.952 [INFO ] [openhab.event.ItemCommandEvent       ] - Item 'Stehlampe_Wohnzimmer_Farbe' received command 36,54,100
18:15:40.959 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> handleCommand() put resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:40.964 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - putResource() id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:40.966 [TRACE] [g.hue.internal.connection.Clip2Bridge] - PUT https://xxx/clip/v2/resource/light/311a715a-e54e-4c1b-9114-3e8d4a416b1d HTTP/2 >> {"type":"light","id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","on":{"on":true},"dimming":{"brightness":100.0},"color":{"xy":{"x":0.4661,"y":0.4039}}}
18:15:41.051 [TRACE] [g.hue.internal.connection.Clip2Bridge] - HTTP/2 200 (Content-Type: application/json) << {"data":[{"rid":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","rtype":"light"}],"errors":[]}
18:15:41.074 [TRACE] [g.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2024-03-10T17:15:42Z","data":[{"dimming":{"brightness":100.0},"id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","id_v1":"/lights/3","owner":{"rid":"0d1d1f4b-fef2-4171-9e26-020c15ce3555","rtype":"device"},"service_id":0,"type":"light"},{"color":{"xy":{"x":0.4661,"y":0.4039}},"color_temperature":{"mirek":null,"mirek_valid":false},"id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","id_v1":"/lights/3","owner":{"rid":"0d1d1f4b-fef2-4171-9e26-020c15ce3555","rtype":"device"},"service_id":0,"type":"light"}],"id":"ff6a7002-23ad-413b-be78-1832fc93cd59","type":"update"}]
18:15:41.075 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - onResourcesEventTask() resource count 2
18:15:41.076 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateChannels() from resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:41.078 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature' update with 'UNDEF' (fullUpdate:false, isDefined:true)
18:15:41.078 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature-abs' update with 'UNDEF' (fullUpdate:false, isDefined:true)
18:15:41.079 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color' update with '35.994,53.9900,100' (fullUpdate:false, isDefined:true)
18:15:41.080 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-xy-only' update with '35.994,53.9900,100' (fullUpdate:false, isDefined:true)
18:15:41.081 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'effect' update with 'NO_EFFECT' (fullUpdate:false, isDefined:true)
18:15:41.081 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Stehlampe_Wohnzimmer_Farbe' changed from 35.969,44.69500,20.16 to 35.994,53.9900,100
18:15:41.082 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'dimming-only' update with '100' (fullUpdate:false, isDefined:true)
18:15:41.082 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'on-off-only' update with 'ON' (fullUpdate:false, isDefined:true)
18:15:41.083 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'alert' update with 'NO_ACTION' (fullUpdate:false, isDefined:true)
18:15:41.084 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'last-updated' update with '2024-03-10T18:15:41.083907800+0100' (fullUpdate:false, isDefined:true)
18:15:41.085 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> onResource() consumed resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:41.085 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateChannels() from resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:41.086 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature' update with 'UNDEF' (fullUpdate:false, isDefined:true)
18:15:41.086 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature-abs' update with 'UNDEF' (fullUpdate:false, isDefined:true)
18:15:41.087 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color' update with '35.994,53.9900,100' (fullUpdate:false, isDefined:true)
18:15:41.088 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-xy-only' update with '35.994,53.9900,100' (fullUpdate:false, isDefined:true)
18:15:41.090 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'effect' update with 'NO_EFFECT' (fullUpdate:false, isDefined:true)
18:15:41.091 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'dimming-only' update with '100' (fullUpdate:false, isDefined:true)
18:15:41.092 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'on-off-only' update with 'ON' (fullUpdate:false, isDefined:true)
18:15:41.093 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'alert' update with 'NO_ACTION' (fullUpdate:false, isDefined:true)
18:15:41.094 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'last-updated' update with '2024-03-10T18:15:41.094902+0100' (fullUpdate:false, isDefined:true)
18:15:41.095 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> onResource() consumed resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:42.167 [TRACE] [g.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2024-03-10T17:15:42Z","data":[{"dimming":{"brightness":100.0},"id":"1d44eebc-15e1-4c6a-9801-b0516c194311","id_v1":"/groups/0","owner":{"rid":"675e35c8-9633-42a0-ab61-31fec33bb225","rtype":"bridge_home"},"type":"grouped_light"},{"dimming":{"brightness":100.0},"id":"6f687ae6-183d-4523-a2fd-9685bd61073a","id_v1":"/groups/2","owner":{"rid":"2e91e911-bf8a-4e99-92c3-a6b9ff34dfe0","rtype":"room"},"type":"grouped_light"},{"dimming":{"brightness":100.0},"id":"acfda9c7-658f-4bd7-8ce0-7ea440f57c4c","id_v1":"/groups/1","owner":{"rid":"afe31e22-7273-47f9-9f90-9d4bc3c796fe","rtype":"zone"},"type":"grouped_light"}],"id":"b52f2942-409e-4943-bbc8-85500cded7ef","type":"update"}]
18:15:42.168 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - onResourcesEventTask() resource count 3
18:15:45.970 [INFO ] [openhab.event.ItemCommandEvent       ] - Item 'Stehlampe_Wohnzimmer_Farbe' received command 36,54,20
18:15:45.979 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> handleCommand() put resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:45.980 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - putResource() id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:45.983 [TRACE] [g.hue.internal.connection.Clip2Bridge] - PUT https://xxx/clip/v2/resource/light/311a715a-e54e-4c1b-9114-3e8d4a416b1d HTTP/2 >> {"type":"light","id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","on":{"on":true},"dimming":{"brightness":20.0},"color":{"xy":{"x":0.4382,"y":0.3937}}}
18:15:46.072 [TRACE] [g.hue.internal.connection.Clip2Bridge] - HTTP/2 200 (Content-Type: application/json) << {"data":[{"rid":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","rtype":"light"}],"errors":[]}
18:15:46.092 [TRACE] [g.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2024-03-10T17:15:47Z","data":[{"dimming":{"brightness":20.16},"id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","id_v1":"/lights/3","owner":{"rid":"0d1d1f4b-fef2-4171-9e26-020c15ce3555","rtype":"device"},"service_id":0,"type":"light"},{"color":{"xy":{"x":0.4382,"y":0.3937}},"color_temperature":{"mirek":null,"mirek_valid":false},"id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","id_v1":"/lights/3","owner":{"rid":"0d1d1f4b-fef2-4171-9e26-020c15ce3555","rtype":"device"},"service_id":0,"type":"light"}],"id":"4fbc5552-40e0-4326-903a-10afacb6bd70","type":"update"}]
18:15:46.094 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - onResourcesEventTask() resource count 2
18:15:46.094 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateChannels() from resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:46.095 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature' update with 'UNDEF' (fullUpdate:false, isDefined:true)
18:15:46.095 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature-abs' update with 'UNDEF' (fullUpdate:false, isDefined:true)
18:15:46.096 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color' update with '35.983,44.6700,20.16' (fullUpdate:false, isDefined:true)
18:15:46.097 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-xy-only' update with '35.983,44.6700,100' (fullUpdate:false, isDefined:true)
18:15:46.098 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'effect' update with 'NO_EFFECT' (fullUpdate:false, isDefined:true)
18:15:46.099 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Stehlampe_Wohnzimmer_Farbe' changed from 35.994,53.9900,100 to 35.983,44.6700,20.16
18:15:46.099 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'dimming-only' update with '20.16' (fullUpdate:false, isDefined:true)
18:15:46.099 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'on-off-only' update with 'ON' (fullUpdate:false, isDefined:true)
18:15:46.100 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'alert' update with 'NO_ACTION' (fullUpdate:false, isDefined:true)
18:15:46.100 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'last-updated' update with '2024-03-10T18:15:46.100607300+0100' (fullUpdate:false, isDefined:true)
18:15:46.101 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> onResource() consumed resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:46.101 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateChannels() from resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:46.101 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature' update with 'UNDEF' (fullUpdate:false, isDefined:true)
18:15:46.102 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature-abs' update with 'UNDEF' (fullUpdate:false, isDefined:true)
18:15:46.102 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color' update with '35.983,44.6700,20.16' (fullUpdate:false, isDefined:true)
18:15:46.103 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-xy-only' update with '35.983,44.6700,100' (fullUpdate:false, isDefined:true)
18:15:46.104 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'effect' update with 'NO_EFFECT' (fullUpdate:false, isDefined:true)
18:15:46.106 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'dimming-only' update with '20.16' (fullUpdate:false, isDefined:true)
18:15:46.107 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'on-off-only' update with 'ON' (fullUpdate:false, isDefined:true)
18:15:46.108 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'alert' update with 'NO_ACTION' (fullUpdate:false, isDefined:true)
18:15:46.109 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'last-updated' update with '2024-03-10T18:15:46.108606+0100' (fullUpdate:false, isDefined:true)
18:15:46.109 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> onResource() consumed resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:47.104 [TRACE] [g.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2024-03-10T17:15:47Z","data":[{"dimming":{"brightness":35.18},"id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","id_v1":"/lights/3","owner":{"rid":"0d1d1f4b-fef2-4171-9e26-020c15ce3555","rtype":"device"},"service_id":0,"type":"light"}],"id":"2ae964e8-6229-47ac-adcd-9e160391eb36","type":"update"},{"creationtime":"2024-03-10T17:15:47Z","data":[{"dimming":{"brightness":67.59},"id":"1d44eebc-15e1-4c6a-9801-b0516c194311","id_v1":"/groups/0","owner":{"rid":"675e35c8-9633-42a0-ab61-31fec33bb225","rtype":"bridge_home"},"type":"grouped_light"},{"dimming":{"brightness":67.59},"id":"6f687ae6-183d-4523-a2fd-9685bd61073a","id_v1":"/groups/2","owner":{"rid":"2e91e911-bf8a-4e99-92c3-a6b9ff34dfe0","rtype":"room"},"type":"grouped_light"},{"dimming":{"brightness":67.59},"id":"acfda9c7-658f-4bd7-8ce0-7ea440f57c4c","id_v1":"/groups/1","owner":{"rid":"afe31e22-7273-47f9-9f90-9d4bc3c796fe","rtype":"zone"},"type":"grouped_light"}],"id":"6766de86-fb8c-434b-a252-33d1977cad4f","type":"update"}]
18:15:47.105 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - onResourcesEventTask() resource count 4
18:15:47.106 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateChannels() from resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:47.107 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature' update with 'UNDEF' (fullUpdate:false, isDefined:true)
18:15:47.107 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature-abs' update with 'UNDEF' (fullUpdate:false, isDefined:true)
18:15:47.108 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color' update with '35.983,44.6700,35.18' (fullUpdate:false, isDefined:true)
18:15:47.109 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-xy-only' update with '35.983,44.6700,100' (fullUpdate:false, isDefined:true)
18:15:47.110 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'effect' update with 'NO_EFFECT' (fullUpdate:false, isDefined:true)
18:15:47.110 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'dimming-only' update with '35.18' (fullUpdate:false, isDefined:true)
18:15:47.111 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'on-off-only' update with 'ON' (fullUpdate:false, isDefined:true)
18:15:47.111 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'alert' update with 'NO_ACTION' (fullUpdate:false, isDefined:true)
18:15:47.112 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'last-updated' update with '2024-03-10T18:15:47.112630500+0100' (fullUpdate:false, isDefined:true)
18:15:47.113 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> onResource() consumed resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:47.117 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Stehlampe_Wohnzimmer_Farbe' changed from 35.983,44.6700,20.16 to 35.983,44.6700,35.18
18:15:48.210 [TRACE] [g.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2024-03-10T17:15:49Z","data":[{"color":{"xy":{"x":0.4451,"y":0.4056}},"color_temperature":{"mirek":343,"mirek_valid":true},"id":"e843d025-ee05-479a-bdc2-1b8e2c371544","id_v1":"/lights/4","owner":{"rid":"db72bc81-cd03-4292-ba84-4f1ab2947b05","rtype":"device"},"service_id":0,"type":"light"}],"id":"87f9813c-8c67-4435-9d87-188afca3bc05","type":"update"}]
18:15:48.212 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - onResourcesEventTask() resource count 1
18:15:49.130 [TRACE] [g.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2024-03-10T17:15:49Z","data":[{"dimming":{"brightness":20.16},"id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","id_v1":"/lights/3","owner":{"rid":"0d1d1f4b-fef2-4171-9e26-020c15ce3555","rtype":"device"},"service_id":0,"type":"light"}],"id":"7693d323-1803-4b00-a9c1-290485741fa5","type":"update"},{"creationtime":"2024-03-10T17:15:50Z","data":[{"dimming":{"brightness":60.08},"id":"1d44eebc-15e1-4c6a-9801-b0516c194311","id_v1":"/groups/0","owner":{"rid":"675e35c8-9633-42a0-ab61-31fec33bb225","rtype":"bridge_home"},"type":"grouped_light"},{"dimming":{"brightness":60.08},"id":"6f687ae6-183d-4523-a2fd-9685bd61073a","id_v1":"/groups/2","owner":{"rid":"2e91e911-bf8a-4e99-92c3-a6b9ff34dfe0","rtype":"room"},"type":"grouped_light"},{"dimming":{"brightness":60.08},"id":"acfda9c7-658f-4bd7-8ce0-7ea440f57c4c","id_v1":"/groups/1","owner":{"rid":"afe31e22-7273-47f9-9f90-9d4bc3c796fe","rtype":"zone"},"type":"grouped_light"}],"id":"64f4c351-cc62-4b8b-92a8-06bef65d466b","type":"update"}]
18:15:49.131 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - onResourcesEventTask() resource count 4
18:15:49.132 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateChannels() from resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:49.132 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature' update with 'UNDEF' (fullUpdate:false, isDefined:true)
18:15:49.133 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature-abs' update with 'UNDEF' (fullUpdate:false, isDefined:true)
18:15:49.133 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color' update with '35.983,44.6700,20.16' (fullUpdate:false, isDefined:true)
18:15:49.134 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-xy-only' update with '35.983,44.6700,100' (fullUpdate:false, isDefined:true)
18:15:49.136 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Stehlampe_Wohnzimmer_Farbe' changed from 35.983,44.6700,35.18 to 35.983,44.6700,20.16
18:15:49.136 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'effect' update with 'NO_EFFECT' (fullUpdate:false, isDefined:true)
18:15:49.137 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'dimming-only' update with '20.16' (fullUpdate:false, isDefined:true)
18:15:49.139 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'on-off-only' update with 'ON' (fullUpdate:false, isDefined:true)
18:15:49.141 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'alert' update with 'NO_ACTION' (fullUpdate:false, isDefined:true)
18:15:49.142 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'last-updated' update with '2024-03-10T18:15:49.142972300+0100' (fullUpdate:false, isDefined:true)
18:15:49.144 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> onResource() consumed resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:49.866 [INFO ] [openhab.event.ItemCommandEvent       ] - Item 'Stehlampe_Wohnzimmer_Farbe' received command 36,54,0
18:15:49.875 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> handleCommand() put resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:49.877 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - putResource() id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:49.878 [TRACE] [g.hue.internal.connection.Clip2Bridge] - PUT https://xxx/clip/v2/resource/light/311a715a-e54e-4c1b-9114-3e8d4a416b1d HTTP/2 >> {"type":"light","id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","on":{"on":false},"dimming":{"brightness":0.2},"color":{"xy":{"x":0.3227,"y":0.329}}}
18:15:49.961 [TRACE] [g.hue.internal.connection.Clip2Bridge] - HTTP/2 200 (Content-Type: application/json) << {"data":[{"rid":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","rtype":"light"}],"errors":[]}
18:15:50.154 [TRACE] [g.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2024-03-10T17:15:51Z","data":[{"id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","id_v1":"/lights/3","on":{"on":false},"owner":{"rid":"0d1d1f4b-fef2-4171-9e26-020c15ce3555","rtype":"device"},"service_id":0,"type":"light"},{"dimming":{"brightness":0.4},"id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","id_v1":"/lights/3","owner":{"rid":"0d1d1f4b-fef2-4171-9e26-020c15ce3555","rtype":"device"},"service_id":0,"type":"light"},{"color":{"xy":{"x":0.3227,"y":0.329}},"color_temperature":{"mirek":null,"mirek_valid":false},"id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","id_v1":"/lights/3","owner":{"rid":"0d1d1f4b-fef2-4171-9e26-020c15ce3555","rtype":"device"},"service_id":0,"type":"light"}],"id":"a9a4a78e-004c-4493-9c3e-2c656dfd8ff5","type":"update"},{"creationtime":"2024-03-10T17:15:51Z","data":[{"dimming":{"brightness":100.0},"id":"1d44eebc-15e1-4c6a-9801-b0516c194311","id_v1":"/groups/0","owner":{"rid":"675e35c8-9633-42a0-ab61-31fec33bb225","rtype":"bridge_home"},"type":"grouped_light"},{"dimming":{"brightness":100.0},"id":"6f687ae6-183d-4523-a2fd-9685bd61073a","id_v1":"/groups/2","owner":{"rid":"2e91e911-bf8a-4e99-92c3-a6b9ff34dfe0","rtype":"room"},"type":"grouped_light"},{"dimming":{"brightness":100.0},"id":"acfda9c7-658f-4bd7-8ce0-7ea440f57c4c","id_v1":"/groups/1","owner":{"rid":"afe31e22-7273-47f9-9f90-9d4bc3c796fe","rtype":"zone"},"type":"grouped_light"}],"id":"2db0cba1-b444-481d-aa70-27fe6e131bd1","type":"update"}]
18:15:50.156 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - onResourcesEventTask() resource count 6
18:15:50.157 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - onResourcesEventTask() merged to 5 resources
18:15:50.158 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateChannels() from resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:50.159 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature' update with 'UNDEF' (fullUpdate:false, isDefined:true)
18:15:50.160 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature-abs' update with 'UNDEF' (fullUpdate:false, isDefined:true)
18:15:50.161 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color' update with '221.539,0.01300,0' (fullUpdate:false, isDefined:true)
18:15:50.162 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-xy-only' update with '221.539,0.01300,100' (fullUpdate:false, isDefined:true)
18:15:50.163 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'effect' update with 'NO_EFFECT' (fullUpdate:false, isDefined:true)
18:15:50.163 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Stehlampe_Wohnzimmer_Farbe' changed from 35.983,44.6700,20.16 to 221.539,0.01300,0
18:15:50.164 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'dimming-only' update with '0.4000' (fullUpdate:false, isDefined:true)
18:15:50.165 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'on-off-only' update with 'OFF' (fullUpdate:false, isDefined:true)
18:15:50.165 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'alert' update with 'NO_ACTION' (fullUpdate:false, isDefined:true)
18:15:50.165 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'last-updated' update with '2024-03-10T18:15:50.165342100+0100' (fullUpdate:false, isDefined:true)
18:15:50.166 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> onResource() consumed resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:50.166 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateChannels() from resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
18:15:50.166 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature' update with 'UNDEF' (fullUpdate:false, isDefined:true)
18:15:50.167 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature-abs' update with 'UNDEF' (fullUpdate:false, isDefined:true)
18:15:50.167 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color' update with '221.539,0.01300,0' (fullUpdate:false, isDefined:true)
18:15:50.168 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-xy-only' update with '221.539,0.01300,100' (fullUpdate:false, isDefined:true)
18:15:50.169 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'effect' update with 'NO_EFFECT' (fullUpdate:false, isDefined:true)
18:15:50.170 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'dimming-only' update with '0.4000' (fullUpdate:false, isDefined:true)
18:15:50.171 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'on-off-only' update with 'OFF' (fullUpdate:false, isDefined:true)
18:15:50.172 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'alert' update with 'NO_ACTION' (fullUpdate:false, isDefined:true)
18:15:50.173 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'last-updated' update with '2024-03-10T18:15:50.173355100+0100' (fullUpdate:false, isDefined:true)
18:15:50.174 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> onResource() consumed resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
@Matze0211 many thanks for running the tests; I know it is complicated but I appreciate your efforts.
Unfortunately your log does not show the command 36,54,0 .. it seems only to show two PUTs with dimming = 100 and dimming = 20 respectively. We would need to see the actual PUT where dimming = 0..
EDIT: oops! I see there is another PUT with dimming = 0.2..
Maybe I could have let you know, that I tested it three times , sorry.
I was unsure about the setup behavior, if that’s known/as expected and therefore added it.
Please let me know, if I can test anything else, as I now have the v4.2 environment for testing running.
Yes. The UPNP issue is known for manual installs. If you install through main UI then OH will also automatically install any dependent features (in this case UPNP) but does not do that if you drop the jar manually. And the need to authenticate the bridge on new systems is quite standard.
Yes, that was also my expectation.. However the need to disable and enable the thing after authentication was unexpected.
Oops! I had made a silly mistake. The corrected version of the Jar is here
Thanks for updating.
After sending a color command with brightness = 0, the light is still changing the color on a minimal level, but not as extreme as before.
Here is the new log (I have send two commands with 36,54,20 & 36,54,0):
21:14:09.886 [INFO ] [openhab.event.ItemCommandEvent       ] - Item 'Stehlampe_Wohnzimmer_Farbe' received command 36,54,20
21:14:09.894 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> handleCommand() put resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
21:14:09.895 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - putResource() id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
21:14:09.895 [TRACE] [g.hue.internal.connection.Clip2Bridge] - PUT https://xxx/clip/v2/resource/light/311a715a-e54e-4c1b-9114-3e8d4a416b1d HTTP/2 >> {"type":"light","id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","on":{"on":true},"dimming":{"brightness":20.0},"color":{"xy":{"x":0.4382,"y":0.3937}}}
21:14:09.978 [TRACE] [g.hue.internal.connection.Clip2Bridge] - HTTP/2 200 (Content-Type: application/json) << {"data":[{"rid":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","rtype":"light"}],"errors":[]}
21:14:10.001 [TRACE] [g.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2024-03-12T20:14:11Z","data":[{"dimming":{"brightness":20.16},"id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","id_v1":"/lights/3","owner":{"rid":"0d1d1f4b-fef2-4171-9e26-020c15ce3555","rtype":"device"},"service_id":0,"type":"light"},{"color":{"xy":{"x":0.4382,"y":0.3937}},"color_temperature":{"mirek":null,"mirek_valid":false},"id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","id_v1":"/lights/3","owner":{"rid":"0d1d1f4b-fef2-4171-9e26-020c15ce3555","rtype":"device"},"service_id":0,"type":"light"}],"id":"eb9e3785-41cf-48d6-89f7-71608d41814d","type":"update"}]
21:14:10.002 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - onResourcesEventTask() resource count 2
21:14:10.003 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateChannels() from resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
21:14:10.004 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature' update with 'UNDEF' (fullUpdate:false, isDefined:true)
21:14:10.005 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature-abs' update with 'UNDEF' (fullUpdate:false, isDefined:true)
21:14:10.005 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color' update with '35.983,44.6700,20.16' (fullUpdate:false, isDefined:true)
21:14:10.006 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-xy-only' update with '35.983,44.6700,100' (fullUpdate:false, isDefined:true)
21:14:10.007 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'effect' update with 'NO_EFFECT' (fullUpdate:false, isDefined:true)
21:14:10.007 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Stehlampe_Wohnzimmer_Farbe' changed from 35.994,53.9900,100 to 35.983,44.6700,20.16
21:14:10.007 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'dimming-only' update with '20.16' (fullUpdate:false, isDefined:true)
21:14:10.008 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'on-off-only' update with 'ON' (fullUpdate:false, isDefined:true)
21:14:10.008 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'alert' update with 'NO_ACTION' (fullUpdate:false, isDefined:true)
21:14:10.009 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'last-updated' update with '2024-03-12T21:14:10.009510100+0100' (fullUpdate:false, isDefined:true)
21:14:10.009 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> onResource() consumed resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
21:14:10.010 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateChannels() from resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
21:14:10.010 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature' update with 'UNDEF' (fullUpdate:false, isDefined:true)
21:14:10.010 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature-abs' update with 'UNDEF' (fullUpdate:false, isDefined:true)
21:14:10.011 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color' update with '35.983,44.6700,20.16' (fullUpdate:false, isDefined:true)
21:14:10.012 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-xy-only' update with '35.983,44.6700,100' (fullUpdate:false, isDefined:true)
21:14:10.013 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'effect' update with 'NO_EFFECT' (fullUpdate:false, isDefined:true)
21:14:10.013 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'dimming-only' update with '20.16' (fullUpdate:false, isDefined:true)
21:14:10.014 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'on-off-only' update with 'ON' (fullUpdate:false, isDefined:true)
21:14:10.014 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'alert' update with 'NO_ACTION' (fullUpdate:false, isDefined:true)
21:14:10.015 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'last-updated' update with '2024-03-12T21:14:10.014512200+0100' (fullUpdate:false, isDefined:true)
21:14:10.015 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> onResource() consumed resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
21:14:11.015 [TRACE] [g.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2024-03-12T20:14:11Z","data":[{"dimming":{"brightness":50.0},"id":"1d44eebc-15e1-4c6a-9801-b0516c194311","id_v1":"/groups/0","owner":{"rid":"675e35c8-9633-42a0-ab61-31fec33bb225","rtype":"bridge_home"},"type":"grouped_light"},{"dimming":{"brightness":50.0},"id":"6f687ae6-183d-4523-a2fd-9685bd61073a","id_v1":"/groups/2","owner":{"rid":"2e91e911-bf8a-4e99-92c3-a6b9ff34dfe0","rtype":"room"},"type":"grouped_light"},{"dimming":{"brightness":50.0},"id":"acfda9c7-658f-4bd7-8ce0-7ea440f57c4c","id_v1":"/groups/1","owner":{"rid":"afe31e22-7273-47f9-9f90-9d4bc3c796fe","rtype":"zone"},"type":"grouped_light"}],"id":"0d38e72f-c4e1-4146-ac4c-e562c76ed53d","type":"update"}]
21:14:11.016 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - onResourcesEventTask() resource count 3
21:14:14.983 [INFO ] [openhab.event.ItemCommandEvent       ] - Item 'Stehlampe_Wohnzimmer_Farbe' received command 36,54,0
21:14:14.991 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> handleCommand() put resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
21:14:14.991 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - putResource() id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
21:14:14.992 [TRACE] [g.hue.internal.connection.Clip2Bridge] - PUT https://xxx/clip/v2/resource/light/311a715a-e54e-4c1b-9114-3e8d4a416b1d HTTP/2 >> {"type":"light","id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","on":{"on":false},"dimming":{"brightness":0.2},"color":{"xy":{"x":0.3908,"y":0.3771}}}
21:14:15.099 [TRACE] [g.hue.internal.connection.Clip2Bridge] - HTTP/2 200 (Content-Type: application/json) << {"data":[{"rid":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","rtype":"light"}],"errors":[]}
21:14:15.106 [TRACE] [g.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2024-03-12T20:14:16Z","data":[{"id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","id_v1":"/lights/3","on":{"on":false},"owner":{"rid":"0d1d1f4b-fef2-4171-9e26-020c15ce3555","rtype":"device"},"service_id":0,"type":"light"},{"dimming":{"brightness":0.4},"id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","id_v1":"/lights/3","owner":{"rid":"0d1d1f4b-fef2-4171-9e26-020c15ce3555","rtype":"device"},"service_id":0,"type":"light"},{"color":{"xy":{"x":0.3908,"y":0.3771}},"color_temperature":{"mirek":null,"mirek_valid":false},"id":"311a715a-e54e-4c1b-9114-3e8d4a416b1d","id_v1":"/lights/3","owner":{"rid":"0d1d1f4b-fef2-4171-9e26-020c15ce3555","rtype":"device"},"service_id":0,"type":"light"}],"id":"a38dcc72-5be9-4bc9-8eed-f6bddd2bcb4a","type":"update"}]
21:14:15.108 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - onResourcesEventTask() resource count 3
21:14:15.109 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - onResourcesEventTask() merged to 2 resources
21:14:15.110 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateChannels() from resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
21:14:15.110 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature' update with 'UNDEF' (fullUpdate:false, isDefined:true)
21:14:15.111 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature-abs' update with 'UNDEF' (fullUpdate:false, isDefined:true)
21:14:15.112 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color' update with '39.061,29.1300,0' (fullUpdate:false, isDefined:true)
21:14:15.113 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-xy-only' update with '39.061,29.1300,100' (fullUpdate:false, isDefined:true)
21:14:15.113 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'effect' update with 'NO_EFFECT' (fullUpdate:false, isDefined:true)
21:14:15.114 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'dimming-only' update with '0.4000' (fullUpdate:false, isDefined:true)
21:14:15.114 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Stehlampe_Wohnzimmer_Farbe' changed from 35.983,44.6700,20.16 to 39.061,29.1300,0
21:14:15.114 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'on-off-only' update with 'OFF' (fullUpdate:false, isDefined:true)
21:14:15.115 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'alert' update with 'NO_ACTION' (fullUpdate:false, isDefined:true)
21:14:15.115 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'last-updated' update with '2024-03-12T21:14:15.115194100+0100' (fullUpdate:false, isDefined:true)
21:14:15.115 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> onResource() consumed resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
21:14:15.116 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateChannels() from resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
21:14:15.116 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature' update with 'UNDEF' (fullUpdate:false, isDefined:true)
21:14:15.117 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-temperature-abs' update with 'UNDEF' (fullUpdate:false, isDefined:true)
21:14:15.117 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color' update with '39.061,29.1300,0' (fullUpdate:false, isDefined:true)
21:14:15.120 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'color-xy-only' update with '39.061,29.1300,100' (fullUpdate:false, isDefined:true)
21:14:15.120 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'effect' update with 'NO_EFFECT' (fullUpdate:false, isDefined:true)
21:14:15.121 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'dimming-only' update with '0.4000' (fullUpdate:false, isDefined:true)
21:14:15.121 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'on-off-only' update with 'OFF' (fullUpdate:false, isDefined:true)
21:14:15.121 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'alert' update with 'NO_ACTION' (fullUpdate:false, isDefined:true)
21:14:15.123 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> updateState() 'last-updated' update with '2024-03-12T21:14:15.123029300+0100' (fullUpdate:false, isDefined:true)
21:14:15.123 [DEBUG] [ue.internal.handler.Clip2ThingHandler] - 0d1d1f4b-fef2-4171-9e26-020c15ce3555 -> onResource() consumed resource id:311a715a-e54e-4c1b-9114-3e8d4a416b1d, type:light
21:14:16.127 [TRACE] [g.hue.internal.connection.Clip2Bridge] - onEventData() data:[{"creationtime":"2024-03-12T20:14:16Z","data":[{"dimming":{"brightness":79.84},"id":"1d44eebc-15e1-4c6a-9801-b0516c194311","id_v1":"/groups/0","owner":{"rid":"675e35c8-9633-42a0-ab61-31fec33bb225","rtype":"bridge_home"},"type":"grouped_light"},{"dimming":{"brightness":79.84},"id":"6f687ae6-183d-4523-a2fd-9685bd61073a","id_v1":"/groups/2","owner":{"rid":"2e91e911-bf8a-4e99-92c3-a6b9ff34dfe0","rtype":"room"},"type":"grouped_light"},{"dimming":{"brightness":79.84},"id":"acfda9c7-658f-4bd7-8ce0-7ea440f57c4c","id_v1":"/groups/1","owner":{"rid":"afe31e22-7273-47f9-9f90-9d4bc3c796fe","rtype":"zone"},"type":"grouped_light"}],"id":"ee3d861c-cd53-4803-97eb-3daa63d37774","type":"update"}]
21:14:16.129 [DEBUG] [e.internal.handler.Clip2BridgeHandler] - onResourcesEventTask() resource count 3
Yeah. It is a ‘feature’ of the CIE xy conversion algorithms that the xy value shifts slightly as the luminance changes. Try 36,54,N where N = 100, 90,80,..5,4,3,2,1,0 and you will see this.
I am separately working on ways to minimise this shift in xy values.
Yes, I already tested this and the new version is of cause much better then the old one.
Also tested it with other colors, e.g. a green light instead of warm white and you only see the difference of you know about it.
The change in xy values is due to “Gamma Correction” which is an algorithm defined by Philips such that color intensities are boosted at low light levels. In principle even though the xy values get changed by gamma correction, as the luminance falls, the respective color balance perceived by the human eye should not.
However as I write this I have a sneaking feeling that the binding may not be properly applying the reverse gamma correction such that the HSB => RGB => xyY => RGB => HSB round trip might not end up with the exact same result. I will check this..
I made another change that should eliminate the round trip gamma conversion errors in the xy color coordinates as the brightness is reduced. The new version of the Jar is available via the same link as previously reported here
@Matze0211 just to report that the Hue binding specific fix for this issue has been merged, so it will be available in the next OH milestone (or snapshot) release.
There is also another fix waiting in OH core that would improve HSB - XY - HSB round trip accuracy even further. But that one might take a bit more time, as the maintainers are generally more conservative concerning OH core changes..
