Hue Dial Tap items
I’m running 4.0.1 on an Intel Nuc with Ubuntu.
I’m trying to get the readings form a Hue Dial Tap via the Hue API V2 binding. The Dial Tap shows up in the binding with a few Channels. If I try to add Items to the channel via the UI, I get a profile error.
If I use this Items file:
Number rotary        {channel="hue:device:601e82241c:b8f81075-5737-4072-96a2-64ca2b53a264:rotary-steps"}
Number knoppen         {channel="hue:device:601e82241c:b8f81075-5737-4072-96a2-64ca2b53a264:button-last-event"}
The items get connected to the channels, buth their reading stays NULL.
The log file however, does show the proper readings:
2023-08-20 09:53:32.975 [INFO ] [openhab.event.ChannelTriggeredEvent ] - hue:device:601e82241c:b8f81075-5737-4072-96a2-64ca2b53a264:rotary-steps triggered 30
2023-08-20 09:53:34.043 [INFO ] [openhab.event.ChannelTriggeredEvent ] - hue:device:601e82241c:b8f81075-5737-4072-96a2-64ca2b53a264:rotary-steps triggered 60
2023-08-20 09:53:34.043 [INFO ] [openhab.event.ChannelTriggeredEvent ] - hue:device:601e82241c:b8f81075-5737-4072-96a2-64ca2b53a264:rotary-steps triggered 30
2023-08-20 09:53:35.046 [INFO ] [openhab.event.ChannelTriggeredEvent ] - hue:device:601e82241c:b8f81075-5737-4072-96a2-64ca2b53a264:rotary-steps triggered 30
2023-08-20 09:53:35.047 [INFO ] [openhab.event.ChannelTriggeredEvent ] - hue:device:601e82241c:b8f81075-5737-4072-96a2-64ca2b53a264:rotary-steps triggered 106
2023-08-20 09:53:36.062 [INFO ] [openhab.event.ChannelTriggeredEvent ] - hue:device:601e82241c:b8f81075-5737-4072-96a2-64ca2b53a264:rotary-steps triggered 15
2023-08-20 09:53:36.063 [INFO ] [openhab.event.ChannelTriggeredEvent ] - hue:device:601e82241c:b8f81075-5737-4072-96a2-64ca2b53a264:button-last-event triggered 1000
2023-08-20 09:53:36.063 [INFO ] [openhab.event.ChannelTriggeredEvent ] - hue:device:601e82241c:b8f81075-5737-4072-96a2-64ca2b53a264:button-last-event triggered 1002
2023-08-20 09:53:37.061 [INFO ] [openhab.event.ChannelTriggeredEvent ] - hue:device:601e82241c:b8f81075-5737-4072-96a2-64ca2b53a264:button-last-event triggered 4000
2023-08-20 09:53:37.062 [INFO ] [openhab.event.ChannelTriggeredEvent ] - hue:device:601e82241c:b8f81075-5737-4072-96a2-64ca2b53a264:button-last-event triggered 4002
What am I doing wrong??
Thx.
These channels are Trigger channels, so the item must be a String item.
Thanks! that solved it!
