I created a couple of Switch items to use as scenes. For example one is called “Away”. When it turns on then all lights turn off and heaters are set to lower temperature - all that using a rule. I marked the switch with the “Switchable” tag so it does appear as option on my Echo. It only works when I say things like “Turn Away on” which isn’t very natural.
- I would prefer to say something “I’m leaving” or “I’m gone” etc. Is this possible?
- For debugging purposes, is there a url which returns the list of options/devices offered by the hue emulator so that I can see what Echo gets as options?
