Should the IP address be the same IP address of my openHAB server?
The caption below the Option Discovery Address reads, “If your host has multiple IP addresses you may specify the IP you would like to advertise in the UPNP discovery process. You may safely leave this empty on most systems.”
Is this referring to having multiple IP address associated with the openHAB server?
